Cracked dizzy cap.
Replace the cap rotor and wires. Not worth the frustration.
Hello Guys and Girls.
I am losing spark on my disco1 v8. The engine goes: Vrrrr bwu Vrrrrr bwu bwu Vrrrr, with a very noticeable click of spark jumping to earth somewhere around the distributor and plug wires in time with every Bwu.
I have looked at the wires in the dark, and some are leaking with very small sparks, but I cannot see the spark causing the loud "tick". I hope this is not inside the distributor somewhere.
First step will be replacing the wires tomorrow, and see if I get somewhere
Any ideas would help.
Pleco
Land Rover. The Art Of Arriving!
Cracked dizzy cap.
+27 zero eight 2 four 95 9252
Sound advice Henris
Those "small" sparks rob you of big amounts of power and fuel. Dizzy cap wires and rotor is not so expensive and will make a big difference.
Henk
Follow us on Facebook
Replaced the leads, and problem solved. Replaced the rotor and cap as a pre caution. Will keep the old rotor and cap as spare.![]()
Pleco
