Conqueror Conquest 12V power system
Results 1 to 4 of 4
    Noordheuwel
    Question Conqueror Conquest 12V power system
    Hi All
    I am now the proud owner of a Conqueror Conquest trailer, its a 2004 model and I must say I am impressed with the awesome condition its in.
    However the trailer does not have a 12V power system, I would like to find out from the more experienced campers out there which 12V charger should I look at, I am not going solar with it, I just want 12V for the fridge so it stays cool if I overnight somewhere on my way to a camping site.
    Any recommendations or advice would be appreaciated.
    If guns are outlawed only outlaws will have guns.
    2.5 Nissan Pathfinder
    Ford Ranger 2.2 Supercab - Ex
    Jan 2011
    Thanked: 7
    Budget? NL battery box with a BH plug on the towbar would be easiest..
    Noordheuwel
    Quote Originally Posted by pblaauw View Post
    I need a charger that can charge the battery from 220V, the charge from car is already in place.
    I need something that will also stop charging once the battery is full.
    Sep 2015
    Paarl
    This is also something I have been contemplating about.
    From my perspective, there are two options here:
    1. Power provided by car (ie dual battery system feeding power to trailer);
    2. Dedicated system for trailer (either built-in or mobile battery box).
    Both have up/downsides to them.
    Car provided power:
    - Relatively inexpensive (NL DiY kit is R2000)
    - Automatic charging while driving
    - Works great if fridge is mounted in back of car
    - Risk of running out of power when stationary for long
    - Camp setup limitations (ie vehicle and trailer needs to be close)
    Dedicated trailer system:
    - More comprehensive system allowing for different types of input (AC/Solar/Battery)
    - Automatically detect/switch to strongest input
    - Charging solution built-in
    - Can connect to vehicle to charge while driving
    - More expensive solution (ie DHcP approx R5,000 excl battery and solar)
    - Does require some technical knowledge unless installed by professional
    I'm leaning towards a DHcP system built-in the nose cone of trailer and mounting all connectors (like caravan plug and lights) to outside of trailer. Though the system is more expensive, it provides a much longer term and flexible solution.
    If all else fails, a NL battery box does the trick, but you would need a Ctek device to charge/condition it properly.
  1. Monitoring\Analysing a dual charging system ......
    By Elders in forum Camping, Fridges, Accessories
    Last Post: 2018/03/14, 09:09 PM
  2. Part catalogs & other useful info
    By charlatan in forum Jeep
  3. 12v Yskas power supply
    By 1965Landy in forum Camping, Fridges, Accessories
    Last Post: 2014/02/09, 01:48 PM
  4. Upgrading the 12V DC system
    By Gert du Preez in forum Camping, Fridges, Accessories
    Last Post: 2011/11/04, 06:52 PM
  5. Grand Cherokee Error code
    By Nick47 in forum Jeep
