Help - Alternator or starter blown??
Results 1 to 11 of 11
    Default Help - Alternator or starter blown??
    Hi Guys,
    Need some advice from the auto electrical boffens please.
    The Pathy blew the fusible link (140A on the positive battery terminal) on Saturday. It happened while trying to start the vehicle on an incline without the clutch depressed (Don't ask).
    With the help of a few good men, we bridged the fuse just to get it started. When bridging it and turning the ignition to on everything is fine, but as soon as you turn the key to start the car the bridge starts glowing.
    We then run-start the car not to use the starter. The car starts fine but the bridge starts to glow again while the engine is running.
    What do you think? Alternator or starter blown Anyone have tips on how to test the alternator and starter?
    Thank you
    Lourens Fourie.
    2006 Nissan Pathfinder DCi 4x4 - "Die Brahman Bul"
    Langs die rivier, op n berg
    Thanked: 2462
    If starting to glow without starter being engaged, then not the starter.
    Could be a short somewhere, could be alternator
    Thanked: 2462
    Switch ignition on without starting the car..., of not glowing then, it could be alternator
    Thanks Reenen.
    I soldered the fuse link to test (and to be able to close the windows), and switching on the car everything is fine - everything works (windows, radio, etc.), but as soon as I turn the key to start it is the 4th of July (the soldering sparks and melts straight away). Not even a sound of the engine turning.
    Lourens Fourie.
    Thanked: 182
    Maybe get the right fuse 1st.
    140A is a lot of power. Most petrol-engine starter motors pull less than that.
    Once the engine is started, it has nothing to do with the starter anymore.
    Now you have an approx 120A alternator trying to recharge the battery. If the alternator was faulty, then it would not have heated up your link...
    Everything sounds fine to me, except your bad fix.
    Isuzu Frontier 280LX 4x4 2001
    Thanked: 182
    Quote Originally Posted by LHFPathy View Post
    Thanks Reenen.
    Solder is not meant for high current applications. High current components get bolted down.
    I'm not saying there is not a problem, but you will not find it until you have the correct fuse fitted.
    Quote Originally Posted by RogueFrontier View Post
    I have ordered the fusible link, but @ R640 a pop I am a bit weary to put the new fusible link before I have made sure that the alternator and/or starter is ok.
    I am looking at loose fuse holders now as testing with a loose R20 140A fuse that the circuitry is ok gives me a few more chances before reaching R640.
    Lourens Fourie.
    Thanked: 182
    Audio shops stock high current fuses and holders.
    Nissan is also known to be slightly coocoo with pricing. Shop around for the permanent fuse.
    Wilderness
    Thanked: 1078
    The fusible link always has +power feeding all the components on the vehicle.
    The starter charging wire could be connected straight to the battery+ or the starter cable+. A bad connection can cause fireworks on any of these cables. When trying to start the vehicle and it blows the fuse/ fusible link, points to a problem with the starter(short)
    If the vehicle is run started and the correct fuse is blown points to the alternator.
    Replace the fusible link with normal wire and see what happens. (be carefull of not damaging other components) There is a difference between a fusible link and a fuse. Only after testing with normal wire, replace with origional
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    After the 140A fuse link it splits to 4 (60A/80A/80A/100A) fuse links. The alternator is the only cable/wire that is connected between the 140A and the others.
    My thinking is, but I could be wrong, that one of the other fuse links would have blown before the 140A if it was something else. According to the manual there is a 40A fuse before the starter which is still fine. Here is an extract from the manual.
    M/T MODELS
    Power is supplied at all times:
    l to starter motor terminal 1 and
    l through 40A fusible link (letter J , located in the fuse and fusible link box)
    l to ignition switch terminal 1.
    with the ignition switch in the START position, power is supplied:
    l from ignition switch terminal 5
    l to IPDM E/R terminal 21.
    With the start signal is input to IPDM E/R CPU, power is supplied:
    l through IPDM E/R terminal 14
    l to IPDM E/R terminal 48.
    Ground is supplied at all times:
    l to IPDM E/R terminals 38 and 59
    l from body grounds E21, E41 and E61.
    Then the starter relay is turned ON.
    The IPDM E/R starter relay is energized and power is supplied:
    l from terminal 19 of IPDM E/R
    l to terminal 2 of the starter motor.
    The starter motor plunger closes and provides a closed circuit between the battery and the starter motor. The
    starter motor is grounded to the cylinder block. With power and ground supplied, the starter motor operates.
    Lourens Fourie.
    Verdict.... Alternator. Replaced and everything is 100% again.
    Was starting to worry that it was my bad fix only.
    Lourens Fourie.
  1. How to know if NL 50 amp fuse is blown
    By fordshark in forum Camping, Fridges, Accessories
    Last Post: 2013/11/29, 08:35 AM
  2. Freelander 2 Blown boostpipe
    By jono1981 in forum Land Rover
    Last Post: 2012/07/25, 10:38 AM
  3. Blown fuse for aux 12v output.
    By Morne Snyman in forum Toyota
    Last Post: 2012/07/13, 04:28 PM
  4. blown front fog light fuse - disco3
    By vnitos in forum Land Rover
    Last Post: 2011/01/07, 02:40 PM
  5. Blown head gasket lead to blown head?
    By cmcs in forum Mitsubishi
    Last Post: 2007/06/29, 09:46 AM
