Fortuner D4D fuel consumption - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 40 of 88
  1. #21
    Rustenburg
    Thanked: 119
    Quote Originally Posted by PieterOos View Post
    Why, and making it worse or better?
    Takes longer to build turbo pressure
    More fuel needed to spool turbo.. thus more pressure applied initially to accelerator..
    It is a known fact that engines produce more power at sea level than at altitude, even turbo engines..
  2. #22
    Thanked: 918
    From personal experience when I went up to JHB in my Fortuner, I'm sure I felt a slight drop in performance but the consumption stayed pretty much the same??
    FJC - Just Cruising
  3. #23
    Rustenburg
    Thanked: 119
    Why?
    Quote Originally Posted by konstanddp View Post
    I would expect higher altitude = less oxygen, thus lower power etc
    Yes, but less pressure, not actual molecule count..
  4. #24
    Jan 2015
    Gladstone, QLD
    Thanked: 513
    Fuelly.com usually gives you a good feel for real world consumption on most vehicles. Keep in mind that the figures might be a bit conservative, because only people who care about their consumption will bother to upload the stats!
  5. #25
    Rustenburg
    Thanked: 119
    Quote Originally Posted by dirtshark View Post
    Well that is in its self impossible.. If you have less performance for the same engine you will use more fuel to achieve the same amount of work.
  6. #26
    Thanked: 724
    And the effect of less air resistance at altitude on vehicle aerodynamics? (Power to overcome aerodynamic drag?)
  7. #27
    Rustenburg
    Thanked: 119
    We're talking urban consumption.. I think
    And the effect you are talking about will be minute and only works on really big cars
  8. #28
    Thanked: 918
    Quote Originally Posted by Andrew bin Achmet View Post
    I really don't know - just sharing my experience Maybe I will start another thread to get input from all.
    I see a few guys get the same (good) consumption up top as we get down here though
    FJC - Just Cruising
  9. #29
    Jun 2012
    Klerksdorp
    Thanked: 64
    Thanks SuzukiPiet. Fuelly.com indicates an average of 9.8km/L for 2009 model diesels
    2009 Toyota Fortuner 3.0 d-4d 4x2
    Custom off-road trailer with Echo TTT
  10. #30
    Rustenburg
    Thanked: 119
    I must be honest, I do not believe that you can achieve above 8.0km.l in a Fortuner in urban driving (real urban driving - stop streets etc)
    I will recommend that people who claim that they do, use Fuelly for some time and see for themselves
  11. #31
    Thanked: 918
    Sure its not 7.3L/100kms
    FJC - Just Cruising
  12. #32
    Jan 2015
    Gladstone, QLD
    Thanked: 513
    when I got it, the computer was on 9.2 and now also on 7.3 after I cleared it on the previous fillup. can it be that a heavy foot can make such a big difference??
    Yes! I can drive my Grand Vitara 2.4 in town at 9.0km/l (without TOO much effort), but it is EASY to get that down to 5km/l!
    Driving style is everything when it comes to fuel consumption. Top Gear once had a show where a BMW M3 beat a Toyota Prius on fuel consumption...
  13. #33
    Thanked: 724
    Agree with more power required = higher consumption
    (But then again - more power = higher consumption, still more power on sea level, so....)
    Modern ECU's (Turbo) usually do air pressure compensation as well, getting the output closer to sea level pressure. (I *THINK* 5% or so loss instead of ~1% / 100m, which can get to ~15% on the Highveld. (Non- TC))
    However - I would guess the differences are quite small as can be witnessed by e.g. my D-4D's consumption @ ~1500m, vs. Disrtshark's (sea level) which was more or less the same.
    IMHO - 7.3 is way out, even on the Highveld.
    Interesting article, http://www.wseas.us/e-library/confer...LA/EELA-29.pdf, but for non-turbo.
  14. #34
    Thanked: 918
    Mine did better (9), measured tank to tank and on the computer(which was 100% correct) for over two years, as I said it averaged out at 10.
    There are thousands that get the same consumption.
    FJC - Just Cruising
  15. #35
    Rustenburg
    Thanked: 119
    I mention again..... URBAN consumption.
    My Fortuner that I had in 2008, gave me an AVERAGE of 9.7, but less than 8 in town..
  16. #36
    Thanked: 354
    Log into my fuelly. http://www.fuelly.com/car/toyota/for...kes1754/110888
    PS: I have the 2011 model. They are more thirsty than the 2006-2009 models!
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
  17. #37
    Jun 2012
    Klerksdorp
    Thanked: 64
    Is there anything that can be done to improve it? tuning wise
  18. #38
    Rustenburg
    Thanked: 119
    Quote Originally Posted by JacoE View Post
    Very impressive!
    You obviously are late for all your appointments
  19. #39
    Rustenburg
    Thanked: 119
    Maak jou regter groot toon kleiner!
  20. #40
    Thanked: 918
    7.3 is far to high FACT!! I never got worse than 9 even in 100% urban.
    My FJ has averaged 6.9 combined!! That's for a 4L auto with the aerodynamics of a post box!!!
    FJC - Just Cruising
  1. Most Fuel Efficient Double Cab Bakkies in South Africa
    By Haggy4x4Bedinges in forum Vehicle & Technical Chat - General
    Last Post: 2015/06/18, 11:15 AM
  2. Advantages of 50ppm diesel
    By Sanman in forum Vehicle & Technical Chat - General
    Last Post: 2015/04/16, 05:11 PM
  3. Fortuner fuel consumption question
    By Dieselman in forum Toyota
    Last Post: 2014/08/19, 12:50 PM
  4. Grand Cherokee Error code
    By Nick47 in forum Jeep
  5. Replies: 13
    Last Post: 2010/05/17, 12:08 PM
