Plastic fuel tanks - Page 2
Results 21 to 30 of 30
    Helderkruin
    Thanked: 409
    Default Re: Plastic fuel tanks
    Landy ja dit is so een.
    Maar gaan kyk by Midas baie goed koper dink ek het R450 betaal daar en is die staal een .
    Een soos die?
    https://www.wantitall.co.za/automoti...SABEgIoy_D_BwE
    teen daai prys sal ek maar bietjie diesel drink op die outydse 'petrol steel vir die bike' manier. 1 meter hosepipe en n pakkie mints.
    Langebaanweg
    Thanked: 1124
    As jy op die "filler" pyp 'n konneksie aanbring wat jy kan af "blank", dan kan jy die pomp daaraan konnekteer en laat loop terwyl jy ry.
    As tenk vol wys dan sit jy net die pump af.
    Jul 2019
    Modimolle
    Thanked: 8
    I am looking at getting one of the pioneer plastics tanks. With the blessings from Henris who used them for years with no trouble, I am convinced. I dont like a permanently fitted long range tank, as you have to carry all that fuel and weight all the time. Will fit the plastic tank in the loadbay, strapped down next to the 50lt water tank.
    Now the question is:
    How do I get the diesel from the plastic tank into my vehicle's tank? As the outlet of the plastic tank will be lower than the filler on the vehicle. Can you pump it safely using an inline pump? And what pump do you use?
    Gravity filling a jerry can and then transferring to vehicle is not an option.
    Why donít you use air ? Surely you have a compressor . Connect it to the breathe and a regulator to not over pressure it .
  4. The Following User Says Thank You to Candyman0113 For This Useful Post:
  5. #24
    Jan 2010
    Thanked: 188
    Fit a high preasure pump in the back, with a quick release connection typically found on boats so that you can take a hose to the filler cap....,works like a dream, no air locks etc etc, and you can fill other vehicles as well. I also fitted a switch inside a small round plastic container with a lead to the pump so i could turn the pump on and off while at the filler cap. Filled the plastic bottle with resin to make it intrinsic to a point.
    (USED A SECOND HAND PUMP OBTAINED FROM A SCRAP YARD THAT CAME OFF AN AUDI TURBO)
  6. #25
    Helderkruin
    Thanked: 409
    Dit sal beslis werk so en is n goeie plan dan kan jy net n klein ball valve in sit waar jy hom wil af blank.
    Ek wil net kyk waar kan ek die 60lt tank onder my F vas sit dan gaan ek dit ook so laat werk terwyl ek ry.
  7. #26
    Wilderness
    Thanked: 1170
    Ek het 'n 100lt tenk agter op die bak. T piece in die filler se breather pyp, deur die loadbin, 10mm ball valve aan tenk. Wanneer die bakkie se tenk so by 1/4 kom, dan maak ek die ekstra tenk oop en die diesel gravity feed binne in die bakkie se tenk in. Teen daardie stadium sal die vlak binne in die ektra tenk laer wees as die bakkie se filler, en kan jy hom oop los. Die enigste probleem wat ek soms ondervind is, dat die bakkie se tenk druk op bou, en dan hou dit die ekstra tenk se vloei terug. Maklik. Maak net die bakkie se tenk oop en dan vloei hy weer.
    Wanneer jy die ekstra tenk wil uithaal sit jy net 'n stopper in die pyp.
    Check in die Isuzu afdeling ek het fotos geplaas.https://www.4x4community.co.za/forum...ange-fuel-tank
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  8. #27
    Friemersheim, Southern Cape
    Thanked: 3089
    My long range tenk (uitgehaal) het een van die gehad.
    https://www.takealot.com/electronic-...E&gclsrc=aw.ds
  9. #28
    Thanked: 666
    Nie n slegte plan nie, maar ek wil nie n gat in my bak maak vir die pyp nie. Dalk oor 5 jaar as ek nog die voertuig het. Kans is skraal, ek het nog nooit n voertuig langer as 4 jaar besit nie.
    12 Conqueror courage
    17 Ranger Supercab Tdci (Sold)
    97 Defender HCPU Tdi (Sold)
    99 Discovery 2 TD5 GS (Sold)
  10. #29
    Langebaanweg
    Thanked: 1124
    Met 'n nice blanking grommet sal niemand dit regtig weet nie.
    Haal uit as jy ekstra tank gebruik en sit terug na die tyd.
  11. #30
    Thanked: 666
    Quote Originally Posted by Leon Venter View Post
    Dit klink beter, sal gaan kyk. Anders is dit mints en hosepipe. Dit gaan dalk een keer per jaar gebruik word. Ons het destyds n petrol pomp vir die 2.8i Defender gesoek. Goedkoopste een was by LP4A teen R4500. Het die pomp uitgehaal, na autozone gegaan en een gekry vir R350.
    Solank dit veilig is om te gebruik. Ek gaan net pomp as ek stil staan by die kamp, hoef nie te pomp terwyl ek ry nie.
    Hoe vinnig kan so pomp 60 liter pomp?
  1. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  2. Long range fuel tanks
    By Fanievdb in forum Camping, Fridges, Accessories
    Last Post: 2013/01/18, 12:51 PM
  3. Installing chips to increase power
    By stevan in forum Vehicle & Technical Chat - General
    Last Post: 2012/09/10, 10:02 AM
  4. Plastic fuel tank 60 liters
    By Kaptein Jack in forum General 4x4 Discussion
    Last Post: 2009/02/12, 08:13 PM
  5. Who sells 60 L plastic water tanks?
    By Ouarzazate in forum Camping, Fridges, Accessories
    Last Post: 2008/08/21, 05:23 AM
