Making Ice - the ultimate answer
Results 1 to 20 of 39
    Aug 2008
    Roodepoort, Wesrand
    Cool Making Ice - the ultimate answer
    Most attempts at making ice during a long trip ends up with a solid block of frozen water and food packages on the bottom of the freezer due to spillage of water from whatever container you use to try to make ice.
    A couple of years ago I've resolved this problem, and are not sure how far this method has filtered through the 4 x 4 community. If it hasn't reached you yet, here is the answer:
    Use those little plastic see-through pill containers that are cylindrical, about 55 mm high and 28 mm in diameter, with a snap-on lid. Fill as many of them as you have space for in your camping freezer, with water, and line the bottom of the freezer in layers with these little pieces of magic!
    They seal water-tight and will give you a fresh supply of ice-blocks every night (provided of course that your freezer is running effectively, and that you re-fill the ones that you've emptied out ). Dislodging the icecube from the container is as easy as letting it stand outside for about 5 minutes, or to hold it tightly in your hand for a little while.
    You can buy these pill containers at any Plastics Warehouse or similar outlets.
    If you DO insist in letting your neatly prepared pre-packed food portions float around in thawed ice water and the labels come off all the time or become unreadable, the answer is also simple - mark the package or Tupperware container INSIDE and not on TOP !
    Hope these suggestions make life easier for you. Would love to here about alternative solutions.
    Last edited by Dirk; 2008/08/22 at 12:40 PM. Reason: Commercial advertising removed. Refer to our TOS.
    4ePajero Guest
    We use the plastic bags that have sub-divisions for cubes.
    You fill it and tie the top closed. Even if it thaws, it does not spill.
    Feb 2008
    Krugersdorp
    I have a Ice maker not cheap but it works I can't drink my Red Hard with out ice.
    To see what my previous Hilux did click link below 8)
    https://www.youtube.com/watch?v=0m_cUKPjRAU 8)
    Now to see what the Fortuner can do 8)
    We use some small water bottles to supplement the ice bricks, and the blocks themselves go into tupperware
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    Give a man a beer, waste an hour. Teach a man to brew, and waste a lifetime!
    Jan 2008
    Modderfontein, naby Rysmierbult
    Johan Mitchell, .... r.i.v. Swambo Marthie
    My beste kennis is diť oor my eie onkunde
    '96 Colt DC V8 ... Safari Camper ... '88 Fleetline L
    '88 Ballade 150 ... sold
    "The rule here is that there is no rule" .. MikeAG
    Bothasig
    This is an excellent idea. The iceblocks should also be a little more substantial than the dinky little ones from the plastic bags - so you need fewer of them.
    '02 Patrol 3.0Di GL
    On your screen
    Ek HAAT ys, dit gee verskriklik babbelaas
    [B]Johan Prinsloo
    Saudi Arabia / Brackenfell CT
    Quote Originally Posted by 2510JP View Post
    Nee dis nie die ys nie. Dit is die slaap, want ek voel baie goed voor ek loop slaap, maar hond die volgende oggend.
    Sorry OT
    Cecil
    Dharhan, Saudi Arabia
    and sometimes
    Brackenfell, Cape Town
    97 Colt 3L V6 DC Rodeo
    De Kelders
    Quote Originally Posted by 4ePajero View Post
    I use the latest ones, they are self sealing.
    Apr 2008
    JHB
    Quote Originally Posted by Pype View Post
    Could you give us more info on your 12V ice maker?
    What make, model etc?
    Where are they sold?
    Do you know if one can see the unit on a website somewhere?
    Thanks,
    Tim
    Aug 2008
    Roodepoort, Wesrand
    Default General response
    Tx for the comments guys.
    Just to remove some confusion: the suggestion on how to make ice pertains to the ice that you put in your drinks, and not to a method of keeping your cooler box cold. Apologies for not having made this clear enough in the original post.
    An ice-making machine is ideal.
    The plastic bags with little rectangles work well under relatively calm and static driving and camping conditions. Been there, done that, bought the T-shirt. However, you still have to spend the time and effort to purchase, and remember to purchase, your new supply of ice-making bags. And we were operating with a lack of enough finnesse to keep them intact
    As far as the second tip / hint / suggestion in the last paragraph goes: I have been sworn to silence, and I respect that fully in terms of the TOS. (I hereby offer my apology Dirk).
    En vir die Afrikaanse manne - Eish!!!!!
    Jan 2008
    Quote Originally Posted by babba View Post
    Eish, en ek dog nog die hele tyd dis Zulu !
    May 2007
    Springs
    jys verkeerd, dis die coke wat jou dronk maak.........
    coke en brannewyn?
    coke en rum?
    coke en whisky?
    coke en vodka?
    dis die coke se ek vir jou
    Die easiest way is to buy a box of these sealed pure water sachets used by marathon runners and to dump this in the freezer. You buy them per box of 100 (about 100ml per bag) and last time I paid R13.00 per box. You will never run out of ice again.
    Aug 2008
    Roodepoort, Wesrand
    Quote Originally Posted by PietH View Post
    Jis Piet, klink na 'n wenner .... waar koop mens daardie goed?
    If brute force does'nt not work you are not using enough!!!
    Size DOES matter!!!!
    Christo Conradie
    Groot-Jongensfontein
    "Overlander"
    Feb 2008
    Wellington
    I also had the blink plan to take my icemachine with on our last trip to Boegoeberg. It works nicely, but what happens if you do not have 220 V. I believe running it from 12 V via your inverter might be too heavy on the second battery that is already working hard pulling lights and a freezer.
    The pill bottles is an excellent idea Babba.
    Skippie
    4ePajero Guest
    What size 'dop' do you throw, if your ice cubes are 100ml!
    The Windy City
    100ml is not much?
    Tall glass, filled with icecubes, double Southern Comfort, and dash of coke and you have drink fit for a king!
  19. #19
    Feb 2008
    Krugersdorp
    Quote Originally Posted by TimJNB View Post
    Thanks,
    Tim
    Hi Tim only saw your post now here is the web site for the Ice maker http://www.xtremerefrigeration.co.za/index_files/Page917.htm I have the BL-15 220 volt which I run of a inverter there is about a R3000-00 deferens between the BL-15 (220 volt only) and the DL-15 (12 volt only).
  20. #20
    Aug 2008
    Roodepoort, Wesrand
    Refer my signature
    Christo Conradie
    "Overlander"
  1. Has anyone used dry ice to keep things cold - when camping
    By william coetzer in forum Camping, Fridges, Accessories
    Last Post: 2010/10/26, 10:56 PM
  2. My camping apple pie and Ice cream recipe
    By Thirstie in forum Braai, cooking, recipies
    Last Post: 2010/06/25, 12:09 PM
  3. ICE in case of emergency
    By Engel in forum General 4x4 Discussion
    Last Post: 2008/04/06, 07:59 AM
  4. Making your own Salami
    By 3.5paj in forum Braai, cooking, recipies
    Last Post: 2008/01/30, 09:07 AM
