Trailblazer diff lock
Results 1 to 3 of 3
    Aug 2015
    Melkbosstrand
    Thanked: 29
    Default Trailblazer diff lock
    Hi, I took my TB for the first time off road today. I faced a few obstacles, typical axel twisters, and noticed that when I engage low range that the traction control is switched off automatically. As a result when one or more wheels starts spinning the traction control does not activate and the limited slip dif does not engage. However, when I attempted the obstacles in high range and one of the wheels start spinning, the traction control kicks in, the wheel spin stops and there is an immediate traction and I completed the obstacles without any issues. This was not the case when I was in low range. My question, should one attemp to complete such obstacles in high range then when the traction control is switched on or is there a way to keep the traction control switched on while in low range? I drive the 2.8 Auto.
    Sep 2012
    Vereeniging
    Hi Jaco
    Have a look at the video in post 69 in the following tread, the best explanation of how the BTC works.
    http://4x4community.co.za/forum/show...=184903&page=2
    The most important thing for the BTC to work properly is a steady throttle.
    Real engines use spark plugs
    2012 Trailblazer 3.6 V6
    2017 Jeep Grand Cherokee 5.7 HEMI
    Philip
    Mar 2007
    Thanked: 104
    Quote Originally Posted by globaljaco View Post
    The traction control does not switch off, the stability control does, which means that the engine power is not reduced. I do find the system to be lazy, as it takes a lot of spinning before it intervenes to power the vehicle through.
    As per the video, you can see that it takes a while. Now put it onto a 20 degree slope.....
    I think that the software could have been programmed better for low range use.
    Compare a Pajero or Jeep Wrangler and you will see a totally different picture.
    The Jeep Grand Cherokee with Quadatrac system is way worse though.
  1. Ranger T6 rear diff lock problems
    By Monkey-D in forum Ford & Mazda
    Last Post: 2015/01/19, 08:26 PM
  2. Patrol - Broken rear diff lock - Angola
    By astoltz in forum Vehicle & Technical Chat - General
    Last Post: 2014/10/04, 07:30 PM
  3. Replies: 17
    Last Post: 2013/04/06, 07:24 PM
  4. Chev trailblazer
    By willie-potch in forum Chevrolet
    Last Post: 2013/02/07, 06:05 AM
  5. Suspension GWM Diff Lock??
    By BaaZ in forum Vehicle & Technical Chat - General
    Last Post: 2010/11/18, 04:50 PM
