Amarok PDF files and recalls
Results 1 to 20 of 28
    Thanked: 2319
    Default Amarok PDF files and recalls
    My collection of Amarok files.
    Hope it helps.
    Amarok bullbar fitting instructions
    Attached Files Attached Files
  2. The Following 5 Users Say Thank You to MariusFourie For This Useful Post:
    Amorosa
    Thanked: 355
    Thanks Marius
    Bush Lapa Miskruier 586
    Thanked: 2319
    Thanked: 2319
    Thanked: 2319
    Thanked: 2319
    last batch
    These are recalls (not applicable to all models)
    Jun 2007
    Lime Acres
    Thanked: 112
    Nou waar kry jy dit?
    Jacques Jansen
    4 x4: 5.7 Hemi Commander
    Platkar: Amarok
    Amorosa
    Thanked: 355
    Weet dit was op die Aus Amarok Forum ook gewees.
    Thanked: 2319
    Quote Originally Posted by Jeep Fan View Post
    Dis al jare se opgaar. As ek iets interessant ontdek erens save ek dit.
    Thanked: 2319
    Quote Originally Posted by Bogaards View Post
    Ek dink dit is waar ek meeste gekry het.
    Jun 2007
    Lime Acres
    Thanked: 112
    Bargain, baie dankie. Ek hou daarvan om te weet hoe goed werk.
    Jacques Jansen
    Platkar: Amarok
    Middelburg
    Wonder of mens heated seats kan voor in die amarok insit soos die Europese weergawes? Wonder hoeveel werk sal dit wees
    Thanked: 10040
    Quote Originally Posted by Johan_Otten View Post
    Vir wat? Ek dink ons het 'n hele 3 keer ons s'n gebruik in die Wrangler.
  15. #14
    Middelburg
    Vra net. Baie lekker in die winter en vir die vrou. Ek het tans suzuki en gebruik ons sin baie. Werk ook selfs as mens lang pad ry en die hitte op d lae rug help met rug pyn.... ry nie met dit permanent aan nie.... Hier kan dit soms ook baie koud word
  16. The Following User Says Thank You to Johan_Otten For This Useful Post:
  17. #15
    Richards Bay
    Could any one assist me on experience with Cooper ST Max 256x65x17 on a VW Amarok
    4 Motion 6 speeds manual gearbox?
    And the Tyre pressures on HI way and Gravel roads and sand an Mud
    My vehicle is 25 to 50% loaded of it max 3000 GVM
    Original Tyres was 245x65x17 and the date plate of the Manufacturer recommend 200 Kpa all-around un loaded and
    300kpa rear and 200kpa frond on cold tyres
  18. #16
    Richards Bay
    Default Jan
    Could any one Please assist me on experience with Cooper ST Max 256x65x17 on a VW Amarok
    My vehicle is 25 to 50 % loaded of it max 3000 GVM and from Time to Time Max up to GVM KG
  19. #17
    May 2016
    Somerset west
    Default Re: Amarok PDF files and recalls
    Hi, i am new to this forum..don't really do much
    4x4 ing.. but i recently bought a VW Amarok..
    Unfortunately secondhand.. its a 2.0 tsi..
    The dealer had it serviced at a reputable
    service centre. After the first 1200kms the
    oil light popped on.. took it back to the service
    centre as instructed by the dealership..they filled
    up the oil and i went on my merry way again.. but the
    mechanic asked me to bring the bakkie in after 500km
    to check the oil level again.. so plus minus 700km later
    i took it back.. to my surprise the bakkie needed oil again.. so we added some more..the previous time it was 4.5L and this time another 4L.. there is no leaks and it doesn't smoke.. where can the oil disappear to? Obviously this is not normal.. is this a common problem with these petrol engines? Other than the fact that it uses alot of oil, it is an amazing bakkie.. any suggestions or comments?
  20. #18
    Thanked: 2319
    Quote Originally Posted by cobus buger View Post
    Joh, that's a lot of oil usage. More than what the manufacturer allows. Take it back and leave it there until they fix it or fit a new engine. It should still be under warranty hopefully.
    Speak to the dealer principal. Communicate in writing confirming everything that was discussed.
    Sent from my Hisense C20 using Tapatalk
  21. #19
    durbanville
    Marius het jy dalk enige pdf van 2014 amarok warranties etc?
    Amarok Bitdi 8spd Auto
    General Grabbers
    Starting with the mods
    Jeep Wrangler JK 2dr
    Cooper STT Pro 33's
    Maniac Bumper
    Poisen spider rock slider
    1 No Petrol card
  22. #20
    Thanked: 2319
    Quote Originally Posted by 4x4 freak View Post
    This is what I have on the Amarok
    Recall campaigns.
  23. The Following User Says Thank You to MariusFourie For This Useful Post:
