Sani Pass ML320CDI
Results 1 to 6 of 6
    Mar 2012
    Default Sani Pass ML320CDI
    Hi there,
    Please can I get some advice, I'm contemplating the trip up Sani Pass with an ML 320 CDi with permanent 4 wheel drive only, no low range or diff lock but it has ascent and descent control with standard 18 inch wheels.
    Would this pass be safe for me?
    Stealth
    Rangeview Krugersdorp
    Thanked: 935
    You would not notice the pass...
    Chev Aveo and Atos and Polo.
    Oct 2008
    East Rand
    Thanked: 38
    Jy sal dit maklik maklik doen. Ek het hom gedoen met n Renualt Koleos destyds...
    Live : Bethal , Work : Saudi
    Thanked: 218
    You will do it with ease in the ML did it last year June with a 1.5 Terios 4x4 had no problems
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
    Bryanston
    Thanked: 132
    Even a Tazz
    joburg
    Thanked: 321
    Did the pass on Monday, they are busy grading the road leading to the pass and SA post. Biggish soft mounds of sand and loose rocks that the grader operator rolled out the way by hand, after that plain sailing.
    On another note, no un abridged certificate for my 9 year old needed (whose passport also expires November), Lesotho side stamped entry and exit same time so I did not need to stop on way down.
    We carried on up the new Chinese road (fantastically smooth) and found knee deep snow all over, played in the snow then had lunch at the pub.
  1. Replies: 9
    Last Post: 2013/10/11, 01:38 PM
  2. Going up Sani Pass (snow)
    By Pappa-Jakkals in forum Lesotho
    Last Post: 2012/08/16, 12:18 PM
  3. Ford Ranger Sani Pass advert
    By Tony Weaver in forum The 4x4 Pub
    Last Post: 2012/06/10, 02:58 PM
  4. Sani Pass in 1 day?
    By JoelM in forum Lesotho
    Last Post: 2011/02/01, 02:22 PM
  5. Sani Pass August 09 Report
    By Bad Santa in forum Lesotho
    Last Post: 2009/08/18, 07:36 PM
