Can a RAV4 handle the sandy roads of Botswana? - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 21 to 40 of 101
  1. #21
    Thanked: 568
    Quote Originally Posted by Lord Farquart View Post
    I would not do it with an Xtrail, RAV4 or Duster. Jimny I would probably try and make it.
    What's the ground clearance on the vehicle you used?
  2. #22
    Almelo, Overijssel
    Thanked: 231
    Have no idea. Can go measure tonight, but the Pathfinder has 25mm spacers in front, jacked with airbags at the back and bigger tyres. I would guess 40mm+ from standard. Even so I could see how I table-topped the middelmannetjie in places.
  3. #23
    Thanked: 568
    Yours sounds pretty well cleared then. I checked the RAV4 specs & it has 187mm, which is quite low. The Pathfinder is listed as even lower, which doesn't look right. As a matter of interest, the Xtrail & Duster are both 210mm which is quite respectable when compared to what's available on the market, even on bigger vehicles.
  4. #24
    Almelo, Overijssel
    Thanked: 231
    Something seems weird there?
  5. #25
    Thanked: 568
    That's what I thought. A Pathfinder can't be lower than a RAV4 or the others mentioned. I'll check a few more sites.
  6. #26
    Helderkruin
    Thanked: 375
    Ek sal nie met n RAV 4 gaan nie dit is te lag as jy begin sand ry en die middle man is dan te hoog .En veral as jy gelaai is of sleep
    Jy gaan net die jou voertuig beskadig.Daar is wel baie plekke wat jy kan besoek daar met die RAV 4
  7. #27
    Florida
    Thanked: 639
    210mm unloaded!
  8. #28
    Thanked: 568
    210mm unloaded!
    That sounds more accurate. Its the same as a Duster or Xtrail
  9. #29
    Thanked: 568
    Here they have it at 165mm. It's an Aussie site & thinks there's a new Pathfinder over there.
    http://m.nissan.com.au/Cars-Vehicles...inder/ST-L-4WD
  10. #30
    May 2015
    Hermanus
    Default Ground clearance
    I have already decided to take of the plastic covers which makes a huge difference. Then give the car good cleaning session at a mechanic when I come back. Can that work better?
  11. #31
    JHB
    What year model is the RAV
  12. #32
    Almelo, Overijssel
    Thanked: 231
    No, it will not make difference. You will get stuck and ruin your holiday. Does your vehicle have traction control or stability control? If so, can you switch it off?
  13. #33
    May 2015
    Hermanus
    Yes it does have trac control and it can be switch off
  14. #34
    Thanked: 568
    Quote Originally Posted by mdevilliers View Post
    Probably not completely. It has a centre lock & LSD rear?
  15. #35
    Sep 2011
    Weltevreden Park
    My swaer het verlede jaar April saam met my deur Botswana getoer met sy Rav4. Die toer was van Khama, Khubu, Moremi (3de Brug), Savuti, Ihaha, Kasane, Nxai panne, en terug.
    Ek moes hom 5 keer uitsleep. Dit het hom R4500 gekos om die Rav weer regtemaak. Dit sluit die plat uitlaat pyp uit. Die moet nog vervang word.
  16. #36
    Thanked: 280
    The cleaners at Nxai pans use an old Rav4. Quite a sight seeing them tackle the thick sand.
  17. #37
    Nov 2012
    Thanked: 12
    Not really a brilliant idea.!! Yes you can do it with sand driving practice,recovery equipment and care with tire pressures.However you should go with at least two vehicles.The one ideally a proper 4 X 4 with low range.
    Getting permanently stuck in the middle of absolutely nowhere is not fun.Take a satelite phone!!
  18. #38
    Thanked: 180
    Hi m,
    I've uploaded a proper tyre calculator here: http://4x4community.co.za/forum/showthread.php?t=4372, but has made some assumptions as to your RAV tyre parameters and calculated that if the tyres are deflated from 2.2 bar pressure to 1.2 bar - you may need to go even lower, e.g. in the Namib we ran 0,8 bar, sometimes 0,6 - you lose 13mm in clearance.
    I assumed the following: 215/65 R16, 7J rim, Load rating 103, Speed rating H.
    You can use this calculator yourself, but if you post your actual parameters above - also the air pressure at which the standard clearance is measured - I'll rerun it for you, also including a 0,8 bar value.
    In a post from the distant past, I explained that some manufacturers inflate the tyres to 3 bar in order to artificially arrive at a better brochure clearance. So do not use that value - measure it.
    From Namib experience with a 2001 Forester, I would not go if the nominal clearance is not at least 205mm, typically deflating to 190mm at 0,8 bar.
    I'm guessing that in standard form, the RAV won't be scraping the middelmannetjie - it would be grading it.
    Johnie
    Volvo XC60 T5
    180kW/350Nm (1500 - 4800 rpm)
  19. #39
    Strand
    About 2 years ago I stumbled upon a Duster from South Gate to Third Bridge pulling a very small trailer. This guy was very peed off with how the 4X4 people churning up the road and so that he cannot drive in it. he had to gun it all the way and got stuck about 5 times and every time a good Samaritan pass by to extricate them from the sand or from the top of the " middelmannetjie".
    we also saw a guy with a ML320 at Third Bridge and they were going to Xaxanaxa the next day, thought they were travelling in a group with other vehicles to assist.
    So, yes, you can do it with possible difficulty and with assistance. Do not go it alone in real thick sand in a RAV4 though.
    Prado 120 V6
    www.optoer.co.za
  20. #40
    Thanked: 83
    Quote Originally Posted by Jan Lock View Post
    A friend of mine did Kubu and Moremi with us in the wet season ( December ) in a Jimny. Never got stuck. I would recommend that you must be at least 2 vehicles. Just in case.
    The Jimny is a proper 4x4 not so? It also has a solid axle up front I think? So probably able to out do a lot of the "big" 4x4's Im sure.
  1. General Botswana Info
    By KobusDJ in forum Botswana
    Last Post: 2019/09/10, 07:55 AM
  2. Botswana in our GV with RTT
    By Mike_P in forum Suzuki
    Last Post: 2014/08/27, 08:01 AM
  3. Namibia, Botswana and Zambia Tour
    By freeflyd in forum Namibia
    Last Post: 2010/02/04, 10:14 AM
  4. Botswana Around the Delta Dec 08 trip report
    By freeflyd in forum Botswana
    Last Post: 2009/05/26, 09:14 AM
  5. Sandy roads
    By CY Pajero in forum Botswana
    Last Post: 2008/01/13, 08:42 PM
