Results 1 to 14 of 14
    May 2014
    Kloof
    Default Navara 2.5dci bash plate/ sump guard.
    Wheres the best place to get a bash plate / sump guard for my truck. I am in Durban.
    May 2013
    Thanked: 168
    Ek het gemeet, na n cut suply gegaan en gesÍ sny my so size, 5 mm plaat, buig hom daar en daar 45 degrees en siedaar ek het n bash plate.
    Silence is golden
    Duck tape is silver
    Jun 2015
    Swellendam
    Default Re: Navara 2.5dci bash plate/ sump guard.
    Quote Originally Posted by ON-RNR View Post
    hi i am looking for a bash plate for my navara 2012 diesel 2.5 king cab.
    is your plate working well? have you photos and measurements available Please. i can get it made up here by our local SSK coop.
    thank you
    Karl
    Charly
    Loevenstein, Bellville
    Thanked: 511
    I'm not big on mods as I don't do any hectic trails and the Navara is mainly used for overlanding but the sump is quite vulnerable to obstacles. I ordered a Stofpad sump guard, fitted it myself and I'm very happy with the product.
    Niel
    2012 BMW F800GS
    Feb 2018
    Durbanville,
    Thanked: 28
    5mm!! Vatikaki ne
    Jun 2015
    Swellendam
    Quote Originally Posted by Musashi View Post
    Charly
    Jun 2015
    Swellendam
    ok and what did you pay for it?
    Charly
    Thanked: 511
    Quote Originally Posted by Brest View Post
    R1800 plus delivery. BUT that was in 2012 and they had a 30% discount going.
    Niel
    2012 BMW F800GS
    Feb 2018
    Durbanville,
    Thanked: 28
    They go for about R2,950-00 ex VAT and excl fitment (you can fit it yourself)
    Thanked: 18096
    2.5mm aluminium checker-plate will do the job. Easy to cut with a small grinder with a 1mm cutting wheel.
    Bending could be an issue if you don't have a flat edge but a set of G-clamps and a table edge and a rubber mallet can do most bends.
    Aug 2011
    Brackenfell
    Thanked: 517
    I have been wondering the same thing, why does one require 5mm aluminium plate on these. Why could vastrap or 3-4mm mild steel galv and ruberize not do the same job?
    5mm will require more force to bend/damage, just to supply some extra protection underneath?
    Feb 2018
    Durbanville,
    Thanked: 28
    I would not recommend an aluminum plate period. Aluminum is soft and will easily be pierced. Spend the couple of bucks and get something that will give you piece of mind. 3mm mild steel is as thin as I would want to go...
    May 2013
    Thanked: 168
    Quote Originally Posted by Gympee View Post
    I am currently using a Wildog on my Navara.
    And it's held up extremely well, considering that it's taken more bangs than a Hillbrow hooker.
    No cracks, just a few dents.
    Kind Regards
    Gympee
    +1, had wildog bash plate on my Triton and it took a beating
    Good product
  1. Bash plate giveaway for Land Rover Defender!!!
    By Stone Accessories in forum Commercial Member Adverts
    Last Post: 2013/08/03, 03:01 PM
  2. Bash plate giveaway for Land Rover Defender!!!
    Last Post: 2013/05/08, 04:03 PM
  3. Ford & Mazda Ford Ranger T6 - Fitting New Bash Plate!!!
    By Wild Ranger in forum Ford & Mazda
    Last Post: 2013/04/02, 09:53 PM
  4. Bash Plate for Triton
    By David A in forum Mitsubishi
    Last Post: 2008/05/01, 05:09 PM
  5. Nw Bash plate:)
    By BigRed in forum Mitsubishi
    Last Post: 2007/09/25, 09:30 PM
