SA Energy Group - Page 15
Page 15 of 17 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 281 to 300 of 324
Thread: SA Energy Group
  1. #281
    Jul 2015
    Default 100l low pressure solar geyser
    100L LOW PRESSURE SOLAR GEYSER-FROM:R3078
    - Save Money
    - Have a good feeling, while taking a shower
    - Take serious care of the environment
    - Increase the value of your home
    - Reduce your energy costs
    - Generate less CO2 and accordingly, less pollution.
    5% DISCOUNT FOR ALL 4X4 COMMUNITY MEMBERS
    PRICES ARE EXCLUSIVE OF VAT!!!!
ID:	364344   Click image for larger version.
ID:	364345   Click image for larger version.
ID:	364346   Click image for larger version.
ID:	364347   Click image for larger version.
ID:	364348   Click image for larger version.
Name:	download (2)_2.jpg
ID:	364349   Click image for larger version.
ID:	364350   Click image for larger version.
Name:	SAEnergyGroup Default Image.jpg
Name:	Midrand Banner.png
ID:	364352   Click image for larger version.
  2. #282
    Jul 2015
    Default 150l low pressure solar geyser
    150L LOW PRESSURE SOLAR GEYSER-FROM:R3495
    - Save Money
ID:	364354   Click image for larger version.
ID:	364355   Click image for larger version.
ID:	364356   Click image for larger version.
ID:	364357   Click image for larger version.
Name:	download (1)_2.jpg
ID:	364358   Click image for larger version.
ID:	364359   Click image for larger version.
ID:	364360   Click image for larger version.
ID:	364362   Click image for larger version.
  3. #283
    Jul 2015
    Default 70w 12v solar panels (ecco)
    70W 12V SOLAR PANELS (ECCO)
    Quality Assurance Testing:
    - Thermal Cycling Test
    - Thermal Shock Test
    - Thermal/Freezing & High Humidity Cycling Test
    - Electrical Isolation Test
    - Hail Impact Test
    - Mechanical, Wind & Twist Loading Test
    - Salt Mist Test
    - Light & Water-Exposure Test
    - Moist Carbon Dioxide/Sulphur Dioxide
    Multiple Protection:
    - All Climatic Environment
    - UV / Moisture / Corrosion
    - Reverse Polarity
    FROM R1025.00 EACH
ID:	364364   Click image for larger version.
ID:	364365   Click image for larger version.
Name:	60W 12V SOLAR PANEL.jpg
ID:	364366   Click image for larger version.
ID:	364367   Click image for larger version.
ID:	364368   Click image for larger version.
ID:	364369   Click image for larger version.
  4. #284
    Jul 2015
    Default Sk series 120w 12v modular inverter
    MODULAR INVERTERS SK SERIES 120W 12V-FROM:R186
    - USB Output
    - Built-In Energy Saver Lamp
    - Battery Voltage: 10V - 15V DC
    - Converter AC Output Voltage: 160V - 250V AC
    - AC Output Type: Modified Sine Wave
    - AC Output Frequency: 50Hz - 3Hz
    - Power Rating: Resistive Load - 70% of labeled rate
    - Inductive Load: 40% of labeled rate
    - Polarity Reverse Protection
    - Overload Protection
    - Over Temperature Protection
Name:	20140721_091731 (600 x 337).jpg
ID:	364371   Click image for larger version.
Name:	20140721_091831 (600 x 337).jpg
ID:	364372   Click image for larger version.
Name:	20140721_091848 (600 x 337).jpg
ID:	364373   Click image for larger version.
ID:	364374   Click image for larger version.
ID:	364375   Click image for larger version.
ID:	364376   Click image for larger version.
  5. #285
    Jul 2015
    Default 80w 12v solar panels (ecco)
    80W 12V SOLAR PANELS (ECCO)
    - Hail Impact Test
    - Salt Mist Test
    - Reverse Polarity
    FROM R1213.00 EACH
ID:	364378   Click image for larger version.
ID:	364379   Click image for larger version.
ID:	364380   Click image for larger version.
ID:	364381   Click image for larger version.
ID:	364382   Click image for larger version.
ID:	364383   Click image for larger version.
  6. #286
    Jul 2015
    Default 90w 12v solar panels (ecco)
    90W 12V SOLAR PANELS (ECCO)
    - Hail Impact Test
    - Salt Mist Test
    - Reverse Polarity
    FROM R1281.00 EACH
ID:	364393   Click image for larger version.
ID:	364394   Click image for larger version.
ID:	364395   Click image for larger version.
ID:	364396   Click image for larger version.
ID:	364397   Click image for larger version.
ID:	364398   Click image for larger version.
  7. #287
    Jul 2015
    Default Sk series 150w 12v modular inverter
    MODULAR INVERTERS SK SERIES 150W 12V-FROM:R210
    - 4 AC Plugs
    - USB Output
ID:	364400   Click image for larger version.
ID:	364401   Click image for larger version.
ID:	364402   Click image for larger version.
ID:	364403   Click image for larger version.
ID:	364404   Click image for larger version.
ID:	364405   Click image for larger version.
  8. #288
    Jul 2015
    Default Sk series 350w 12v modular inverter
    MODULAR INVERTERS SK SERIES 350W 12V-FROM:R569
    - 4 AC Plugs
    - USB Output
ID:	364414   Click image for larger version.
Name:	20140721_091751 (600 x 337).jpg
ID:	364415   Click image for larger version.
Name:	20140721_091802 (600 x 337).jpg
ID:	364416   Click image for larger version.
ID:	364417   Click image for larger version.
Name:	20140721_091842 (600 x 337).jpg
ID:	364418   Click image for larger version.
ID:	364419   Click image for larger version.
ID:	364420   Click image for larger version.
ID:	364422   Click image for larger version.
  9. #289
    Jul 2015
    Default 30amp 12v-24v solar charge controller
    30AMP 12V-24V SOLAR CHARGE CONTROLLER
    The 30A PWM Solar controller is for off-grid solar systems and control the charging and discharging of the battery.
    The intelligent charging process has been optimized for long battery life and improved system performance
    Major functions
    -Automatic identification system voltage, 12 volts/24 volts.
    - Humanized LCD displaying and double button operation of man-machine interface.
    - High efficiency intelligent PWM 3stage charging.
    - The load control mode can be selected; the timer function can be reset for street light at night.
    - Reliable over voltage protection: short circuit protection, over load protection, overcharge protection, over-discharge protection
    - Accurate temperature compensation, correcting the charging and discharging voltage automatically, improving the battery lifetime
    - Roundly reverse connected protection
    - Solar panels, battery, solar charge controller positive poles are all connected together, adopting negative MOSFET in series control circuit.
    FROM R560.00 EACH
ID:	364426   Click image for larger version.
ID:	364427   Click image for larger version.
Name:	BuyFast_Ecco_LD2420c_Solar_controller-4_1_59a908ad-f445-487a-9dd2-0734ae0af8b5.png
ID:	364428   Click image for larger version.
ID:	364429   Click image for larger version.
ID:	364430   Click image for larger version.
ID:	364431   Click image for larger version.
ID:	364432   Click image for larger version.
  10. #290
    Jul 2015
    Default 6 plate gas stove (white)
    6 Plate Gas Stove (White)-FROM:R2631
    6 Volcano Plus Burners
    Stainless Steel Cooking Surface
    Chromed Oven Shelf
    Oven Door Glass Viewer
    Intermediate Oven Glass
    Glass Lid
    Enameled Oven
    Oven Door With Intermediate Stop
    Rear Protector
    Storage Compartment
    Oven Capacity: 84 L
ID:	364439   Click image for larger version.
ID:	364440   Click image for larger version.
ID:	364441   Click image for larger version.
ID:	364442   Click image for larger version.
ID:	364443   Click image for larger version.
  11. #291
    Jul 2015
    Default 40amp 12v-24v solar charge controller
    40AMP 12V-24V SOLAR CHARGE CONTROLLER
    - Humanization LCD displaying
    - PWM 3stage charging
    - Load working mode is optional
    - Overall effective protection function
    - Charging current and discharging curren display
    - Load rationing setup
    FROM R711.00 EACH
ID:	364451   Click image for larger version.
ID:	364452   Click image for larger version.
ID:	364453   Click image for larger version.
ID:	364454   Click image for larger version.
ID:	364455   Click image for larger version.
ID:	364456   Click image for larger version.
  12. #292
    Jul 2015
    Default 2 plate gas burner
    2 PLATE GAS BURNER-FROM:R221
    - Gas stoves have a more even distribution of heat on the stove top
    - They are easier to gauge and adjust
    - Gas stoves use natural gas which is less expensive, abundantly available and clean burning
    - Gas stoves are less expensive to use than electric stoves
    - They cook food faster due to flames heating sides as well as the bottoms of the pans
    - Gas stoves are able to change temperatures rapidly
ID:	364458   Click image for larger version.
ID:	364459   Click image for larger version.
ID:	364460   Click image for larger version.
ID:	364462   Click image for larger version.
ID:	364463   Click image for larger version.
ID:	364464   Click image for larger version.
  13. #293
    Jul 2015
    Default 50amp 12v-24v solar charge controller
    50AMP 12V-24V SOLAR CHARGE CONTROLLER
    - Charging current and discharging current display
    FROM R742.00 EACH
ID:	364474   Click image for larger version.
ID:	364475   Click image for larger version.
ID:	364476   Click image for larger version.
ID:	364477   Click image for larger version.
ID:	364478   Click image for larger version.
ID:	364479   Click image for larger version.
ID:	364480   Click image for larger version.
  14. #294
    Jul 2015
    Default 300w 24v solar panels ecco
    300W 24V SOLAR PANELS ECCO
    - Hail Impact Test
    - Salt Mist Test
    - Reverse Polarity
    FROM 2650.00 EACH
ID:	364500   Click image for larger version.
ID:	364501   Click image for larger version.
ID:	364502   Click image for larger version.
ID:	364503   Click image for larger version.
ID:	364504   Click image for larger version.
ID:	364505   Click image for larger version.
  15. #295
    Jul 2015
    Default 5.5kw diesel-single phase generator
    ECCO 5KW DC7000D DIESEL GENERATOR-FROM:R12500
    Specifications
    - Single Phase
    - Silent
    - 4-Stroke Diesel Engine
    - Single Cylinder
    - Direct Fuel Injection
    - AC and DC Output
    - Low Oil Alarm System
    - Rated Power: 5.0kw.
    - Max Power: 5.5kw.
    - Frequency: 50Hz.
    - Forced Air Cooled System.
    - Electronic Starter.
ID:	364486   Click image for larger version.
ID:	364487   Click image for larger version.
ID:	364488   Click image for larger version.
ID:	364489   Click image for larger version.
ID:	364490   Click image for larger version.
ID:	364491   Click image for larger version.
ID:	364492   Click image for larger version.
ID:	364494   Click image for larger version.
  16. #296
    Jul 2015
    Default 240w 24v solar panels ecco
    240W 24V SOLAR PANELS ECCO
    - Hail Impact Test
    - Salt Mist Test
    - Reverse Polarity
    FROM R3308.00 EACH
ID:	364507   Click image for larger version.
ID:	364508   Click image for larger version.
ID:	364509   Click image for larger version.
ID:	364510   Click image for larger version.
ID:	364511   Click image for larger version.
ID:	364512   Click image for larger version.
  17. #297
    Jul 2015
    Default 200w 24v solar panels ecco
    200W 24V SOLAR PANELS ECCO
    - Hail Impact Test
    - Salt Mist Test
    - Reverse Polarity
    FROM R2416.00 EACH
ID:	364515   Click image for larger version.
ID:	364516   Click image for larger version.
ID:	364517   Click image for larger version.
ID:	364518   Click image for larger version.
ID:	364519   Click image for larger version.
ID:	364520   Click image for larger version.
  18. #298
    Almelo, Overijssel
    Quote Originally Posted by SA Energy Group View Post
    Not sure I'm allowed to do this, but why don't you maybe respond to the posts here? Seems like a lot of people are questioning the specs and performance of Ecco panels.
    http://www.4x4community.co.za/forum/...d.php?t=229366
  19. #299
    Jul 2015
    Default 200w 12v solar panels ecco
    200W 12V SOLAR PANELS ECCO
    - Hail Impact Test
    - Salt Mist Test
    - Reverse Polarity
    FROM R2,318.00 EACH
ID:	364524   Click image for larger version.
ID:	364525   Click image for larger version.
ID:	364526   Click image for larger version.
ID:	364527   Click image for larger version.
ID:	364528   Click image for larger version.
ID:	364529   Click image for larger version.
  20. #300
    Jul 2015
    Default 105ah 12v tubular flooded discover battery
    105AH 12V Discover Tubular Flooded Battery-FROM:R2450
    - Maintenance Free
    - Traction heavy duty grid design gives consistent active material adhesion and corrosion resistance
    - High impact reinforced co-polymer and polypropylene cases
    - Compatible with sensitive electronic equipment
ID:	364540   Click image for larger version.
ID:	364541   Click image for larger version.
ID:	364542   Click image for larger version.
ID:	364543   Click image for larger version.
ID:	364544   Click image for larger version.
  1. WP 4WD Events whatsapp group (27 members currently)
    By James-Black in forum Western Cape
    Last Post: 2015/03/23, 06:39 AM
  2. 4x4 East London Group outing -Gubu Report 04/10/14
    By hunter26 in forum Eastern Cape
    Last Post: 2014/10/11, 11:08 AM
  3. Replies: 970
    Last Post: 2012/06/10, 08:45 PM
  4. Prolong
    By henlo in forum Jeep
    Last Post: 2007/06/06, 11:59 AM
