Results 1 to 16 of 16
    Jan 2007
    Default Cleaning water tank on trailer
    Hi all
    Any ideas on how to clean the water tank fixed to my Echo 4 without removing the thing ? What do you guys do ?
    I do empty it out after camping but it allways has bit of water left in .........
    Thx
    4ePajero Guest
    I would not empty it, but rather fill it with water. (Deprive growth of oxygen)
    Add salt and bleach.
    Empty and re-fill before you go on the next trip.
    Skipfari Guest
    Hi Jas.
    Get Cellor liquid from Cosave hardware. Pour 1L of cellor Liquid with 50L of water. Let it stand overnight. Drain and rinse tank/system.
    Alternative is Chlorwash F. Use one cup of powder on 50L of water. Pour in tank, drain and rinse.
    Chlorwash F is expensive (but very good - dairy farmers use it to clean their equipment from algea and bacteria.
    Regards.
    Wilgeheuwel, JHB
    Thanked: 22
    Mine stands empty with the filler cap off and tap open - cover these with a stocking to keep dirt out. It stands in the sun and the tank eventually dries out. A few days before use, fill it up with water and put two caps of Jik and let it stand until the day before you leave. Then drain for one night and fill with your drinking water the next morning. So far, so good - haven't had the gyppos yet and it tastes fine.
    Steve
    Callsign and forum ID: ZR6SGN
    YouTube channel: https://www.youtube.com/user/SteveNuns
    How many is a brazillian?
    Pampoenkraal, naby Dwarskersbos
    Thanked: 812
    Johan Mitchell, .... r.i.v. Swambo Marthie
    My beste kennis is dié oor my eie onkunde
    '96 Colt DC V8 ... Safari Camper ... '88 Fleetline L
    '88 Ballade 150 ... sold
    "The rule here is that there is no rule" .. MikeAG
    Thanked: 906
    JAS
    The solution is to camp more often!!
    CATs
    2003 Safari Xplorer
    Nelspruit and Cape Town
    Thanked: 111
    I agree with JohnDough. Miltons is the way to go.
    Jul 2007
    Vishoek
    Post
    I need to clean the whole water system (including geyser) on my Explorer! Would Miltons not harm the system / geyser?
    Thanked: 111
    Quote Originally Posted by Bullet View Post
    I don't know, but I think if Miltons is effective enough to kill all sorts of goggos, but safe enough to not make babies sick, then it should be ok to put through your geyser.
    Jul 2007
    Vishoek
    Post
    Thanx Eben, makes sense to me but as i am not a very mechanically orientated person, rather check than be sorry!
    4ePajero Guest
    Miltons is a mixture of
    • water,
    • table salt
    • household bleach.
    (Check the bottle)
    Thanked: 111
    • water,
    • table salt
    • household bleach.
    (Check the bottle)
    Is there someone on these forums with enough knowledge of chemicals and chemical processes who can give us a "recipe" for mixing up our own version of Miltons?
    Normally, I'd experiment until I got it right, but we're talking about drinking water here and I'm not overly keen on going to hospital with chlorine poisoning each time I get it wrong.
    4ePajero Guest
    Quote Originally Posted by Eben View Post
    From this web site:
    If Miltons solution is not available use
    commercially available concentrated chlorine
    (household bleach) which has 4% available
    chlorine for example White King. Add 6.25mls
    (1 teaspoon) of household bleach to 2 litres of
    cold water.
    Apr 2008
    Table View Cape Town
    Thanked: 8
    I used 2 caps of Miltons once in my Explorer. I could not get that taste out of the tank. Even after rinsing about 20 times. I eventually put a little bottle of vanilla essence in the tank with a tank of water. I left it for 2 weeks, rinsed. Now I just drain and leave open between camps.
    Eric
    2017 Discovery Sport SE
    2011 Discovery 4 V8 HSE
    2016 Audi A1 Sportback (Sold)
    2012 Range Rover Evoque (Sold)
    2009 Defender SVX 60th Limited (Sold)
    1997 Discovery V8 ES (Sold)
    2009 Freelander 2 TD4 (Sold)
    2012 Spite Tourer SP
    2010 Jugens XT140 (Sold)
    2008 Jugens Xplorer (Sold)
    Jul 2007
    Vishoek
    Post
    Excuse my ignorance again!
    Got hold of a bottle of Milton fluid and the reverse states that content not to be used on metallic surfaces or objects. The water tanks in my van are plastic, but the geyser and piping is all metal! Some more advice please?
    Ladismith western cape
    I'm also not an expert when it comes to chemicles however I see it as follows.
    In the factory where I work we use caustic soda, citric acid and nitric acid to cleen the tanks and pipe work.
    The general rule is, the longer the wash chemicle is exposed to the material the more it will do the job of cleaning.
    Most cleaning chemicles are corrosive to metalic material.
    The trick is to the lenght of time and the temperature of the chemicle beeing used. In other words the longer you leave the chemicle in the pipe the more it will corrode the pipe.
    Milton fluid will be corrosive if left for too long in the pipes. The producers will put this warning onto the box to protect themselves against this.
    In other words it will be safe to use if you wash and then rince with water. If you wash and leave the product in the pipes then it will corrode the pipes.
  1. Water purification
    By A.J. in forum Camping, Fridges, Accessories
    Last Post: 2020/06/15, 06:05 PM
  2. water tank
    By Christo Davids in forum Camping, Fridges, Accessories
    Last Post: 2011/11/17, 07:05 PM
  3. Fuel Tank (Aftermarket) Excel
    By Tabatwa in forum Vehicle & Technical Chat - General
    Last Post: 2011/08/11, 06:58 PM
  4. water purification
    By Elders in forum Camping, Fridges, Accessories
    Last Post: 2011/02/02, 07:05 AM
  5. Explorer - Water Tank Key
    By JohanJvV in forum Camping, Fridges, Accessories
    Last Post: 2011/01/16, 01:05 PM
