Lifting a standard caravan
Results 1 to 10 of 10
    Oct 2008
    Pretoria East
    Thanked: 44
    Default Lifting a standard caravan
    Hi all,
    I grew up camping in tents, we used a caravan once when I was still at school, those days there was no tar road to Sodwana, and it took my dad's Datsun Safari 3 hours to get the caravan through the flooded gravel and sand road from Josini to Soddies... Two weeks after returning home the caravan was sold.
    So now with the kids still too young and under swambo's demands I buckled and the purchase of a used Gypsey Regal Blue Series went ahead.
    The caravan is perfect, except that it is waaaay to low in my opinion.
    I searched the forum and only came up with this thread about lifting a standard road going caravan:
    http://www.4x4community.co.za/forum/...d.php?t=109337
    Afterwards I spoke with the workshop manager at the caravan dealership, and they sell and install 30mm spacers.
    After crawling under our recently acquired van I established that I already have 30mm spacers fitted.
    It also came with 14 inch "bakkie" crossply tyres, and it has a Rubax type axle .
    Does anyone know what the costs would be to replace the rubbers in the axle? Or would you rather add an additional spacer , or fit a 50mm channel to increase the lift?
    The reason behind the lift query is not to do off-road trails or travel baboons pass.
    I just want to ensure that I have enough ground clearance to tackle a "standard " gravel road or a sand track in a camp site where the middleman is high...?
    2009 Toyota Hilux 4.0 V6 Raider D/C AT
    Sep 2012
    North West
    Thanked: 15
    No idea what it will cost. Keep in mind that the shakes on gravel roads is NOT the friend of a road van.
    Bossies toe!!!
    Work : Toyota LC HZJ76
    Home : Trailblazer 2.8 4X4 LTZ
    SWAMBO: Toyota Avanza - Gone
    Conqueror Commander
    Google know too much.
    Thanked: 1153
    Quote Originally Posted by Harry OpieTremspoor View Post
    There is much more to it than merely raising the body. The strengthening of the chassis and body is another story. If you want to do it properly it is an expensive exercise. Just the latches to keep the inside doors closed came to R1050. You pay motorhome prices for silly little things.
    Stellenryk, Bellville
    Thanked: 296
    If you do not intend strengthening the chassis, frame, cupboards, etc, you should stay away from gravel roads - travelling a short gravel at slow speed to reach a campsite is fine but no extended gravel road trips unless the aforementioned had been done.
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
    Thanked: 14217
    Two options:
    - Sell the Gypsey Regal and buy a proper offroad caravan
    - buy an old Jurgens or Sprite that had leaf springs and strengthen as per Poen's advice: new subframe, external roll-cage, longer shackles and shocks, etc
    Thanked: 59
    I went through this whole exercise in NOV '14, for our 5 Country tour in DEC '14. It was on a 1992 Caravette 6. Lifted it 75mm in total (Mix of larger wheels and a new subframe).
    Don't bother with "Fixing" the Rubax. When I did mine I had multiple discussions with ALKO, and the short of it is, if it's not inverted yet, then it's still fine. And it's almost cheaper to buy a new AXLE than have the old one refurbished.
    Then, to strengthen the interior, I bought normal residential fittings from places like Gelmar and Easy Life Kitchens. Caravan and Camper shops ask a hefty premuim for the same stuff.
    Rangeview Krugersdorp
    Thanked: 1296
    Sadly the bodywork is not built to go off road. Put together with short staples and hope.
    Ford Figo 2016
    Jun 2012
    Gordons Bay
    Thanked: 14
    Quote Originally Posted by Andre N View Post
    Do you have any pics of your conversion?
    Ford Ranger 3.2 M/T D/C 4x2 (Pavement Parking in style since July 2012)
    Thanked: 2224
    That is the reason it would remain a gravel roader. The older caravans have the better structures and if one can find a pre vacubond one that is 1st prize.
    On those models one could remove the outer panel and rebuild all the wood inside and while the panel is off it new wiring and polystyrene insulation.
    The internal furniture also becomes a part of the structure and wit a bit of beefing in the right areas the end result can be quite rugged.
    The axle is the main point a this has to absorb the extra high frequency bounce from corrugations and rough road. This tends to cause quite a lot of heat in the rubax systems and is the reason why I opt for a standard leafspring axle with shocks
    Another point of high load and stress is the cupboard doors, they often have compartments built in to the door enabling one to pack stuff in there as well, nice idea but this increases the weight of an already heavy door for the size of hinges and fixing screws for it. Easy to overcome by removing the door and replacing it with rip stop and velcro
ID:	354838   Click image for larger version.
ID:	354839   Click image for larger version.
ID:	354840   Click image for larger version.
ID:	354841   Click image for larger version.
ID:	354842   Click image for larger version.
ID:	354843   Click image for larger version.
ID:	354844   Click image for larger version.
ID:	354846   Click image for larger version.
ID:	354847   Click image for larger version.
    Henk
    Follow us on Facebook
    Oct 2008
    Pretoria East
    Thanked: 44
    Thanks for the advice so far.
    That scout looks like a very nice alternative to a trailer setup.
    For now I think I'll stick to the black top with the van, and rather just take the tents for extended gravel road trips.
  1. Which off road caravan or off road trailer is the best?
    Last Post: 2017/10/06, 10:54 AM
  2. converting a standard caravan to an off-road caravan
    By ralton in forum Camping, Fridges, Accessories
    Last Post: 2017/09/08, 04:07 PM
  3. Buying a caravan
    By avk in forum General 4x4 Discussion
    Last Post: 2011/03/16, 10:24 PM
  4. Lost the caravan
    By Madota in forum The 4x4 Pub
    Last Post: 2010/10/04, 09:34 AM
  5. Electrical problem in Caravan
    By Jeep001 in forum Camping, Fridges, Accessories
    Last Post: 2010/01/06, 09:02 AM
