EGT installed on ML 270cdi
Results 1 to 9 of 9
    Default EGT installed on ML 270cdi
    I have installed a VDO Viewline Onyx 1650F Pyro EGT gauge in my 2002 Mercedes Ml 270cdi
Name:	EGT probe 1d.jpg
ID:	353899   Click image for larger version.
Name:	EGT probe 2d.jpg
ID:	353900   Click image for larger version.
Name:	EGT probe 3ad.jpg
ID:	353901   Click image for larger version.
Name:	EGT probe 4ad.jpg
ID:	353902   Click image for larger version.
Name:	EGT gauge 1d.jpg
ID:	353903   Click image for larger version.
Name:	EGT gauge 2d.jpg
ID:	353904   Click image for larger version.
Name:	EGT gauge 3d.jpg
ID:	353905   Click image for larger version.
Name:	EGT gauge 4d.jpg
    edenvale
    Thanked: 202
    cool job
    please post up idle / cruise and wot values
    What is wot values?
    The gauge is in Fahrenheit.
    In cruise it varies between 750F-1050F (400C-565C)
    At idle it is about 450F (230C)
    The max I got so far driving hard up Hans Strydom is 1580F (860C)
    edenvale
    Thanked: 202
    wot = wide open throttles
    Thanked: 2252
    very nicely done. I also like the neat copper nuts on the manifold and the shiny new turbo.
    Story behind the new bits?
    Long story for the new shiny turbo and new gasket, but in short the following:
    Since I bought the car in 2007 the turbo was never 100%. Eventually find faulty/leaking actuator on turbo. Garrett or Merc does not sell actuator seperate from turbo but I managed to get another actuator fitted by some company. The car was much better, but still not 100% since the actuator should actaully be set on a flow bench machine and computer in order to set some minimum vane position for the turbo to work at optimum. This was done about 3 years ago.
    I planned on fitting an EGT gauge last year, and during inspection of my exhaust manifold to look where I was going to fit the egt probe, I saw that my turbo and gasket was now leaking exhaust gas. (pictures attached)
    I could have got my turbo serviced for about R2500 but the actuator would still not be perfect and also the turbo has already done 310000km. So I decided to buy a brand new turbo from Garrett and I replaced my exhaust gasket as well as my turbo. While the exhaust gasket was removed I got someone to come and drill and tap the manifold and attached the egt probe "bracket/nut"
    While I was at it I also replace my airbox and the air pipe between airbox and turbo. (Previous airbox was somehow letting some dirt in on wrong side of airfilter)
    I also bought heat shielding self adhesive material made from crushed lava which could withstand 2200 Fahrenheit and put that on my turbo heatshield as well as airbox in order to keep my intake air cooler.
    I flushed and cleaned my intercooler before I replaced my turbo and now everything is running smoothly
Name:	Old gasket1.jpg
ID:	353950   Click image for larger version.
Name:	Old gasket 2.jpg
ID:	353951   Click image for larger version.
Name:	Old turbo 1.jpg
ID:	353952   Click image for larger version.
Name:	Intercooler removal.jpg
ID:	353953   Click image for larger version.
Name:	Intercooler cleaning 1.jpg
ID:	353954   Click image for larger version.
Name:	Intercooler cleaning 2.jpg
ID:	353955   Click image for larger version.
Name:	New turbo 10.jpg
ID:	353956   Click image for larger version.
Name:	New turbo 11.jpg
Name:	Engine bay 2.jpg
    Forgot to add the pics about the heat shielding material on the airbox and turbo shield.
ID:	353959   Click image for larger version.
ID:	353960   Click image for larger version.
ID:	353961   Click image for larger version.
Name:	Turbo shield 1.jpg
ID:	353962   Click image for larger version.
Name:	Turbo shield 2.jpg
    Thanked: 2252
  1. EGT gauge on a 2.8D Hilux
    By Ouarzazate in forum Toyota
    Last Post: 2017/08/29, 09:38 AM
  2. Safe EGT
    By Christo Davids in forum Vehicle & Technical Chat - General
    Last Post: 2010/01/11, 06:18 PM
  3. EGT and Others
    Last Post: 2009/12/29, 10:11 PM
  4. EGT Gauges for Land Rovers
    By Dirk in forum Land Rover
    Last Post: 2007/05/29, 04:19 PM
  5. EGT gauge installed.
    By Lofty in forum Ford & Mazda
    Last Post: 2007/03/21, 09:08 PM
