Page 2 of 2 FirstFirst 1 2
Results 21 to 36 of 36
  1. #21
    Durbanville, Cape Town
    Thanked: 33
    Matty, Pushing the button kills SC, but TC is always active. Only way to kill TC is by pulling the ABS relay.
    Or switching on the Diff lock in low range. 😂😂
    '19 Mitsubishi Triton Athlete
    '23 Bush Lapa Miskruier BL3344
  2. #22
    Apr 2011
    JHB
    Thanked: 105
    Thanks Roelf and Karel, got it!
  3. #23
    Lebanon
    I read somewhere on the internet that some guys managed to find the ABS/TC? cable (colored black and blue) connected to the ECU which is located after the gear shift area below the Radio. Intercepted the cable with an on/off switch which they claim that in the off position all three (ASC, TC and ABS) will be disabled. For the reenabling process, one has to turn the engine off, turn the new switch on, and then turn the engine back on, where the system is rescanned and should enable all three again.
    I haven't tried this on my NS, so I can't confirm the above.
    2008 Gen 4 petrol 3.8 silver LWB
  4. #24
    St Albans
    Thanked: 1195
    Quote Originally Posted by Joseph-ahd View Post
    Why would you need to switch these features off?
  5. #25
    Barberton
    Thanked: 7497
    There is a (false?)perception out there that TC holds you back.
    I have been up dunes, up axle twisting mountains, tested it under "racing" conditions and have never experienced TC holding me back - quite the opposite.
    ASC will most definitely hold you back up a steep dune.
  6. #26
    Lebanon
    Quote Originally Posted by KurtG View Post
    I'm just sharing what I know about pajero TC disabling, since this option is for some reason available in other 4x4s, and not in gen 4 pajero as RoelfleRoux mentioned earlier.
    I guess one would want to switch traction control off in case it does interfere with engine power when momentum is needed.
  7. #27
    Barberton
    Thanked: 7497
    I think Kurt's question could have been tongue in cheek. Almost like asking why carry a toolbox in a Pajero.
    PS: Spare cable ties: yes
  8. #28
    Teen die Berg langs die See
    Thanked: 308
    My Sport is a GLS but that also means in the case of the Sport it has Rear DL not TC. I engage RDL...aim....and shoot! I just love it!
  9. #29
    St Albans
    Thanked: 1195
    Hi Roelf, you are partly right. I asked because I have never in any circumstances be they onroad, offroad on a trail, in sand dunes etc. needed to change any of the standard settings. When in High Range (4HLc), you can switch off ASC with a button on the dash, and TC is not normally required because your speed is high enough (momentum) but can become useful. In Low Range (4LLc), ASC is switched off anyway and the TC is useful for grip. In addition, when in Low Range and you are using the TC too much the car will eventually spin through it and allow you to kick dust in the air to your heart's content....
    My 2cw
  10. #30
    Jul 2015
    Keimoes
    Thanked: 13
    Guys please read my thread above and comment regarding what I am trying to achieve with front and rear lockers
  11. #31
    Barberton
    Thanked: 7497
    Hi Hoppi,
    Will do.
  12. #32
    Centurion, Pretoria, SA
    Thanked: 1101
    Default Re: Gen 4 Traction vs Diff Lock
    Well I just had to post a comment here. I have had my Gen 4 NS SWB for about 3 years now and was not happy with the TC and preferred the DL as fitted to my previous models. This weekend at Drie Berge I had the opportunity (and possibly the right mindset) to put the TC system to a fair test.
    Well by driving it correctly I found it quite impressive. If I come across a DL for my vehicle I would grab it but at least I am not as negative about TC as I was originally.
    Peter
    SOMETIMES I WAKE UP GRUMPY,
  13. The Following User Says Thank You to Sneaky Pete For This Useful Post:
  14. #33
    Dec 2019
    Strubensvalley
    Hi All,
    I am posting here as this is the closest thread to my current problem, maybe someone can help.
    I have a Gen4 2007 3.2 SWB. The Traction Control is engaging on even a mild pull off, straight or around a corner, going into limp mode for a couple of seconds.
    Diagnostics show error 14 RL SNSR OPEN. I have replaced the sensor but still the same issue.
    Any advise will help please.
    Andre
  15. #34
    Barberton
    Thanked: 7497
    Default Re: Gen 4 Traction Control vs Diff Lock
    Then one is tempted to think that there is a problem with the wiring to the sensor.
  16. #35
    Thanked: 727
    A silly question from my side, but you never know. Are the tyres all the same profile on your vehicle? If one is smaller or bigger it might also make the electronics confused I would think? Although your problem definately rather sounds electronic of nature.
    CATS
    2003 Safari Xplorer
  17. #36
    Darling
    Thanked: 15
    Quote Originally Posted by Andre Booysen View Post
    Hi All,
    Andre
    Info on the error code: https://www.pajeroclub.co.za/forum/viewtopic.php?t=2205
  1. Replies: 24
    Last Post: 2014/08/20, 10:55 AM
  2. Diff Lock Solenoid Motor
    By johannesbarwise in forum Mitsubishi
    Last Post: 2014/03/25, 12:10 AM
  3. Replies: 14
    Last Post: 2014/02/28, 09:01 AM
  4. Difflock trouble
    By Vaaljapie in forum Mitsubishi
    Last Post: 2012/08/26, 12:13 AM
  5. Diff lock or not
    By James B in forum Mitsubishi
    Last Post: 2011/08/24, 07:19 PM
