Jimny - Removing the cats - any difference? - Page 3
Results 41 to 60 of 61
    Pretoria Oos - Garsfontein
    Thanked: 148
    Default Re: Jimny - Removing the cats - any difference?
    So if you want to remove the cats, you have to ground the white wire going to the engine and all will be fine (on the M13 motor)?
    2015 Isuzu KB250 D/C 4x4 LE - Mine / 2009 Suzuki Grand Vitara 3.2l V6 Auto - Hers
  2. #42
    Jan 2015
    Thanked: 119
    Or fit a cat defouler
    2009 Zook Jimny Sport - with too many extras to mention
    True fuel consumption is shown as FuellyData+7.4%
    Build Thread: http://www.4x4community.co.za/forum/...ead?highlight=
  3. #43
    Thanked: 148
    Quote Originally Posted by Rivar View Post
    JA BUT...
    Who wants to buy a defouler if you can ma' sommer connect the wire...
  4. #44
    Jan 2015
    Thanked: 119
    True. Depends what you wanna do. Heard the wire trick doesn't always work.
    I would rather just get it chipped and add a turbo while I'm at it
  5. #45
    Randburg
    Flip I spoke to Wizerd already. Rivar the restrictive part of the catalytic converter is a honeycomb/coral-ish material that can be broken up and removed as far as I know so I might try that...hkgk
  6. #46
    Jan 2015
    Thanked: 119
    Quote Originally Posted by aa3smit View Post
    You will still have the problem with the sensor if you do nothing to it
  7. #47
    Apr 2008
    Thanked: 24
    I do cat removals on a daily basis we fit a cat fooler to each of them and never had come backs so far very simply screw it in and away you go.
    Daihatshu Terios LWB 4x4
    Branch and 50mm free flow
    45mm lift
    Winchbar
    KIA Sportage.....Retiredstripped for spares
    Fiat Uno platcar
  8. #48
    Jan 2015
    Thanked: 119
    Quote Originally Posted by segalmarisa View Post
    Agreed. Way to go
  9. #49
    Sep 2015
    Thanked: 159
    Not entirely related to this post, but might be.
    Three tanks of fuel ago I added 50ml, measured, of 2SO to a full tank.
    But even now, every now and then, there is a very noticeable sulphur smell from the exhaust.
    The undiluted 2SO also has a sulphur smell, but not as pronounced.
    Weird thing, I run my RC plane and weedeater 2stroke on the same 2SO, but MUCH higher concentration, and NO sulphur smell.
    Really would like to get to the bottom of this.
    Is it something the CAT does ?
    Jimny, the most underestimated 4x4xfar
  10. #50
    Jan 2015
    Thanked: 119
    Sometimes the cats to let off an odor that smells like sulphur, or plain english, eggs.
    Why are you putting 2SO into the tank?
  11. #51
    Sep 2015
    Thanked: 159
    Talking Re: Jimny - Removing the cats - any difference?
    Hi Rivar,
    Thanks for the reply.
    Many years ago I attended a comp in OZ, and we drove in a Pajero that could switch between LPG, or petrol.
    A few days later, we had problems with the engine.
    Long story short, running on LPG "dries" out the mechanics in the carb, and the local mechie said to start and end the day on petrol, and to add 500mL of 2SO to a full tank of petrol, for the lean times.
    Never had problems for the rest of the time.
    So I figured, why not on a new vehicle, considering I had to replace the carb on a previous vehicle, where the mechie said, "you should have run some 2SO every tank now and then, for lube"
    And that was a number of years back.
    So my theory is, and only mine, that maybe the 2SO will coat metal surfaces with a thin layer of oil, and get into those mechanical movement areas present in most fuel systems.
    Heck, if 2SO can lube a high revving 2 stroke, it can only help in a 4 stroke.
    And if it doesn't bung up the CAT, so what ?
    That is why
  12. #52
    May 2008
    Thanked: 304
    'Cause he loves the smell of rotten eggs once in a while
    Flip
    Awesome: Suzuki Jimny;
  13. #53
    Jan 2015
    Thanked: 119
    Quote Originally Posted by Gustav Jimny View Post
    Hi Rivar,
    That is why
    Interesting.
    Thanks for the feedback
  14. #54
    Nov 2017
    Gauteng
    Thanked: 21
    I bought a 2011 Jimny on the 19th Of July .
    I replaced the factory exhaust with a 54mm Powerflow pipe and 2 free flow boxes . The cat that is inside the manifold is still there. Sounds beefier , but honestly dont notice any difference at all .
    However , i wasnt going for big power , just something that sounds fun when Im in the dunes giving it some horns .
    2011 Suzuki Jimny . 40mm zombie offroad lift , 215/75/15 tyres, 50mm powerflow .
    Disco 2 Td5, 3 inch lift, straight pipe, remap, egr delete, cdl mod, 32/11.5/15 all terrains. ( Sold )
    1985 Suzuki Sj410 , 970cc of stock Japanese power , 245/75/15 muddies , 2 inch lift . ( Sold )
    2016 Harley iron 883 , lowered , tank lift , wire tuck , fender delete, flipped mirrors , straight pipes . ( Sold )
    Various Volvo company cars over the last 6 years .
    2001 Polo Playa Millenium , stock besides 75hp nitrous shot. ( Sold )
    1987 Caddy , 2.1 16v Abf , 44mm throttles , 288 billet cams , 11.5 :1 compression. ( Sold )
    1981 Mk1 Golf , 1900cc , weber 38 dgas , 298 cam , tnt branch , 11.5 : 1 compression . ( Sold )
  15. #55
    Apr 2018
    Thanked: 14
    Hi Segal,
    Reviving an old one here, hoping you can help with some info or opinion?
    The Situation:
    I did a de-cat on my 2015 Jimny at a CT shop in December. Since they day it was installed the engine light has been coming on and off (mostly on), and when it occasionally goes off I have very sluggish response between 2500-3200 RPM.
    I have been back to that shop three times to get it fixed - the first time they said it was an engine problem that the Suzuki needed to fix, Suzuki said it as the other shops fault and to take it back. I took it back, the shop replaced it and re-set the error messages. A day later we were back in the same situation, I took it back to the shop, they said it's not their problem, take it to Suzuki.
    The Symptoms:
    • Engine light is almost always on
    • Feels like a gigantic AirCon is being turned on between +/- 2500-3100 RPM - huge power drop
    Wether the problem is the Cat Fooler or not, all these problems didn't exist until the day it was installed. Any ideas on how to solve this Both the shop and Suzuki blame the other.
    MUCH appreciated!
    Suzuki Jimny (2015)
  16. #56
    Apr 2008
    Thanked: 24
    Quote Originally Posted by jonnyr View Post
    Hi Segal,
    The Situation:
    The Symptoms:
    MUCH appreciated!
    Hi there. What does the diagnostic tool say when the shop run the obd?
    45mm lift
    Winchbar
    Fiat Uno platcar
  17. #57
    Apr 2018
    Thanked: 14
    Ok, went back to the dealership, they are 100% confident it's the O2 sensor that needs replacing. They say every 60000kms or so it should be replaced, we're currently on 54k.
    Replacement is happening next week with Suzuki, will update on the effects.
    Bloody expensive little gadget.
    Suzuki Jimny (2015)
  18. #58
    Thanked: 1673
    First time I hear that a O2 sensor needs to be replaced at 60 000km 🤔
    Sent from my iPhone
  19. The Following User Says Thank You to Rebel 4x4 For This Useful Post:
  20. #59
    Mar 2019
    Hey Jonnyr, did replacing the o2 sensor sort you out?
    ___________________
    Suzuki Jim 2010
    ___________________
  21. #60
    Jan 2007
    Thanked: 339
    Quote Originally Posted by DEATHWOBBLE86 View Post
    Go to Wild 4x4 they know how to fix it
    Vic
  1. Jimny Disc pad replacement
    By dewets in forum Suzuki
    Last Post: 2014/11/28, 01:28 PM
  2. Replies: 72
    Last Post: 2014/07/23, 08:29 AM
  3. Discovery 2: Removing cats & O2 sensor
    By Gwone in forum Land Rover
    Last Post: 2012/04/03, 07:00 PM
  4. First road trip with Jimny
    By Nys in forum Suzuki
    Last Post: 2011/05/17, 09:42 AM
  5. Jimny goes to Tiffendell
    By Sawdust in forum Suzuki
    Last Post: 2009/08/20, 02:52 PM
