Results 1 to 20 of 33
    Mar 2015
    Default Solar charge controller connected whilst alternator charging
    Hi all,
    I wired my dad's solar charge controller directly to his spare battery, we also added a brad Harris plug for connecting the solar panel when he is stopped and setting up camp.
    The question I now have is, is it ok to leave the controller connected to the battery when it is being charged via the car running? If I remember correctly it is only a problem if both the car and the solar panel are charging the battery at the same time? Alternatively should I install a switch to switch the controller on and off manually?
    The controller is a CML-v2 from photos if that helps.
    Thanks,
    Nick
    Hillcrest
    Thanked: 8516
    Quote Originally Posted by nicksimp08 View Post
    Hi all,
    Thanks,
    Nick
    I don't see any photos.
    YES YES YES I KNOW
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
    Mar 2015
    YES YES YES I KNOW
    Hi fluffy, photos is the brand
    Photos like photons rather than photos like images
    Hillcrest
    Thanked: 8516
    Yep
    see the YES YES YES I KNOW part of my post
    3 Land Rover V8's
    Apr 2011
    Thanked: 17
    You can use a relay to make life a lot easier - and you won't have to remember flicking switches...
    Hi all,
    Thanks,
    Nick
    Mar 2015
    Yep
    Ah, I thought it may have been part of your signature
    Quote Originally Posted by Antonf View Post
    Could you advise where one would wire this in?
    Is it a problem to have the controller permanently connected though whilst driving? (without the solar panel)
    Mar 2015
    I see in this resource they say it shouldn't be a problem:
    http://forum.solar-electric.com/foru...ller-or-panels
    I would however prefer to hear it from someone on the forum as well
    They also mention that you can have the panel and alternator connected at the same time? I was under the impression that this could damage either the panel or the controller?
    Jul 2010
    Pinetown
    Thanked: 2613
    I have the solar controller connected to the aux. batteries in the back permanently for years. Brad Harrison connector for connecting the panel when in camp if needed. With a split charge solenoid to the alternator for charging while driving. No problem with it at all, though I have never had the solar panel charging while driving so not sure about simultaneous charging ....
    Peter Hutchison
    Platkar = Chevy Spark 1.2
    Mar 2015
    Thanks all, you have put my mind at rest
    Thanked: 553
    It is perfectly OK to leave the controller in circuit permanently.
    You do not need a relay.
    That Photos controller is probably a Phocos?
    Now you can relax some more.
    Eggie.
    "Do not go where the path may lead, go instead where there is no path and leave a trail."
    - Ralph Waldo Emerson.
  11. The Following User Says Thank You to Eggie For This Useful Post:
    Apr 2019
    Default Re: Solar charge controller connected whilst alternator charging
    I'm going to necro this post, apologies
    To to get it right, i have a solar charge controller connected to my batteries, i can connect my panels to this controller (Brad Harris), however when the panels are not connected i could connect the same connection to the alternator?
    EDIT:
    30A generic controller
    Thanked: 1027
    Quote Originally Posted by scabs View Post
    EDIT:
    Maybe explain a little better? More detail?
    I found myself at a loss as to what you're trying to say.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    Apr 2019
    Apologies, details as follows:
    In my trailer i have 2x105ah batteries, these can either be charged via 220v or solar. For solar charging, i have a 30A generic solar charge controller connected to the batteries. I connect the panels to the charge controller using a Brad Harris connector.
    My questions is, can i use my alternator to charge the batteries via the solar change controller if i connect it to the Brad Harris connectors?
    I hope that is clearer.
  15. #14
    Garsfontein
    Thanked: 2318
    No. You cannot connect your alternator to the PV inputs on your solar charge controller.
    I presume you have a setup for AC220V in, and PV (solar panel) in. What you could do is add a second Brad Harrison connector directly to the battery (fused, on + as close to the battery as possible) and charge the batteries from the alternator via that.
    Ian de Villiers
    Nissan Patrol GRX 4.5
  16. The Following 2 Users Say Thank You to iandvl For This Useful Post:
  17. #15
    Polokwane
    Thanked: 944
    Like Ian said, bypass the controller, connect straight from the vehicle's battery to the trailer batteries. 16 sqr mm cable is the go to size.
    Conqueror Courage 2016
  18. #16
    Thanked: 236
    Ian The part in bold is what I am referring to
    If the solar charge controller is for a "12 v" solar panel - so the charge controllers range could be from 12 v to say 20 v from the panel
    If the alternator's voltage is around the 14 v mark - then in theory the solar charge controller will handle the alternator as an input
    or am I just being doff
  19. #17
    Garsfontein
    Thanked: 2318
    Theoretically, it seems to make sense. But it will not work.
    Solar panel voltage is not 12V. For a 12V system (meaning 12V on the battery side - not on the solar input side), the voltage from the panels will probably be between 18V and 22V. I believe that the input voltage from the PV has to be (at minimum) between 4V and 5V higher than the battery voltage before the charge controller will start charging the battery.
    Ian de Villiers
  20. The Following 2 Users Say Thank You to iandvl For This Useful Post:
  21. #18
    Thanked: 1027
    I agree with Ian
    Alternators put out 13,8-14.5V at the most. For this reason it will not work if the specific solar regulator was so designed.
    It may however be that some regulators are different.
    The cheaper PWM types for example is nothing more than just a switch which will connect the alternator and the batteries directly. Then that 5V above battery voltage may not be applicable which I suspect is only the case with your MPPT types.
    I stand to be corrected by the clever guys
    Nico Swart
    ZS6NJS
  22. #19
    Garsfontein
    Thanked: 2318
    I agree with Ian
    I've got a Victron MPPT in the camping setup and some other cheap PWM type thing at home. I think I'll give this a test. Maybe it works...
    Ian de Villiers
  23. #20
    Thanked: 1027
    Scabs is happy to refund you if something pops/blows
    Seriously, I'm sure they'll both be fine and this will be excellent to know the results.
    Nico Swart
    ZS6NJS
  1. Bush lapa miskruier review
    By Jaco Kruger in forum Trailers, Caravans, Towing etc
    Last Post: 2021/07/29, 05:00 AM
  2. Batteries - General Info
    Last Post: 2019/03/09, 06:39 AM
  3. Cheapest way to charge deep cycle with solar.
    By constantlm in forum Alternative Energy Solutions
    Last Post: 2015/04/26, 03:57 PM
  4. buying solar charge set up or build from scratch
    By hunter26 in forum Camping, Fridges, Accessories
    Last Post: 2013/02/28, 09:20 PM
  5. Charging aux battery whilst still connected in vehicle
    By Numbnut in forum Camping, Fridges, Accessories
    Last Post: 2012/04/22, 11:19 PM
