Freelander won't start!!
Results 1 to 20 of 31
    Dec 2014
    Default Freelander won't start!!
    Hi Guys
    I really need your help. I bought a 2nd hand Freelander 2 TD4 SE. I have had it for about 2 weeks. This morning when I went to take my daughter to school it would not start. It does a systems check and all seems fine but just won't start!
    Has anybody else had a similar problem? What could be the cause? I am currently waiting for the AA guy to arrive, but they also not very useful.
    Would really appreciate some assistance.
    Andrew
    Toyota Fortuner 4x4
    Jurgens XT140
    "Don't make a decision in the dark that was inspired in the light"
    Thanked: 94
    Hi Andrew.
    Does it swing or does nothing happen when you try it?
    2009 Defender 110 puma SW
    2011 Freelander 2 SD4 (Swambo)
    1999 Defender 90 2.8i
    1966 Series 2a 88'' 2.25 petrol - ALFIE
    Ex:
    2010 Discovery 4 V8
    2007 Discovery 3 V8
    2008 Defender puma 110
    2003 Discovery 2 td5
    2000 Defender td5
    Dec 2014
    Quote Originally Posted by Champ View Post
    Hi Andrew.
    It did nothing. But the AA have been and we put a battery charger on and it started. He suggested that the earth from the battery to the car could be faulty?
    Will take it in to the shop to let them run diagnostics to make sure.
    Andrew
    Toyota Fortuner 4x4
    Jurgens XT140
    Forest Hills, KZN
    Thanked: 873
    I had this one morning, but it didn't happen again. There are some known issues as discussed on the freel2.com forum in the UK.
    http://lmgtfy.com/?q=site%3A+freel2....2+not+starting
    Let us know how it goes.
    2003 LR Discovery 2 Td5 ES - Lots of Mods(check thread) - [Husky]
    Apr 2011
    Thanked: 1057
    Flat battery. Esp, since it is winter. Did the car stand outside?
    It usually does the check but then just "click, click". When the battery is flat it will not run the starter at all, so it wont "swing".
    Thanked: 543
    Thats battery.had it with 2 of my previous preowned cars and both within a month of purchase.
    Thanked: 14259
    Had the same on the Wrangler 2 weeks ago with the first really cold snap.
    Dead as the dodo.
    The new ECU's just refuse to do anything if the voltage is too low.
    New battery, all sorted.
    Thanked: 201
    Our FL did that a while ago.
    New battery and all is sorted.
    Battery required is 80Mah. Old one was only 66Mah!
    Si vis pacem, para bellum
    Aug 2010
    Thanked: 117
    First general modification.for a Freelander 2 is to run an extra earth cable to the starter or close. That cable is now standard in later models and well discussed on the freelander forum
    Freelander 2 i6 SE - loveeee iitttttt!
    650 V Strom - my trusty beast
    Honda XR400R - wanna play......
    Vespa - when you just have to be cool 8)
    GT Expert and Giant Anthen MTB's - keeping the tummy in check
    Apr 2011
    Thanked: 1057
    Quote Originally Posted by mountainboy1974 View Post
    Standard since which MY?
    Dec 2014
    and I'm back!! Car would not start again. I have just checked the replies and most of you seem to suggest it's the battery. The dealership I bought it from is coming to collect the car and see what is wrong. I really hope that it is just the battery...
    So, just to confirm. Even if all the lights come on, it does a systems check but does not swing at all it could still be the battery??
    Andrew
    Toyota Fortuner 4x4
    Jurgens XT140
    Apr 2011
    Thanked: 1057
    Yip!
    When you insert the key all "systems" come on and a system check is done. But when you push the start button there is just nothing but a faint "click" sound. No swinging of the starter.
    ps....it is probably the factory fitted Netstar unit draing the battery. Ask them to remove it.
    Went through the exact same story 1 month ago with the wifes FLII.
    Thanked: 94
    Quote Originally Posted by Angen View Post
    Stepdad had the same thing with his FL2 last week. Battery kaput- his is still under warranty at LR and was replaced free of charge by LR Menlyn.
    Apparently the did an entire system check afterwards that took over an hour to check if something's draining the battery.
    Ex:
    2010 Discovery 4 V8
    2007 Discovery 3 V8
    2000 Defender td5
    Thanked: 39
    Don't know Freelanders, but if it is an intermittent fault it could be the starter relay that is on it's way out. Every thing comes on but the starter does not turn or click, even if the battery is 100%. Had it on my Jeep and just swopped the relay and all was good.
    Jan 2014
    Everton, Durban
    The AA guy is correct to say it could be a poor earth/negative... had the same thing with my previous A4. My negative cable had frayed inside the sheath... after 3 months of intermittent starting, new starter, 3 batteries, recon alternator, new key batteries, etc. I spotted a small metal strand sticking out of said cable, cut it in half, joined it properly, and sorted! had enough current for the lights, radio, obc etc. but not for the starter... I think my case occurred because when the battery was changed it wasn't fastened down properly, and caused the cable to fray...
    Jordan
    <a href="http://www.fuelly.com/car/land_rover/discovery-2/2004/jordanza/311455" target="_blank">
    Default Re: Freelander won't start!!
    Hi
    Is there any update on this issue and my FL 2 /2012 SD4 SE has the exact same issue.
    I have a dual battery system so i can connect secondary battery but still no go even with a battery booster.
    The car starts sometimes like nothings wrong and certain times with in a minute or minutes, i usually move the shifter from Park to Neutral and had some luck here but not always.
    Has anyone successfully figured this one out?
    Thank you in Advance
    Jan 2014
    St Lucia
    Thanked: 11
    Buying a used car has its problems, the reason why the previous owner sold it, for you to find and sort out those and after this you will have a fantastic Freelander! Mine had also some problems to sort and now it is a gem! Do not give up!
    Mine is 2nd hand but ive had her for 150k km already one of the best vehicles ive owned this is the first issues i have had with her.
    I hope i can find the fix not giving up just yet
    Thanked: 75
    Quote Originally Posted by sohail1 View Post
    Hi
    Try and take note of the steering column lock...when you push the key in, does it disengage? I had the problem of non-starting and it was the steering column lock
    Quote Originally Posted by veedub View Post
    Ok great i will check this out too
  1. Colt 2.8tdi cold start issues?
    By Hanman1 in forum Mitsubishi
    Last Post: 2014/04/01, 10:16 PM
  2. cold start valve
    By Vaaltyn in forum Nissan
    Last Post: 2014/03/25, 12:35 PM
  3. My Jeep won't start!
    By magoo_za in forum Jeep
    Last Post: 2014/01/11, 02:57 PM
  4. Freelander 2 i6 fails to start
    By lenh in forum Land Rover
    Last Post: 2011/09/23, 11:14 AM
  5. Freelander Hard start
    By jacovos in forum Land Rover
    Last Post: 2010/04/06, 04:06 PM
