Results 1 to 5 of 5
    Bogota
    Default 4H didn't engage
    Hi, everybody.
    This weekend I went to the country. When I tried to put the pickup in 4H it didnít engage. I tried several times with no success. I tried to go forward, no result. I tried to move back, no result. Itís imperative to have 4H and even 4L in some places on the trail I was going to drive on, so I switched off to wait for somebody who would bring some things to my place. Well, when I turned on the engine I saw the so desired 4H light, and then I could put in 4L with no problem.
    Does somebody have had this problem? Iíve heard that about other brands with electronic 4x4 system.
    Thnaks for the input.
    Sep 2015
    Adelaide
    If you keep pushing the 4wd buttons the controller gets confused . Quite often you will find if you turn the ign off and then on it will select the range ok . Don't play the buttons like a piano .... One push for 5 sec , then release usually does it . Always go from 2wd to 4 wd hi then stop to select low . When going back to 2wd select 4 wd hi first then 2 wd ... It's a bit clunky but no worse than the old Isuzu system
    Bogota
    Quote Originally Posted by commerute View Post
    Hi, commerute.
    Thank you for the answer.
    You described what I always do. I am very careful for everything, read completely owner’s manuals, follow what it’s written on, and it’s not different for that matter, especially because I am newbie to 4x4. First, I always stop (in spite of the possible change on the fly for 4H according to the manual), push the 4H button, wait (always 4-5 seconds) and push the 4L (again the same delay), and vice versa, and never by passed the mechanism.
    That day I waited for 30 seconds maybe one minute for each attempt. It had never happened before and never happened again.
    Thanks again for the interest.
    Sep 2015
    Adelaide
    No problem , I get a lot of questions about the 4wd
    Bogota
    That happened again, several times. I had to turn off and turn on and then the 4H appeared when the engine started. Foton engineer told me they found an error code showing the engine started with the 4H engaged but did not explain the problem. Does somebody have an idea?
    Do I have to return to 2H always before turning off the engine? When I go to the countryside, I have to engage 4L, so I turn the engine off in 4L because I have to use it like that to return to the highway and I thought it was not worth and not necessary to return to 2L before turning off, knowing I have to engage 4L again when I drive the next time.
    Thank you for the input.
  1. 2004 ranger 4x4 wont engage
    By justcruzin in forum Ford & Mazda
    Last Post: 2019/03/22, 07:44 PM
  2. Sporty 4x4 doesnt engage
    By HenkBooyse in forum Kia
    Last Post: 2013/10/28, 07:45 PM
  3. ANC wants to 'engage' with Desmond Tutu
    By Doepie in forum The 4x4 Pub
    Last Post: 2011/10/07, 10:29 AM
  4. Clubcab 4x4 Engage
    By Clubby_2.8 in forum Mitsubishi
    Last Post: 2011/09/26, 08:31 AM
  5. Diff lock wont engage
    By NewB in forum Mitsubishi
    Last Post: 2010/03/17, 09:51 PM
