Triton spotlight DIY install - long term project
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 69
    May 2013
    Default Triton spotlight DIY install - long term project
    Hi all 8)
    So I want spots on my Triton the reason it is a long term project is that I am waiting until my birthday to actually buy the spots/lightbar....so in the mean time I am planning and scheming and getting prepared please feel free to leave comments and suggestions
    May 2013
    Default Concept
    So the idea is to get a light bar and mount it similar to the pics....
ID:	348758   Click image for larger version.
ID:	348759   Click image for larger version.
ID:	348760   Click image for larger version.
ID:	348761   Click image for larger version.
    May 2013
    So now I had to decide where to put the light switch, because I don't want the spots to come with my brights....and because I don't like 'plugs' where there are supposed to be buttons and Mitsubishi conveniently plugged the button which disables the airbags (or at least that's what I think the missing button would be for)....I have decided to use that button space for my spots
    The pic below shows the button I'm talking about...it is the one opposite the hazard switch (on the left hand side)
    I had my "button" to the right of the steering wheel, there where the diff-lock button is.
    Nicely hidden away
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
    May 2013
    So I managed to find a Triton in a scrap yard and went there to buy the hazard light switch/button 8) it ended up costing me R250 (and I was able to also get the plug with wiring that plugs into the back of the switch). Just the switch would've just cost me R525 ex VAT from the stealers
    Now my plan is to get a blue button cover made up so that it doesn't look like I have two hazard light switches on my dash
    I will also need to solder on a new LED because the current one on the little circuit board is a red LED....and the switch is a momentary switch which posed another problem....
ID:	348781   Click image for larger version.
ID:	348782   Click image for larger version.
ID:	348783   Click image for larger version.
ID:	348784   Click image for larger version.
    May 2013
    Here is a basic drawing of the circuit board for the switch
    Here's a table for the colours of the different wires that are on the standard plug for the hazard switch;
    (1) green/red
    (2) black
    (3) black/yellow
    (4) green/white
    May 2013
    The problem with the momentary switch is that when I release the button, the signal turns off and the relay for the spots won't stay latched on...so I did some digging and found a drawing on the12V.com
    The drawing I found is for an impulse relay...not sure if you get automotive impulse relays? It would make my life a lot easier!
    So I redrew their drawing so that it is easier to understand and then also put it in PLC code just to double check that it works...and it works! You push the button and the lights come on...you push the same button again and the lights go off
    May 2013
    Nicely hidden away
    Thanks Nys, I'm guessing your switch was like a toggle switch? ie, when you switched it on, it stayed on?
    Quote Originally Posted by tintin_85 View Post
    Jip, on-off switch. Was linked to brights though i.e. you can only turn spots on when brights are on.
    May 2013
    Okidoki thanks
    If I'm not mistaken, your 'button' to the left, opposite the hazard switch is actually a warning light that indicates amber if and when your passenger airbag has been deactivated. When you start the vehicle up it should illuminate temporarily together with all your other dashboard lights so you can see whether it's working or not.
    To disable the airbag you have to open the passenger side door and turn the keyed switch (use your ignition key) that's located on the side of the dashboard. I'll have to double check on my Triton some time, but that's how I remember it working.
    2009 Triton 2.5 DiD
    May 2013
    Is your Triton an import? I definitely have a plug there and no light
    Where do you insert your key to disable the passenger airbag? Is it in the passenger door?
    Sorry for the late reply Tintin, I didn't keep an eye on this thread.
    My Triton is an import yes, opposite from the hazard switch is definitely only a indication light and my 'switch' (operated with the ignition key) is located inside the cubbyhole. I was confusing the location of the 'switch' with that of my previous car but made sure of it a day after my previous post.
    2009 Triton 2.5 DiD
    May 2013
    OK cool thanks Mine is the locally built 3.2....double checked and I only have a plug
    Now my only concern is getting the dash open without breaking anything
    May 2013
    So I bought the relays yesterday
    May 2013
    So I updated my circuit diagram 8)
    With Relay 6 wired up to the main head lamps, the spots will only work with the main headlamps on. If you switch the main headlamps off (or turn the car off) while the spots are on, then the spots will turn off as well. If the main headlamps are off and you push the button to turn the spots on, the spots will only be on for as long as you are pushing the button, much like flashing your brights
    Spots have been ordered....
    Next step is to put the circuit together, get a new button made, solder on a blue LED (for the switch) and then poke around my car and see what's what
    Edit: decided to wire "relay 6" off the brights instead of the mains because the Triton has separate relays for the headlights and the brights. The headlight relay doesn't stay on when switching to brights so what happened when switching to brights is that the spots would switch off
    May 2013
    So I decided to help explain the circuit to those who are interested...
    I redrew the circuit in the Siemens LOGO PLC software to help visualize what happens. The relays are labeled with a 'M' for memory bit instead of a 'R' for relay.
    Below are the pics of the switch (I1) being off, with the mains (I2) off...and then a pic with the switch (I1) on with the mains (I2) off. In my previous schematic, I2 is actually R6.
Name:	Switch off Mains off.jpg
ID:	352209   Click image for larger version.
Name:	Switch on Mains off.jpg
    May 2013
    The next 4 pics are all with the mains (I2) on. This shows the sequence with the momentary button used on the switch (I1).
    Pic 1. The mains is on...everything else is off
    Pic 2. The switch is pushed in (ie. it is on). This brings the lights on. Relay 'M3' is latched on to keep the lights on.
    Pic 3. The switch is released. The lights stay on because of relay 'M3' being latched.
    Pic 4. The switch is pushed in again. Relay 'M3' unlatches because relay 'M1' is now on.
Name:	Switch off Mains on.jpg
ID:	352212   Click image for larger version.
Name:	Switch on Mains on Lights on.jpg
ID:	352213   Click image for larger version.
Name:	Switch off Mains on Lights on.jpg
ID:	352214   Click image for larger version.
Name:	Switch on Mains on Lights off.jpg
    May 2012
    The 6 relay wiring looks like a lot of overkill, but the asthetics of the switch in the vehicle with the momentary press button will be worth the effort..
    clever idea you have there.
    Currently do not own a 4x4, driving a sedan
    Ex: 2013 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2012 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2013 Ford Ranger 2.2 XLS 2WD manual
    Ex: 2009 Mazda BT50 3.0 CRDi double cab manual
    May 2013
  1. Discovery 3 suspension lift long term feedback
    By DiscoDave in forum Land Rover
    Last Post: 2013/03/12, 05:16 PM
  2. Long range tank for triton
    By Greenhorn in forum Mitsubishi
    Last Post: 2011/02/21, 09:48 PM
  3. DIY for as long as you can
    By Johan in forum The 4x4 Pub
    Last Post: 2010/05/14, 09:02 AM
  4. Replies: 25
    Last Post: 2009/11/19, 07:31 AM
  5. Triton long range fuel tank mileage
    By phjoubert in forum Vehicle & Technical Chat - General
    Last Post: 2009/01/09, 06:43 AM
