Defender Td5 not 'auto-bleeding'
Results 1 to 8 of 8
    Oct 2014
    JHB
    Exclamation Defender Td5 not 'auto-bleeding'
    Howsit guys,
    My Defender doesn't do the fuel pump/system bleed when you depress the pedal 5 times (I think that's how you're meant to do it)
    Any suggestions?
    Dec 2010
    Groblershoop
    Can you hear the pump when you switch the ignition on, it should run for about 3-5 seconds.
    Springs
    the Td5 pump should run around 20 - 25 seconds
    depress pedal 5 times and the engine light should come on to indicate that it is in autoprime
    may be an ECU issue, a dirty plus of something silly
    you can prime without this function by switching on till the pump stops, switch off and on etc but worth investigating
    Oct 2014
    JHB
    The pump runs for 3 minutes when the ignition is turned on. Thereafter the pedal pump method does not work.
    The ecu does look dirty, how do I go about cleaning it?
    Who can help me look at this (the pump bleeding)? I know its a small fault but its a fault none the less.
    Cape Town, Durbanville
    Some of the earlier ECU's did not have this function.
    I think you have to switch it off and on a few times to bleed it.
    ---000O000---
    Disco 3 V8 HSE 2007
    Ford Ranger 3.0 TDci 2008
    SERIES III 109 1976 HC
    DEFENDER 110 TD5 2006 CSW - SOLD!
    ZS1JHZ @ 2M
    Springs
    Quote Originally Posted by miks. View Post
    remove the ECU, unscrew the cover bolts (you need special Allen keys - those with hole in the middle of the star) and remove the cover
    get electrical cleaner and properly drench the inside and the outside, place face down for the muck to run out and leave in sun to dry
    reassemble the cover and apply a thing cote of silicone to where the cover fits on
    also silicone the vent holes to prevent water and dust ingress
    Gaborone
    Quote Originally Posted by Landyluvver View Post
    So much for vent holes....
    I understood the problem was predominantly oil migrating into the ecu via the wiring loom.
    Sep 2019
    Default Re: Defender Td5 not 'auto-bleeding'
    Quote Originally Posted by serieslr View Post
    I have a 1999 Defender TD5 which doesn't seem to do autobleed. Do you have any info on which ECUs can do it and which can't?
    Land Rover
    Defender 110
    TD5
    @saffaoverland
  1. Defender TD5 Engine Rebuild
    By Phil2005 in forum Land Rover
    Last Post: 2015/02/17, 02:42 PM
  2. Discovery 2 TD5 ES Auto Facelift White 2004
    By rssfeed in forum For Sale, Swop & Give-Away
    Last Post: 2015/02/17, 12:00 PM
  3. 2005 Defender 110 TD5 Book value
    By brandh in forum Land Rover
    Last Post: 2014/10/11, 01:56 PM
  4. Defender Buying a 2002 TD5 Defender, advice needed.
    By constantlm in forum Land Rover
    Last Post: 2011/10/05, 12:12 PM
  5. Defender 110 Td5 - GCM (Gross Combined Mass)
    By JohanJvV in forum Land Rover
    Last Post: 2011/07/18, 08:14 AM
