Tire Pressure Monitoring System
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 60
    WC
    Thanked: 194
    Default Tire Pressure Monitoring System
    Can anyone recommend a good yet budget friendly TPMS please?
    2004 Jeep Grand Cherokee 4.7L V8
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 933
    OK.
    Bad manners to just subscribe.
    Would also like to know. I lost a tyre value (R2460) that could've been spared if I had a system installed
    Some months (years?) ago Weg magazine compared some systems. I cannot remember when.
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
    WC
    Thanked: 194
    We are in the same boat Johan.
    We lost a perfectly good, almost new tire in Etosha. It was in shreds before I even knew anything was wrong! All I could see was just black rubber shooting up in the side mirror.
    It will certainly pay for itself by saving just one tire.
    Thanked: 415
    I have the Tire Guard from Abraham Kruger (Abe on the forum) Still works after 3.5 years.
    2004 Defender 110 Td5
    Oct 2014
    Thanked: 60
    See www.tyrealert.co.za
    Dawood is deaf so don't phone - text or email him.
    I'm pretty sure you'll find his service to be the best you've had this year.
    Those are nice, but what would be ideal for overlanding is something that can monitor 8 wheels: 4 + 2 spares + 2 trailer...
    Land Rover Discovery 3 TDV6 2007
    Witbank
    Thanked: 14
    I think there is one called TPMS that does 6 tyres?
    Gandalf: '77 Series III 109" SW (He's old, he's grey, he smokes, but on an adventure you want him as companion...)
    HF, VHF, UHF
    Detroit Locker rear, Truetrac LSD front
    Hardened valve seat ULP conversion
    British cut cam shaft
    VW carb conversion, electric fuel pump
    G-Tech Electronic Ignition
    Hankook M/T 235/85/16
    Frodo: '12 Jimny (SWAMBO)
    Stofpad spacer lift and underbody protection
    Platkar (work): '15 Ranger 3.2 AT 4x4 with AluCab
    Jun 2008
    Thanked: 933
    Our Tiguan is equipped with them as standard.
    One day we were riding on the N1 and the TPM flashed. I thought to drive to the next filling station without checking.
    500m later the tyre was completely flat and totally ruined.
    I really felt like an a$$hole.
    WHEN ALL ELSE FAIL, TRUST YOUR INSTRUMENTS
    Isuzu 300 d-tec
    BMW R1200GS & GSA
    Gaborone
    Thanked: 1000
    Tireguard does upto 22 wheels, so call Abraham Kruger and he can help.
    BTW you don't need it for the spares as the sensor is in the valve cap so it moves on when you change tyre.
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
    Apr 2015
    Thanked: 279
    Just bought a Tyredog 5 wheel TD-1300A system.
    Installed it today, seems to work fine.
    Fortunately I had metal valve stems installed at the last tyre change.
    WC
    Thanked: 194
    Apparently you get internal or external sensors?
    If the sensor is external could it not get damaged?
    SANDTON
    Happy with my TireGuard system. Has 6 sensors so able to monitor the trailers tyres as well.
    DISCOVERY 4 SDV6 SE
    Apr 2011
    JHB
    Also very interested in hearing everyone's views. How do the internal sensors get fitted..? So you need to remove the entire wheel from the rim or how does it work..?
    Apr 2015
    Thanked: 279
    Quote Originally Posted by Chuckzoo View Post
    Yes, in theory it could get damaged, but in practice it does not seem to happen often. You can lock them into place, so they won't just fall off.
    They seem to handle reasonable immersion in water quite well.
    Both have disadvantages and advantages.
    External :
    1) Cannot measure tyre temperature accurately
    2) Battery can be replaced.
    3) Can be lost / stolen / damaged
    4) Easy to install / move to another vehicle or other rims.
    Internal :
    1) Measures accurate internal tyre temperature
    2) Difficult to install, same as a valve replacement. You don't have to take the tyre completely off the rim, but almost so.
    3) When the battery is flat the tyre unit needs to be replaced, they are sealed (and the sensors are about R700 each). But battery lasts more than 3 years.
    4) Not easily transferable.
    Can't think of other pros/cons at the moment.
    I have a Tyredog external system, seems to work well.
    Okahandja, Windhoek
    Thanked: 789
    I use tiremoni , atill working after 5 years. Just replace the valves in the rim form time to time.
    Johan Kriel
    LCs, Hilux and Echo Chobe
    Apr 2011
    JHB
    Thanks Jola for the detailed response.
    WC
    Thanked: 194
    How important is it to be able to measure tire temperature accurately? Is high temperature a good indication the the tire is about to blow?
    Since we will be off road in thick sand with deflated tires the tires will be hotter than normal correct?
    At this point I am leaning toward the external monitors.
    Timbavati Game Reserve
    Contact Abraham. Had my unit for over 3 years now.
    Had a problem and unit was replaced immediately, within 30 minutes of my call. Only problem with new unit is that the outer coating will not allow double sided tape or Velcro to stick to it.
    Very accurate and batteries last more than two years and easy to replace.
    Only problem I see now is the very thin "O" Ring on the battery covers are perishing, but then again everything perishes in the Lowveld summer temperatures.
    So far I have saved three tyres on the Pathfinder and one on my Caravan, so it has paid for it's self many times over.
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
    Nissan Pathfinder 2.5d
    A bunch of LR Tdi & Td5
    Apr 2011
    JHB
    Quote Originally Posted by davejackaman View Post
    Dave which make/model do you have?
    Hi Zenbaas
    Sorry I omited to but the make in
    Tire Guard Abraham - 082 926 0585
    Dave
    Dave Jackaman
    Ham Call Sign ZR6DG
    Timbavati PNR
  1. Tyre Pressure Monitoring System
    By 4x4 in forum Tyre chat
    Last Post: 2019/01/02, 01:30 PM
  2. Discovery 4 - Upgrade
    By pieter_fourie in forum Land Rover
    Last Post: 2015/03/04, 04:07 PM
  3. Tire pressure opinion poll
    By NEON DEON in forum Jeep
    Last Post: 2013/10/04, 03:54 PM
  4. Solar system ...
    By Elders in forum Camping, Fridges, Accessories
    Last Post: 2013/02/27, 12:09 AM
  5. Tyre Terminology
    Last Post: 2011/07/13, 01:53 PM
