My "new" Landy, with saga attached - Page 15
Page 15 of 21 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 LastLast
Results 281 to 300 of 417
  1. #281
    Modjadjiskloof
    Thanked: 146
    And there she is, in the flesh. Purrs like a kitten.
    Attachment 375498
  2. #282
    Mar 2007
    Thanked: 85
    Now for the pure Land rover enjoyment, enjoy it Anthony.
    2015 Pajero Sport 2,5 Di-D 4x4 5-spd Auto, STOFPAD eng & gbox plate, new engine courtesy Mitsubishi at 95k km.
  3. #283
    Modjadjiskloof
    Thanked: 146
    Quick trip up Magoebaskloof pass to test her out. 2200 rpm in third gear. Max temp 95 deg C and you can hear the viscous fan kicking in.
    Can't check egt as the probe or its connection seems to be damaged. I suspect the earth braiding has been ripped out somewhere during manhandling.
    Oil pressure nicely in spec
  4. #284
    Mar 2015
    New Germany
    Thanked: 496
    Glad it all going well, i had to take out my injector pump as the pin that runs on the off set cone was seized, pump was supposed to of been servest, ya right it was.... so back it went to the IP people again but all back together now
  5. #285
    Thanked: 87
    Antz
    Lekker to be behind the steering wheel again ne ??
    That bumper isnt standard - cause your number plate is skeef
    I know the previous owner is on this forum
    BUT
    Check air holes vs std bumper
    I hate aftermarket stuff that isnt researched
    Yours is an auto so not sure of another radiator
    That trip to Lesotho should have been a nothing in terms of air flow and temps
    Then I see 2 small spot lights in the way of normal air flow
    My 2 c worth
    If I compare the night driving of my freinds flat cars - polo, Auidi A4, korean something, opel , ford something
    None of them compate to my lights at all which are standard and severly piited from driving over toyotas
    All of my comparisons are cars older than 4 years
    Ek se maar net
    But she is home
    Gooooood news
    Enjoy
  6. #286
    Mar 2007
    Thanked: 85
    Ross, you are correct about the front bumper/bull bar combo, and the wind tunnel designed OE bumper. Brian Cotton did the front end rebuild, and we carefully checked the "mating" surfaces. We added in horizontal sections to ensure the airflow is path is as per the OE bumper. Interesting observation was that with the front end re-build the rubbers along the vertical radiator frame, both sides went AWOL, and this was picked up as the running temperature was higher. Once those vertical rubber seals were back in place all was back to normal. The 115 mm diameter Bosch spots are actually a good distance from the front grille. There was no running temperature difference, and they were there for 6 years.
    What that "Oshkosh" bull bar did, when the winch was added, was that the front dropped by about 4 mm due to the additional weight of all the steel.
    The OE bumper will be collected by Anthony later this year, so Sokkies will have two "dress" code options, if so required....
    First pic the bull bar that was a bolt on to the OE bumper, next pic the "Oshkosh" bumper/bulbar and the air flow diversion plates we put in.
ID:	375540   Click image for larger version.
ID:	375541   Click image for larger version.
  7. #287
    Modjadjiskloof
    Thanked: 146
    Ross, thanks for the constructive comments. Much appreciated. I'll keep a careful eye on the temperatures as summer continues scorching.
    Thys, thanks for clarifying with details of the rebuild. I really like that front bumper/bullbar combination - it's genuinely a sturdy build and is securely mounted as well. It also gives this landy a unique "look" and I would be very hesitant to remove it.
  8. #288
    Mar 2007
    Thanked: 85
    Thanks Anthony, maybe you must just check if all the Indies who worked on Sokkies lately, did not remove those two strips we fitted between the bumper and grille.
    Enjoy
  9. #289
    Modjadjiskloof
    Thanked: 146
    The Masonite stuff? It's still there and so also are the side rubbers.
  10. #290
    Modjadjiskloof
    Thanked: 146
    Today was spent doing police clearance because of the engine number bungle.
    Got all the documents together and made an affidavit. Half an hour in Tzaneen SAPS where a guy checked everything about my story. Back to Modjadjiskloof for a RPC, took 3 hours standing in a queue of 4 people. Then back to Tzaneen and 10mins later all done...
  11. #291
    Thanked: 87
    Antz
    I know this may sound a bit over the top
    BUT
    Landy all clean
    Take good overlaping photos of the motor and g/box and even diffs
    Then in 3 months time when you spot something you can actually cross reference it back to a photo and not some paranoid made up memory
  12. #292
    Jan 2009
    On the beach in Ramsgate But unfortunately paying the bills in Bellville CT
    Thanked: 16
    Glad its all sorted , now you just need some quality of roading time
  13. #293
    Modjadjiskloof
    Thanked: 146
    Antz
    BUT
    Landy all clean
    Wise words. Not a bad idea for insurance purposes anyway.
  14. #294
    Mar 2007
    Thanked: 85
    Could they get Sokkies back as a 7 seater?
  15. #295
    Modjadjiskloof
    Thanked: 146
    No, she has to go through another RWC. Just got issued a new licence disc a few minutes ago, so I'll do a RWC in December and then wait for the next disc.
  16. #296
    Modjadjiskloof
    Thanked: 146
    Just refuelled after about 530 km driving.
    Fuel consumption 10.9 l/100 km. Not bad for a still-running-in engine. What's more, a lot of this was done on mountain passes.
    EGT gauge not functional at the moment - it seems to have come back from the workshop giving spurious readings. I'll check this weekend to see if the earthing sheath is properly connected. The probe is properly installed. I would have liked to get some EGT readings, especially in this hot weather. Apparently it reached 41 deg C in Tzaneen yesterday!
    Climbing on the road from Tzaneen to Agatha (The Coach House), you ascend from about 750 m to 1100 m. This was quite easy yesterday, with only myself in the car and no aircon. But it was a bit of a challenge today with some passengers and the aircon running. In the steepest sections, I had to slow to about 40 km/h in second gear, with water temperature climbing to 100 dec C near the top of the hill.
  17. #297
    Thanked: 23
    So happy for you that this thread has eventually turned into a feel good story! Wishing many hundreds of thousands of trouble free kilometres!
    2017 Nissan Qashqai
  18. #298
    Modjadjiskloof
    Thanked: 146
    AwieT, thanks for the good wishes. Certainly it has started well, with such a great job done by the indy.
  19. #299
    Modjadjiskloof
    Thanked: 146
    Time for another round of thanks.
    This time the award goes to VENTURE OVERLAND (a very competent workshop in Tzaneen run by Dermot). Dermot, I know you don't read the forum because you're too busy fixing our Landies. But this is just a public THANK YOU for all the excellent work and attention to detail on my car. I've seen from your attitude and work ethic that you are truly a one-in-a-million mechanic.
  20. #300
    Modjadjiskloof
    Thanked: 146
    I spent a bit of time this afternoon with the Landy in her natural habitat. Did some back gravel routes around Magoebaskloof and got a nice coating of dust all over the car. An absolute pleasure to drive on the back routes where there are no "fast" cars to chase you. Just stick it in Drive, push the accelerator, grin and enjoy.
  1. Landy worx fantastic service!
    By Matuka in forum Land Rover
    Last Post: 2017/08/18, 07:23 AM
  2. Discovery 1 It's Final. I LOVE my Landy!!!!
    By biltong in forum Land Rover
    Last Post: 2014/10/18, 11:53 AM
  3. Defender My Puma is alive again
    By wouterdwc in forum Land Rover
    Last Post: 2014/04/18, 09:16 AM
  4. Land Rover Auction at the 2014 Landy Festival
    By craigdutton in forum Land Rover
    Last Post: 2014/01/28, 07:46 PM
  5. 3.5 V8 Landy starting problem
    By 0-100km/h in 2 days in forum Land Rover
    Last Post: 2012/04/07, 05:17 AM
