Discovery 2: 2so td5 - Page 2
Results 21 to 28 of 28
Thread: 2so td5
    Thanked: 451
    Quote Originally Posted by Landyluvver View Post
    ok, so your injectors are happy
    2SO can only "fix" if it is broken not make injectors operate better than from the production line.
    if you have access to a endoscope and could feed it in through the injector port, you would see that the engine is a lot cleaner inside
    this should be evident inside the turbo as well
    +1
    George Bosch
    Distributor for:
    Thanked: 12
    My thoughts exactly. The best thing I did last week, is to replace the MAF sensor. The Disco runs much better now.
    2011 Fortuner D4D 4x4
    2002 Disco GS TD5
    1965 Beetle in sections
    Feb 2012
    WC
    Thanked: 12
    I am with Roguefrontier's reasoning.
    Springs
    Thanked: 280
    Quote Originally Posted by RogueFrontier View Post
    I think posting injector readings every 100 000km will be much more indicative.
    injector readings are influenced by various factors
    compression, condition of copper washers, injector harness condition, oil in harness, injectors themselves etc all affect the readings
  5. #25
    Thanked: 689
    My 110 TD5 was sold on 330 000km and still had the original injectors. never saw a drop of 2SO.
    90TD5 is on 260 000km, also original injectors and never saw any 2SO.
    I totally agree with this. If you look after your engine as per manufacturer specs and follow the correct service intervals, you will be a happy camper. I dont believe in 2SO, thats my opinion.
    For injector readings that are all over the place, take it to an indy and have him check the mechanical and electronic settings. This TD5 I got 2 months ago was useless in the morning and didnt really have any power - ever. Took it to my Indy in jhb and we found that the injector codes wasnt paired with the ECU. Also the mechanical settings were out. She runs like a bat out of hell now!
    Not meaning to start a war, I simply want to state what I have observed on the forum: many of the guys that swear by 2so, seem to be the ones complaining about injector failure at some point or another. A few weeks ago somebody asked why only diesel injectors give problems and not petrol injectors, my opinion is because nobody adds 2so to a petrol car.
    My 2cw. No that this is off my chest, I will never speak off 2so again.
    12 Conqueror courage
    17 Ranger Supercab Tdci (Sold)
    97 Defender HCPU Tdi (Sold)
    99 Discovery 2 TD5 GS (Sold)
  6. #26
    Springs
    Thanked: 280
    we don't have control over the quality of fuel we buy
    even the best engineered vehicles can be destroyed by poor oil or fuel
    petrol does not leave carbon deposits as diesel does
    petrol injectors are also not direct injection and the injectors subjected to direct heat or carbon buildup so different scenario
    incorrectly coded injectors has nothing to do with this discuussion
    as stated many times before - no one is forcing you to use 2SO so if you don't like the idea, then don't support it
  7. #27
    Thanked: 689
    My injector readings were all over the place, coding got that sorted. That was what I meant to say.
  8. #28
    Springs
    Thanked: 280
    accepted
    everyone who have bought a second hand Td5 or had copper washers done should verify that the coding is correct
    it takes 10 minutes to remove and read the injector codes
    you however need to have access to diagnostics to verify the codes are correct
  1. Adding 2SO to low-sulphur diesel
    By BergKwagga in forum Land Rover
    Last Post: 2016/09/27, 01:33 PM
  2. td5 maintenance advice needed
    By Ivan113 in forum Land Rover
    Last Post: 2015/05/07, 09:52 AM
  3. Defender TD5 Preventative maintenance
    By Bighest in forum Land Rover
    Last Post: 2015/04/06, 05:13 PM
  4. Disco 2 TD5 Questions
    By Danny de Bont in forum Land Rover
    Last Post: 2015/02/11, 04:05 PM
  5. Defender Td5 - 2SO question...sorry!
    By Trevor_Mathews in forum Land Rover
    Last Post: 2011/04/03, 09:25 PM
