Upper control arm bushes replacement
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 51
    May 2010
    Bergbron, Roodepoort
    Thanked: 223
    Default Upper control arm bushes replacement
    Easy or is there a trick to it?
    Jan 2009
    Germiston
    Thanked: 95
    Yes there is, gm only! Franz, maak briek pyp los, cable tie hub laat hy nie move. Balljoint los(as jy lucky is het jy balljoint flip, maak dit dan maklik. Dan maak jy shim plek los, links regs nuts los, trek hom uit.
    Hierso vind ek hammer en n staal punch slaan ek hom uit, ek slaan nuwe terug in met ou bushes.
    Insit, in reverse maar wanneer jy kant nuts vas maak trek dit vas in in omtrent die orientasie waar die control arm in normale posisie is as die kar op sy wiele is. Onthou shims terug sit soos hul uitgekom het. Na als gaan check alignment
    As dit nie werk bel my...
    Groete
    __________________
    '01 Isuzu Frontier LX 4x4 Diesel8) - For the brown Stuff
    '14 Renault Sandero 900cc Dynamique, small with a big heart
    Jan 2009
    Germiston
    Thanked: 95
    Het ek genoem GM only!!! As jy nie luister kan jy oor 10 000 km die proses herhaal...
    __________________
    Thanked: 167
    Is there no one out there that can do poly bushes for us?
    Flagster if you need a hand let me know I'm free this weekend and next.
    2010 Toyota Fortuner 2 4x4.
    2001 Isuzu KB320 Frontier 4x4.
    2012 Polo GT White with community sticker.
    Jan 2009
    Germiston
    Thanked: 95
    G would be an idea, but gm ones will give you 200k
    __________________
    May 2010
    Thanked: 223
    Dankie Jaco, sal so maak.
    Thanks Garreth.
    Garreth, something like this?
    May 2010
    Thanked: 223
    Jaco, ek het ook n contact by GM.
    My swaer werk by die Randburg tak
    Jan 2009
    Germiston
    Thanked: 95
    Franz!!! Waar kry jy daai?
    __________________
    Jan 2009
    Germiston
    Thanked: 95
    Franz wie is jou swaar? My kontak ook daar, hy doen my baie gunse
    __________________
    Thanked: 167
    Ja that's them. I'll change mine to poly any day.
    Now you tell us ha ha been hiding him for us lol😂
    May 2010
    Thanked: 223
    I think the place is called Eastrand Spring Works? In Springs? I got pins made for my leaf springs a year ago or so and they gave me those. The pins where specially made for me and everything cost something like R600.
    My swaer se naam is Christo du Plessies. Hy gaan uit en doen die breakdowns.
    I want to spend a few bucks on the Isuzu. I want to replace all the rubbers and ball joints with new, from GM. When that is finished then it is new brake discs, wheel bearings, needle bearings, seals also all from GM. Sick and tired replacing the same parts every few months, then all hoses. SMYlie has 330,000km on the clock. It's time.
    May 2010
    Thanked: 223
    Sorry, Boksburg
    243 Power Street
    011 914 3299
    Thanked: 167
    Cool did you get the details I send you on Facebook. That should help you with the parts you need.
    May 2010
    Thanked: 223
    I'll go and have a look thanks.
    Thanked: 167
    No prob
    Jan 2009
    Germiston
    Thanked: 95
    My ou is johan du plessis, wonder of hul familie is!? Assistant parts manager, baie nice ou
    __________________
    May 2010
    Thanked: 223
    Quote Originally Posted by sweeper View Post
    Lol
    Dis nou per toeval
    May 2013
    Thanked: 20
    Vossie replaced all the bushes infront with poly bushes on mine. Replaced a few other things with that. He is not expensive at all. Has all the tools etc.
    2003 KB 300 TDI 4x4
    2006 Audi A4 3l TDI
    2013 KTM 450 SXF
    Thanked: 25
    Bushes like these will not work as upper control arm bushes. You need to have the outer sleeve as well. Look at how the bushes fit into the control arm and you will understand why I say this.
    When U replaced mine, I made use of an impact air wrench, a piece of tubing and a piece of threaded rod. Makes life so much easier.
    This youtube video sort of describe how to do it
    Watch "Control Arm Bushing" on YouTube
    https://youtu.be/Aom8oDLiHF4
    _____________________
    Work is to pay for playing
    Jan 2009
    Germiston
    Thanked: 95
    Chris is right, those poly's are not UC bushes.
    __________________
  1. Pathfinder rear control arm bushes
    By ColinK in forum Nissan
    Last Post: 2014/06/17, 09:45 PM
  2. Traction Control is not the same as Stability Control!!!!
    By XJ Junkie in forum Vehicle & Technical Chat - General
    Last Post: 2014/01/04, 10:37 AM
  3. prado 120 control arm teflon bushes
    By airtite in forum Toyota
    Last Post: 2013/09/23, 09:45 AM
  4. Replies: 2
    Last Post: 2009/01/16, 04:28 PM
  5. Control arm bushes for WJ
    By Jeeper in forum Jeep
    Last Post: 2007/10/31, 04:06 PM
