Discovery 1 What have you fixed on your Disco 1 today?
Results 1 to 20 of 40
    Jan 2015
    Smile What have you fixed on your Disco 1 today?
    So, it seems to me that a common problem with the Discovery 1's are the rear windows that cease to function. After a quick bit of googling the most likely scenario seemed to be that there was some problem with the window ECU.
    Now, its easy enough to check this with a voltmeter, since I'm told that a VERY small current may in some instances find its way to the window regulator, but that would obviously entail opening the doorcovers and such; which seems to be quite a bit of effort and quite a backwards way of going about it if one intends to do this in order to establish that the fault MAY lie somewhere else.
    In any event, I opted to tackle the window ECU directly as per a very nice video clip uploaded by an American. The wire-connectors are a hassle to remove in the sense that the angle is a bit awkward and one is naturally afraid to rip the wires right off, but once they're free you're halfway there.
    After removing the ECU circuit board, the culprit is pretty obvious. It seems that the soldering point comes loose over time. In my case a clear ring/crack was visible around the point, which obviously obstructed the flow of current. Once the point was re-soldered and the ECU re-fitted, the windows worked beautifully.
    I might add that the car had been with two auto-electricians who couldn't figure this thing out; one of the guys suggested that the car's wiring loom be re-done. Which just go's to show the power of sharing information... and the internet.
    Here's a link to the video which I had referred to:
    https://www.youtube.com/watch?v=kt6odNB3c8s
    I will attach a before and photograph, so you guys can see what to look out for.
ID:	341417   Click image for larger version.
    Thanked: 436
    Hi eti1ne
    I fixed the front bumper guards and fitted new front indicator lights. The old ones were faded
    George Bosch
    Distributor for:
    Jan 2015
    Default Faded (oxidised) lights?
    Headlight oxidation, that faded light problem.. can be easily fixed with some toothpaste and a little elbow grease.
    https://www.youtube.com/watch?v=2lZ96BXoT10
    Thanked: 9657
    Quote Originally Posted by eti1ne View Post
    Which confirms the average standard of so-called professionals these days.
    Thanked: 436
    +1
    George Bosch
    Distributor for:
    Thanked: 436
    Yes that works, but in my case the yellow lenses were faded and had cracks. No amount of tooth paste would have helped there.
    George Bosch
    Distributor for:
    Hartbeespoort
    I now have my rear sunroof leaking water, tighten the little screws on the window cleaned rubbers but still leaking, anyone with advice, also replaced my headlights and indicator lences, looking better.
    Ze'
    '98 Disco 300 Tdi "Stony"
    Ironman suspension, dual tanks/batteries, rr,rtt,snorkel, etc.....
    Jan 2015
    Quote Originally Posted by Ze' View Post
    Hi Ze,
    I was in the process of trying to source some rubbers for my rear side windows (which are shot), when I saw something about the drainage plug hole that might get clogged on the sunroofs. Have a look at the thread below; it should actually read D1 and not Series 1, don't be put off by that, its the same car as yours.
    http://www.4x4community.co.za/forum/...ow+rubber+seal
    Hartbeespoort
    Thanks eti1ne, I did fix my roofliner a while back, seems like I will have to remove it again have re upholstered and clean drain pipes to prevent water spilling inside again.
    Ze'
    Thanked: 9657
    The other option is to permanently close the sunroof using silicon gel.
    Mar 2014
    Ermelo
    Thanked: 108
    Nice thread. We must share info as much as possible to keep them going
    Four wheels move the body,
    Landys move the soul.
    0614512283
    Current: Discovery 1 V8i
    Next landy, D3 V8 HSE Previous one.D1 300 TDi donkey, D1 V8 Fuel THIEF!!! freelander 1, biggest pos known to man,
    Thanked: 7
    The plastic drains can crack or pull away from the metal. The bit where the pipes go on can break too. Entirely fixable but a pain to get the lining out the way.
    '09 Suzuki Grand Vitara 3.2
    ''84 Bertone X1/9
    '80 Moto Morini 500
    Mar 2014
    Ermelo
    Thanked: 108
    What did you use for fixing a sagging roof lining?
    0614512283
    Thanked: 7
    I just glued it back while I had it out. While you have the headlining out is also a good time to add any extra heavy duty wiring to the back of the car. And clean those alpine windows from the inside. On the subject of alpine windows look for rust on the inside. This is a good time to treat it.
    ''84 Bertone X1/9
    '80 Moto Morini 500
    nwanetsi concession, KNP
    Going to attempt to fix my front door lock tomorrow, wish me luck.
    1992 Disco 1 200tdi
    Mar 2014
    Ermelo
    Thanked: 108
    Quote Originally Posted by defender200tdi View Post
    That little springs? Not a lekker job
    0614512283
    Hartbeespoort
    I for one do not se the need for sunroofs, its just problems waiting to happen so yes jelo silicone might just do the job.
    Ze'
    Jan 2014
    Thanked: 52
    Awesome thread!! Wonder if there's enough fixing going on for a Series version, or can we just hang out here as well
    Angry
    Quote Originally Posted by Sam vd Merwe View Post
    Gave it a good go today but couldn't get it done,
    On the plus side I saw that there was an earth strap on the starter motor and after I loosened the strap cleaned the contacts and reattached my little truck is starting like a dream.
    Is there such a thing as an auto locksmith that could help with my lock woes??
    1992 Disco 1 200tdi
    Mar 2014
    Ermelo
    Thanked: 108
    I bought 2 left and 2 right hand side springs long ago. Fitted the left front and the 5th door. Its a real bad one trying to fit that little springs
    0614512283
  1. To Disco 4 on not to Disco 4
    By CharlieBrown in forum Land Rover
    Last Post: 2012/07/17, 05:39 PM
  2. Gauteng 4X4 Community Dyno Day 31 March 2012
    By TwinDisco in forum Gauteng
    Last Post: 2012/04/12, 09:53 AM
  3. Buying advice Disco 2 vs disco 3
    By justcam in forum Land Rover
    Last Post: 2012/03/22, 11:23 PM
  4. Discovery 2: I just drove a Disco II td5..
    By petermoffat in forum Land Rover
    Last Post: 2010/01/19, 04:38 PM
  5. Disco II V8
    By karoo landy in forum Land Rover
    Last Post: 2009/12/29, 02:09 PM
