Discovery 1 What have you fixed on your Disco 1 today? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 40 of 40
  1. #21
    Mar 2014
    Ermelo
    Thanked: 108
    Replaced the brake fluid bottle rubbers
    Four wheels move the body,
    Landys move the soul.
    0614512283
    Current: Discovery 1 V8i
    Next landy, D3 V8 HSE Previous one.D1 300 TDi donkey, D1 V8 Fuel THIEF!!! freelander 1, biggest pos known to man,
  2. #22
    Gansbaai
    Quote Originally Posted by defender200tdi View Post
    Gave it a good go today but couldn't get it done,
    On the plus side I saw that there was an earth strap on the starter motor and after I loosened the strap cleaned the contacts and reattached my little truck is starting like a dream.
    Is there such a thing as an auto locksmith that could help with my lock woes??
    Spent another couple of hours working on the drivers door of my Disco today and I'm pleased to say that I think I've been successful. I'm going to live in great fear of my door not opening at all for the next week or two but after that I reckon I'm home free. Also managed to tighten the central locking linkage so all doors are locking and unlocking again
    1992 Disco 1 200tdi
  3. #23
    Mar 2014
    Ermelo
    Thanked: 108
    Fights with that springs?
    0614512283
  4. #24
    Gansbaai
    Fitting the spring into the lock was the easy part Sam. Getting the lock in and out of the door and reconnecting the rods was the rough part. Wouldn't want to do that again in a hurry.
    1992 Disco 1 200tdi
  5. #25
    Mar 2014
    Ermelo
    Thanked: 108
    Try the 5th door. The worst one for me. I learned a new word or two
    0614512283
  6. #26
    Jan 2015
    Default Disco 1 - Running like a beast for the first time!
    After replacing every single thing that could affect the startup/firing prosess under the bonnet of the V8, and not getting behind why she was misfiring....
    Replaced every single pc box/ elec. box, feul management system i could FIND! And for the first time since I bought my Disco, she's running like a beauty without skipping a beat!!!
    Also DIY plastidipped all the black bumbers & nudge bar as this was n test and the beginning to see if it's worth DIY plastidipping the whole car! So far, it' looks like its the way to go!
    "One does not simply just fix a Land Rover, there's a certain amount of patience, a little bit of luck and a whole lot of oil involved....."
    97' D1 V8 Land Rover.
    10' Volvo V50
    15' KTM 250SX
    04' BMW R1150R
  7. #27
    Mar 2014
    Ermelo
    Thanked: 108
    Looking good
    0614512283
  8. #28
    Jan 2011
    JHB SA
    Thanked: 13
    Clear the blocked aircon drain pipes. No more wet carpets
  9. #29
    Jan 2015
    Rewired my whole disco, no more elec. problems popping up
    10' Volvo V50
    15' KTM 250SX
    04' BMW R1150R
  10. #30
    Thanked: 67
    JTC
    The whole disco
    dash, rear wiring , windows and everything ?
    Big job but probably worth it
  11. #31
    Jan 2015
    Every single thing! (well 95% , the whole dash, all the lights, windows, harness) basically everything except the wipers... they were still working. And it most definitely was NOT a DIY a big job, but fixed a whole lot of niggles in the process
    10' Volvo V50
    15' KTM 250SX
    04' BMW R1150R
  12. #32
    Jan 2015
    Fought with the lift pump over the weekend. The right-hand bolt is a mission to get to without a suitably thin ratchet extension that can pass between the injection lines.
    Once that's out, getting the replacement back in without damaging the new gasket made for some tedious work; especially since I'm just too short to have proper footing when making those necessary little adjustments.
    I was also stupid enough to lose one of the no.11 bolts into my front axle mounts. I'll remember to pop a rag into that cavity in future!
  13. #33
    Hartbeespoort
    JTC I am also fixing my harness, removed the centre part of my dash but looks like I will have to remove complete dash, have a short in the main harness, found two burnt wires and am following them from engine bay to where ever its going under the dash, not easy, its an old problem thats draining my battery, will also look at the window ecu and blocked pipes as there is always water coming through and also remove my heater which is also leaking.......
    Ze'
    '98 Disco 300 Tdi "Stony"
    Ironman suspension, dual tanks/batteries, rr,rtt,snorkel, etc.....
  14. #34
    Jan 2015
    Quote Originally Posted by Ze' View Post
    Yes, unfortunately everything must go before you could actually work there!
    Hell of a job, but well worth it! I found 2 earth wires, that were litarally in pieces and a couple of other ones, that were barely making contact. Also if you want to replace your dash lighting with LED's, this would be the time!!!
    10' Volvo V50
    15' KTM 250SX
    04' BMW R1150R
  15. #35
    Hartbeespoort
    Yip, will look at everything that needs fixing ......thanks.
    Ze'
  16. #36
    Hartbeespoort
    Fixed harness and removed burnt wire, not easy as space is limited.While everything was open under dash I decided to open ECU box as per above video, found some loose connections and resoldered, had to be very carefull as it was difficult to remove the botton connector and in the process I damaged more connections and had to open it a few times , all fixed now, windows working well. Next will try to fix the heater as its leaking water.
    Ze'
  17. #37
    Jan 2015
    Talking SPIDER unit - Starting issues with 300tdi
    Okay, so my Disco now has 408,000 km on the clock and naturally there will be a few niggles with it by now. Though, I have to say that I am yet to find another vehicle of the same age which has held its age as well as this guy.
    However, there is one problem with a vehicle that will cause you to abandon the bloody thing right there and then and that is when an engine turns over, but won't start. Now, as we know a diesel engine requires three things to start: fuel, air and compression. So, when a 300tdi turns over, but won't start its likely that fuel isn't coming through. The first thing that usually comes to mind is that the little fuel lift pump has had it again; which is precisely what I would have thought had I not replaced it a mere couple of hundred kilometers ago. It turns out that the fuel-stop solenoid had shut off the fuel and the alarm ECU (spider) is the bugger that was responsible for this.
    "The spider unit is a small black box of relays, controlled by the immobiliser & alarm, mounted on a panel just in front of (toward the front of the vehicle) and below the radiocassette slot - a very inconvenient position which is designed to be very inaccessible to thieves in a hurry. This contains relays which isolate various key circuits of the vehicle; the feed to the fuel solenoid, and the feed to the starter solenoid on a 300Tdi, and ignition, fuel and starting circuits on a V8. A combination of heat, vibration and a not very good quality circuit board eventually results in a dry solder joint on the circuit tracks inside this unit, which often then get hot and burn out completely." - BogMonster at [http://forums.lr4x4.com/index.php?showtopic=86]
    LR sells a bypass unit for the problem, but its not very difficult to simply fix the little black box once you manage to get hold of it, which you'll have to do in any event if you want to fit the bypass unit.
    I had pretty much followed the instructions which this guy (as per the above link) had done a bloody fantastic job of explaining, re-soldered the dry circuit joints and that was that. Not so much as a hiccup since then.
    Side note: Upon re-installing the facia panel I'd left the aerial input on the far side of the right-hand blower and after manhandling everything back in, realizing my mistake only upon connection of the radio terminals, I had decided to leave it at that until I find a replacement part for the blower fan switch...
  18. #38
    Jan 2015
    Post Blower switch
    Does anyone have an idea where one might find a replacement blower fan-speed switch? Its made by siemens and the switch itself is usually sold as part of the fan assembly for some stupid reason; especially since this seems like the only part prone to problems.
    Also, has anyone done anything about the curling dashboard problem?
  19. #39
    Mar 2014
    Ermelo
    Thanked: 108
    Ask landylover on the forum, he has many d1 spares 0833006099
  20. #40
    Jan 2015
    Thanks Sam. Ek sal hom vra.
    Vandag het ek 410000km op die tdi se klok.
  1. To Disco 4 on not to Disco 4
    By CharlieBrown in forum Land Rover
    Last Post: 2012/07/17, 05:39 PM
  2. Gauteng 4X4 Community Dyno Day 31 March 2012
    By TwinDisco in forum Gauteng
    Last Post: 2012/04/12, 09:53 AM
  3. Buying advice Disco 2 vs disco 3
    By justcam in forum Land Rover
    Last Post: 2012/03/22, 11:23 PM
  4. Discovery 2: I just drove a Disco II td5..
    By petermoffat in forum Land Rover
    Last Post: 2010/01/19, 04:38 PM
  5. Disco II V8
    By karoo landy in forum Land Rover
    Last Post: 2009/12/29, 02:09 PM
