D3 died - Page 16
Page 16 of 22 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 LastLast
Results 301 to 320 of 430
Thread: D3 died
  1. #301
    Thanked: 31
    Quote Originally Posted by longclose View Post
    So a bit of tranny lube will save the engine...
    Just had my gearbox double flushed and new filter from LR (free) as I have 3rd gear judder (and still have it) including a metallic rasp on light throttle on and off from the TC. Will Dr Tranny fix the judder and noise?
    LR workshop foreman said this was normal...(the metallic rasp).. they are part of the same group who sold me the car so I am a little suspicious thoughts ELRICO?
    Lock up solenoid needs cleaning .
  2. #302
    Thanked: 441
    Quote Originally Posted by Defender110V8 View Post
    Why is it interesting now , I made the same observation last week and then I was an idiot
    Hi Defender110V8
    I would like an opinion from Sean on this. I am still doubtful, that the torque converter or gearbox is the guilty party for a crank snap. I personally believe that the flex plate will break, long before a crank would snap because of a gearbox related issue.
    Lets see what the specialist comes up with. If I would be wrong, I would openly state this on this forum. Nobody is perfect
    George Bosch
    Distributor for:
  3. #303
    Thanked: 8
    Well, now that I have read Peter's post I have perished the thought of using Poly-TFE in my V8 engine. My mind is made up to simply stick to Castrol Edge Professional A5 5w30 every 10k.
    2007 Disco 3 V8 s
  4. #304
    Jun 2013
    Empangeni
    It is so good to see someone else local with that same metalic rasp. I have found cases of it overseas and the most common diagnosis seems to be a chain rattle or something like that in the transfer case. And when people tried to get responses from the manufacturer and land rover...seems that the noise just becomes a characteristic and i havnt seen any case where it leads to a failure.
    With me it happens especially under gentle throttle in most gears...and then does it briefly when i take my foot off the throttle in slower driving. The sound does not change with speed etc...and is like u say a metalic rasp type sound. I took mine to land rover durban, land rover Empangeni, a gearbox and diff workshop in durban and another one in empangeni. No one really knows what it is and say its not gearbox or diff and nothing to worry about.... but id love to find the exact caus and find a solution!
    Ive considered taking a trip one day to see if Sean at gearbox co. can find a fix maybe?
    I had new torque converter fitted and flushed gearbox...changes smoothly with no judder etc...only this sound
    Regards,
    Noel
    2008 Discovery TDV6 SE for me
    2012 Kia Picanto for wife
  5. #305
    Jun 2013
    Empangeni
    Will this cure the noise or shudder...caus i have the noise but no shudder
    Regards,
    Noel
  6. #306
    Thanked: 441
    Quote Originally Posted by Noel Arbuthnot View Post
    Ive considered taking a trip one day to see if Saun at gearbox co. can find a fix maybe?
    Hi Noel
    contact Sean from the Gearbox Company in Midrand. He will be able to advise you.
    Sean [email protected] or 0118056000
    George Bosch
    Distributor for:
  7. #307
    Thanked: 31
    Dont know . Mine made a noise when changing to third that was still there , albeit quieter , after my torque converter was fixed . It was gone totally after the solenoid pack was cleaned .
    Most of the gearbox companies I contacted with my torque converter problems told me that they open up and clean out the gearbox at the same time as the torque converter . I suspect that most of the time they do not actually need to replace the torque converter , its just the solenoids that need cleaning .
    Borrow a trailer or a caravan and see what the gearbox does under load.
  8. #308
    Jan 2011
    Durban, Upper Highway
    Think I mentioned that I had the pan replaced and gearbox flushed by LR dealer last week, still had the judder and rasp. Just been down to The JLR Centre in Durban for other reasons they diagnosed the rasp as the EGR valve, and issued me Dr Tranny which I have just administered - it appears to be a magic cure, the gears change more positively and the judder has almost been eliminated after a 10k drive. Never been a believer in snake oil but this - so far so good.
  9. #309
    Jun 2013
    Empangeni
    Hi Noel
    Thanks i will give him a call. Pity i am other side of the country....bit if its something worthwhile i can always make a plan.
    My warranty pays up to R20k for gearbox or transfer case...so if he finds things needing fixing it might be worth while
    Regards,
    Noel
  10. #310
    Jan 2011
    See my post above.. The noise was diagnosed as the EGR valve and is a common problem according the The JLR Centre in Durban
  11. #311
    Fourways Gardens
    Thanked: 584
    Default Ptfe
    I came across this article regarding PTFE as an oil additive, makes for interesting reading, whether its true or not, you decide.
    http://www.carbibles.com/snakeoil.html
    Series III 88"
    Scout Nomad
  12. #312
    Jun 2013
    Empangeni
    So how does one cure the sound?
    Regards,
    Noel
  13. #313
    Jan 2011
    The EGR valve recirculates exhaust gases back into the engine to reduce NoX emissions. Not exactly familiar with the TDV6 but I believe they use stepper motors to operate a valve, these become noisy with age.
    A lot of people blank them off, this is what The Centre suggested, however I believe on post 2007 models which are Euro 4 compliant I believe it brings up a fault on the dash so just need to investigate further. Not too expensive to change as I understand if you do not want them blanked off.. this is what they look like..
    http://www.island-4x4.co.uk/valve-va...10-p-7112.html
  14. #314
    Thanked: 441
    Hi longclose
    no not on SA models, as they were not fitted with DPF's.
    By blanking off the EGR's you will save yourself untold grief. Blanking kits are available from most parts sellers such as British4X4, Dover, LP4A etc.
    Blanking off the EGR's and decatting the D3 were the first steps I took after we got the D3.
    For directly imported D3 and D4's with DPF, Bell Autoservices in the UK sell the blanking kits with a software patch.
    George Bosch
    Distributor for:
  15. #315
    Jan 2011
    Thanks George... that explains it...
  16. #316
    Randpark Ridge
    Thanked: 235
    I worked at a factory that assembled Brigs & Stratton lawn mowers, I even had a copy of the test.
    That's why I don't do unapproved, non scientifically tested additives.
    Discovery 3 TDV6 S G4 No 29 - Mine
    Discovery 4 TDV6 SE - SWAMBO's
  17. #317
    MTUNZINI
    Thanked: 463
    Yes Longclose that vienna sausage is absolutely magic.
    It even works in transfer boxes, and get stuck solenoids in ZF gearboxes t unstuck.
    Have to admit, tried it as a last resort and 70 000km later my gearbox is smooth.Its one additive I believe in , and cured a lot of gearboxes since , locally and abroad.
    EGR refers, once helped a Jeep wrangler owner , it sounded if the engine was seizing ,we all came to the conclusion it was running bearings or something, but it was a stuck EGR valve
    Koos Best
    Land Rover Discovery3 TDV6 S.
  18. #318
    Thanked: 441
    Quote Originally Posted by Koos Best View Post
    +1
    Koos told me about it 3 years ago and we used it with great effect on the D3 when Sean did the double flush.
    That red sausage is to gearboxes, what "the Muti" is to engines, manual gearboxes, TFC' and diffs (without LSD).
    Needless to say Sean uses both. Especially when fitting pilot shaft bushes .
    George Bosch
    Distributor for:
  19. #319
    Thanked: 44
    The continuous peddling of poly-tfe is getting a bit tiring...
    2013 Amarok d/c TDI 103kW 4motion
  20. #320
    Thanked: 182
    I'm very surprised by Peters findings. I have a huge amount of respect in that he's not dismissing his finding to "save" his reputation (which by the way will not be tarnished).
    In fact this type of thing makes me more confident in the way Landyworx has, and will treat my vehicle. Big up uncle Peter.
    On a similar note if you fell your D3 is too much of a risk to maintain, I suggest you put it up for sale at about R50k so I can buy it.
    Life's too short to drive boring...
    2011 Disco 4 SDV6 SE (iNyathi)
    2005 Disco 3 TDV6 HSE (Pepper)
    1994 Pajero 3.0 V6 (Ruby)
  1. A Namibian icon died today
    By Gert du Preez in forum Namibia
    Last Post: 2012/04/30, 01:31 PM
  2. Wrangler 4dr Jeep Died on Highway
    By Dionne in forum Jeep
    Last Post: 2012/04/07, 06:47 AM
  3. Discovery 2: Diesel tank "lift-pump" died
    By maverick in forum Land Rover
    Last Post: 2011/11/06, 03:47 AM
  4. Replies: 15
    Last Post: 2009/12/01, 12:23 PM
  5. Colt v6 died!!
    By segalmarisa in forum Mitsubishi
    Last Post: 2009/04/01, 04:49 PM
