Results 1 to 20 of 30
Thread: Shocked..
    Thanked: 48
    Default Shocked..
    I have late 2012 Jimny with 28000km on the clock and a 40mm spacer lift kit. I took my Jimny in to get the balancing done, etc at a Dunlop fitment center and asked them to check the shocks aswell. They said all the shocks are finished and need replacing (see attached report).
    It doesn't make sense... especially since I was forced to replace both the rear shocks just over a year ago to keep my warranty intact (they got knocked loose and I had them put back at another garage).
    Guys is this possible? Is it the lift kit putting extra stress on them? I seem to have to replace the Jimnys wear and tear parts all the time.
    Cape Town & Tulbagh
    Hey there
    I speak completely on foggy memory from previous threads, but as far as I know...
    The spacer lift kit, will put extra force (on extension) on the shocks, IF you used the standard length shocks. Hence, people put on longer shocks to accomodate the extra travel (and eventually hitting the end of travel) of the standard length shocks.
    When I considered the spacers now, I looked at shocks that are 40mm longer (which made it cheaper later to buy the 40mm longer coils).
    You will likely be good to go on longer shocks, since you hgave to replace now (and I hope/don't think shocks are too expensive) :/
    I hope someone will correct me if I am wrong (oh, of course they will).
    Hehehe:
    That sheet says that after 80 000km it should be damaged quickly, I am sure we can organise that.
    2014 Jimny JB43
    Stofpad undies
    40mm Amada Xtreme Suspension
    Goodyear Wrangler AT/SA
    Thanked: 48
    Hahaha! We have enough potholes here to damage them quite easily if neccessary
    HoneyDew
    Exclamation Important Notice - Leveling Kits
    Just Received this form LA Sport.
    If a Leveling Kit is not done correctly it can Cause Lots of Damage!!
    I will not trust anyone with my suspension - there's a lot of places that makes stuff like this, " O this is easy to make - Lets duplicate and Makes Lots of Money"
    when it comes to Suspensions and Control.... DONT Take Short cuts!!
    Rather go to a Fitment Centre that knows ( LA Sport / 4x4 Megaworld ... ex.) - Pay a bit more and you know you and your Family are safe!
Name:	LAS Important Product Notice - Leveling Kit Spacers - 01.jpg
ID:	338715   Click image for larger version.
Name:	LAS Important Product Notice - Leveling Kit Spacers - 02.jpg
    FordRanger T6 / 3.2 XLT 4x4 Auto.
    The 3Ton Gravel Road Monster over weekends.
    The Pavement Special in the week.
    Since March 2013
    ConquerorComfort.
    Camping instyle since January 2012.
    HAM CallSign: ZS6LSC
    ORRA CallSign:AG34
    <a href="http://www.fuelly.com/car/ford/ranger/2013/zs6lsc/172702" target="_blank"><a href="https://badges.fuelly.com/images/sig-metric2/172702.png" target="_blank"><a href="https://badges.fuelly.com/images/sig-metric2/172702.png" target="_blank">
    Cape Town & Tulbagh
    Indeed.
    BUT! Spacers are used widely, and 100% safe and fine, a lot of members use them, it's just a matter of using the longer shocks with them. It makes sense, the shock will be at it's extended limits way more often with a spacer, if it's shorter.
    I agree though, a reputable installer, or for shocks, someone like HiQ or whatever will do just fine, unless it's that kid at supaquick in Montague Gardens, *shiver*
    2014 Jimny JB43
    Stofpad undies
    Jan 2007
    Thanked: 354
    The spacer lift, adds spacers to the shocks as well, so no need for longer shocks.
    My shocks also only lasted 30000kms, but I do quite a lot of dirt road driving.
    I replaced them with Amada Xtreme's. It's the best mod I've done to my Jimny.
    Vic
  7. The Following User Says Thank You to saxj For This Useful Post:
    Weltevreden Park
    I also had a shock test done. Shocks finished had to replace 55 000km. Dealer replaced the shocks. Went back to the same Garage that did the shock test and did another shock test. Results came back .......... Shocks needs to be replaced.
    This was a well known tire place on Malibongwe, Strijdompark VW replaced the shocks.
    In short I dont trust these shock tests they do
    Cape Town & Tulbagh
    At least they used a device capable of generating a graph. Guy in bethlehem that tested my father's Isuzu shocks just pressed down on the front of the vehicle, and said "yup, worn"...
    2014 Jimny JB43
    Stofpad undies
    Mar 2011
    Walker Bay
    Thanked: 1266
    So you are pleased with Amada Xtreme's.
    What is the ride like?
    May 2012
    Thanked: 13
    I agree with Gerhard.
    I have witnessed many shock testers fail new shocks , saying they are worn and need replacing.
    I would stick to the old fasioned test of bouncing the vehicle a few times and see how many rebounds you get before it settles.
    Currently do not own a 4x4, driving a sedan
    Ex: 2013 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2012 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2013 Ford Ranger 2.2 XLS 2WD manual
    Ex: 2009 Mazda BT50 3.0 CRDi double cab manual
    Jan 2007
    Thanked: 354
    Quote Originally Posted by Mistral View Post
    I feel that the ride is a bit harsh, but their performance more than makes up for the slight discomfort.
    With the original shocks, I found it hard to maintain 60 on a badly surfaced dirt road, often thinking I was going to die if I kept to that speed. With the Amada's on the same surface, I can do 80 comfortably and only over 90 does it start to feel uncomfortable. But I do know that high speed on dirt can get you in to a world of trouble very quickly, so I tend to stay at around 60-70kph.
    Vic
    Thanked: 48
    I would stick to the old fashioned test of bouncing the vehicle a few times and see how many rebounds you get before it settles.
    That's what I am thinking as I don't notice anything wrong with the shocks or the ride...
    I do have the shock extensions as well as the spacers, pretty sure the lift kit is not causing any problems.
    Thanked: 95
    What would a set of standard replacement shocks go for a Jimny?
  15. #14
    Thanked: 2828
    drive 40km/h then brake hard. The nose must dive and when you come to a stop it must come up (one movement) and sometimes a small down movement as well. Any bounces more than that and the shocks are finished.
    Do the test in reverse to check the rear shocks.
    Pay special attention to the corners to check a singular shock that may be off.
  16. #15
    Thanked: 101
    I killed my front shocks in 12000km, actually drove the rubber bushes out of the shocks.
    Personally I think the standard shocks is useless for offroad use they wont last!
    Spend the extra money and get Tough Dog or EFS and you wont regret it.
    My 2c
    Zone Built JEEP 018
    ORRA AG42
    2013 Jeep JK Rubicon
  17. #16
    Thanked: 48
    Thanks for the tip! Will definitely try that out
  18. #17
    Cape Town & Tulbagh
    Keep us posted too, want to know if those shocks were actually wasted or if there's another place using crappy testers.
    Also, curious about what you're going to get as a replacement....
    2014 Jimny JB43
    Stofpad undies
  19. #18
    My problem with these mashines iho they dont carer for a sfa 1 tonne jimny.
    Suzuki Jimny - BS Dueler AT - Wizerd Steel Undies, Wizerd Rock sliders. Tough Dog Suspension, Front Runner Roofrack
    Suzuki SJ410 '84 - SOLD
    Nissan X-Trail 2009 (Lekker Kar Die)
  20. #19
    Thanked: 48
    No bounces.. I haven't noticed any unusual handling in fact
    That's what I was thinking, its seems weird that all 4 shocks are gone at the same time, I wondering if the machine caters the Jimny...
  21. #20
    Thanked: 87
    I have a set of std shocks and coils with 17000kms on if anyone wants to make me a offer?
    2016 Toyota Fortuner GD6 Auto
    2012 Jeep Grand Cherokee 3.0CRD
    2011 Jeep Cherokee
    2006 Jeep Grand Cherokee 3.0CRD-50mm EFS Lift, GDE Tune
    2009 Jeep Rubicon-50mm Coil Lift, Branches, Free Flow, K&N, MT`s
    2013 Suzuki Vitara-40mm lift
    2012 Suzuki Jimny-Fully Kitted.
    2007 Jeep Cherokee-Std
  1. Shocked
    By Miems in forum Motorcycles
    Last Post: 2014/07/11, 12:58 PM
  2. Replies: 6
    Last Post: 2012/06/23, 01:33 PM
  3. At last- Extreme Trail Weekend!
    By incrediblebob in forum 4x4 Trails / Routes / Clubs
    Last Post: 2011/12/15, 02:37 PM
  4. Replies: 29
    Last Post: 2011/08/12, 07:41 AM
  5. Michelle Shocked in SA
    By Tony Weaver in forum The 4x4 Pub
    Last Post: 2011/06/22, 05:21 PM
