2006 Mahindra Scorpio 2.6 Alarm problem
Results 1 to 10 of 10
    Jan 2015
    Elspark
    Default 2006 Mahindra Scorpio 2.6 Alarm problem
    Howzit guys,
    I need help with my alarm. This is the factory fitted unit. All the doors, windows, bonnit and back door are closed properly, when the alarm is activated. The car is parked and locked in the garage. The time frames and frequencies are irratic, but the alarm will go of for no reason. I've had an additional immobeliser fitted, as the standard alarm isn't recognised by insurance companies. The alarm still goes off after this was done. I've had the alarm tested and it was given clean bill of help. What else could it be?
    Aug 2008
    Check your battery, some alarms will sound if the voltage drops below a certain voltage.
    Jan 2015
    Elspark
    I've already replaced the battery, Scorpio Turbo. Any other suggestions?
    Oct 2012
    Standerton
    Check the driver door sensor... I had the same problem and as soon as I replaced the sensor problem solved
    Springs
    Also had the same problem took it in to dealer and they replaced the bonnet switch. All is good now..
    Does it have an IR sensor? I had issues with my Nissan Sani and the sensor picking up temp differences and it would activate the alarm for no good reason.
    Jan 2015
    Elspark
    Thanks guys, will check out your suggestions.
    I also had this problem...turned out to be one of the door sensors.... This is a very basic push in/out switch with rubber cover. One of them dirty. Sprayed all out with contact cleaner. no more issues.
    2009 D3 V8 SE - Family car, holiday and weekends
    2009 Mahindra Scorpio 2.6 GLX - Mom's Taxi
    2001 Ford Ranger 2.5 D/C - My Car
    2007 D3 TDV6 S - Family car, holiday and weekends ( RELUCTANTLY SOLD )
    Apr 2019
    westville
    Default Re: 2013 Mahindra Scorpio 4/4 2.6 Alarm problem
    I need help with my alarm. This is the factory fitted unit. All the doors, windows, bonnit and back door are closed properly, when the alarm is activated. sometimes when locking... it gives off 6 beeps. but it locks. after a while.. the alarm goes off. but when i lock again.. one beep and all is well. but i use only my door most of the time this happens. so it could be my door switch might be faulty. how do i clean the switch. ive checked battery terminals.. all good. battery is fairly new. any other suggestions might help. thanks mod
    Mar 2016
    Auckland
    Default Re: 2006 Mahindra Scorpio 2.6 Alarm problem
    When this happened to me with my 2014 scorpio and i took it in to be fixed, the mechanic showed me adjustable windy things (sorry don't know what they are called), that are inside the bonnet and doors to make them close neatly. If they are adjusted wrong, the sensor can be only just activated, and possibly flick to the other mode while the vehicle is parked. He adjusted them a little and the problem has not recurred.
  1. Ford Ranger alarm issues
    By The Bruce in forum Ford & Mazda
    Last Post: 2014/09/15, 11:15 AM
  2. Replies: 8
    Last Post: 2012/05/19, 05:58 PM
  3. 2007 mahindra scorpio 2.6 GL 4x4
    By dcsmax in forum Mahindra
    Last Post: 2012/03/29, 09:13 AM
  4. Mahindra Scorpio Problems
    By PJ_Kotze in forum Mahindra
    Last Post: 2011/05/04, 10:50 AM
  5. D2 Alarm problem
    By camelman in forum Land Rover
    Last Post: 2009/09/07, 03:38 PM
