Disco 1 300tdi Aircon Belt probleme
Results 1 to 6 of 6
    Nov 2014
    Thanked: 15
    Default Disco 1 300tdi Aircon Belt probleme
    Hi julle - eerste post op die forum alhoewel ek al lank lekker lees aan alles.
    So ekt einde laas jaar vir my 'n pragtige Disco1 300tdi gekoop en nou 'n week terug vir die eerste keer die langpad aangedurf met "Snaartjie" (want sy pluk aan my hart snare haha).
    Als goed gegaan en al te lekker in Kosi bay rondgeploeter maar oppad terug het die aircon belt in die helfte gebreek. In Ermelo gou weer die tensioner reggestel en 20km buite witbank my gasket geblaas sonder enige waarskuwing. Die aircon belt het toe deur die water pyp gesny onder die pulley.
    Ek wou nou gou hoor of enige iemand anders ook al moeilikheid met die aircon belt gehad het wat afspring en stukkend raak (die aircon belt wat gebreek het was splinter nuut).
    Thanked: 87
    Yep
    On my D1 300 tdi snapped an aircon belt and it cut the thin pipe going to the expansion tank
    You must must must must must must must must must must have a monitoring system fitted which includes water level
    Otherwise it will drain your pockets as well very fast
    They typically break because one of the two idler pulleys is seized or busy seizing so belt gets hot and boom
    Nov 2014
    Thanked: 15
    Yip, thats the same pipe that was cut on mine... Really missing my poor old landy now. Did you fit the Madman system or let someone else fit it?
    Thanked: 87
    I did it
    Very easy
    Has been in now for many years and saved me on many occasions
    Another place to watch on leaks is the fat pipe from the top of the radiator to the block as it goes over the top of the fanbelt pulley
    You can do the madman in stages so water level first
    Did I say first
    Then do the rest as you get money
    You can disable the features till you connect them
    Thanked: 87
    Turk
    Where did you take your landy for repairs ??
    Nov 2014
    Thanked: 15
    I left it at my uncle's workshop in Rayton. Quite knowledgeable - just usually takes forever..
  1. Discovery 2: Disco 2 without aircon
    By TaunB in forum Land Rover
    Last Post: 2014/01/02, 06:59 PM
  2. Disco 1 300tdi engine milage
    By kokop in forum Land Rover
    Last Post: 2009/03/27, 05:19 PM
  3. Replies: 3
    Last Post: 2009/01/07, 09:05 PM
  4. Replies: 8
    Last Post: 2008/10/27, 09:44 AM
  5. Starting issue on a 300Tdi Disco
    By henkc in forum Land Rover
    Last Post: 2008/08/21, 08:04 AM
