12 V - Trailer wiring ...
Results 1 to 8 of 8
    Jul 2010
    Gordons Bay as a base - travelling Africa
    Thanked: 92
    Default 12 V - Trailer wiring ...
    I've got an Echo electrical box that behaves weird, batteries are charged, when connected, 12 V doesn't work, only after pushing the MAN-start button, but as soon as the box is disconnected from 220 V, the 12 V is not working any more.
    We opened the box, exchanged the little fuse, but no success. Everything seems to be fine.
    Apart from my question did anybody had that phenomen before,
    I thought, I can connect the 2 12 V lights and the 2 Hella plugs directly to the battery.
    What wire mm and do I need to build in a fuse?
    May 2012
    pretoria
    Thanked: 64
    Contact Manie from HCDP Electronics in Pretoria, he manufactures these Power Panels for Echo
    Sounds like there is a problem with the connection between the hcdp panel and the battery. Check the fuse on the positive pole of your battery. I had the same problem and it drove me nuts until I discovered that the 80A fuse on the battery was damaged.
    2008 Mitsubishi Triton 2.5 4x4 SS
    Jul 2010
    Thanked: 92
    Thanks so far, will check out tomorrow
    When I avoid the box and wire the 12 V lights and the Hella Plugs directly to the batteries,
    what fuse size must I use?
    Thanked: 1702
    This might sound silly but check the battery leads where it plugs in to the board. I have had that plug come loose just enough to break contact but look connected. Unplug it and plug it back again just to be sure
    Henk
    Follow us on Facebook
    Jul 2010
    Thanked: 92
    Finally found the reason, while I stripped all in search of that 80 amp fuse (which we have only in one trailer), the negative connection of one battery was broken off.
    We had upgraded our batteries last year at the local Battery Clinic and they had taped (don't know the right word now)with cable channels, the leads nicely packed, x cable binders around, but one couldn't see the contacts.
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 177
    Suggest you get a 80 Amp fuse and get it on the positive lead between the battery and panel.
    Must be as close as possible to the battery.
    Seen a situation where the fuse was not in place and a short took place where the cables come out of the battery box, it was not run in the channel and the lid worn the insulation down.
    Almost a catastrophic situation at a campsite.
    PS - 50 Amp will also do the job.
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
    Jul 2010
    Thanked: 92
    Thought the same, can't understand why Echo does not build a fuse in.
    8 trailers only one with a fuse...
    Will do it when we "springclean" our trailers in the next weeks after holiday.
  1. Standard trailer wiring diagram (colour coded)
    By Cherokee in forum Camping, Fridges, Accessories
    Last Post: 2013/08/27, 07:33 PM
  2. Wiring Hilux DC for off road trailer on tow
    By jlo in forum Trailers, Caravans, Towing etc
    Last Post: 2013/04/21, 09:55 PM
  3. Reversing with a trailer behind your 4x4?
    Last Post: 2013/02/04, 12:51 PM
  4. Is it Legal to Tow a Trailer Behind a Caravan?
    By Doepie in forum The 4x4 Pub
    Last Post: 2012/02/05, 07:17 AM
  5. Wiring for fridge in off-road trailer
    By Blackie in forum Camping, Fridges, Accessories
    Last Post: 2011/08/15, 12:07 PM
