Building and energy efficient house
Results 1 to 20 of 95
    Dec 2006
    Durbanville, Otjiwarongo
    Thanked: 101
    Default Building and energy efficient house
    So we are looking at building in the next few years and already started the divorce proceedings... jokes (but we did check the prenup).
    Realizing that energy efficiency is too often added on afterward or as an after thought I want to design the house around security and energy efficiency.
    The security bit is another thread alone.
    House is in Cape Town, on a west facing slope.
    I was first thinking of building materials and style. Most fancy designer houses have parapet walls and after my current house and the sealing nightmares... never again. So the house will be standard brick and roof with large overhangs (balcony/ patio all the way around the house). These will keep the sun out the house and with roll down siding to keep the rain off the patio in bad weather.
    Face-brick.
    Roof will have North facing facet at optimum angle for solar panels, pool heating and geyser panels.
    Skylights.
    Fully insulated ceiling.
    And that's as far as I have got.
    I was thinking that a clever wall design with a fan could harness the South Easter.
    Betty's Bay, South Africa
    Thanked: 298
    Have you thought of a light steel structure? Building time halved and insulation capabilities good.
    Our website
    Contact us
    Join us on Facebook
    Stone Accessories operates solely as an ONLINE BUSINESS
    1996 Defender 110 300 tdi
    Mantec snorkel
    Bash plate
    Roof racks
    Diff guards
    Corner protector/bumper steps
    Water tank
    Bellville
    Thanked: 1773
    Your architect has a complete SABS code to GUIDE him with an energy efficient design.
    Some see this as a hurdle to overcome to build your dream home .... those that have been in Europe smile as these rules are not even half way where it should be !!
    we CAN build homes that are a LOT more energy efficient !!
    but rather spend 99% of the design time on esthetics .....
    The person to give you the BEST guidance is certainly MikeAG
    from an energy perspective - see how you can gel the following with your esthetics :
    - INSULATE the home.
    - STOP air leakage
    - PV is the way to go -
    * PV panels and 48V element to drive your geysers
    * PV panels, and a battery bank to drive a 12V light system for the whole house
    - Invest in modern fridges and freezers with inverter starters
    - Invest in a modern washing mashine
    one thing to bear in mind - in a "few years" the whole grid tied solar issue may have been clarified, and just maybe it might be worth it (NOT, if they stick to the current proposals)
    Dec 2006
    Thanked: 101
    Quote Originally Posted by Stone Accessories View Post
    There are a couple of methods to looked at. There is a new type of breeze block a friend is using to build his house from that is also much cheaper than brick.
    Of cource insurance is easier with brick.
    What roof material is the most efficient? I am talking about overall. No point in something being a super insulator that needs replacing every two years.
    Dec 2006
    Thanked: 101
    I am also looking at rain water harvesting. As the house is on a slope I can then use it for irrigation/ pool water without a pump.
    I also like the idea of using grey water for irrigation.
    Dec 2006
    Thanked: 101
    - STOP air leakage
    I have done some cursory research on this an applying my own logic, full PV or Solar and 12V DC means battery packs and and and while we still have a functioning grid I think batteries are a waste of money and essentially a very expensive consumable. By omitting batteries payback is a lot shorter.
    I am not sure how legal this is but a heard via a friend of a friends gardener that if you end up generating excess power from the panels, it actually runs the power meter backwards. So while eksdom is not buying it off you you are reducing your bill.
    May 2013
    Fish Hoek
    Since 2 years ago, the energy efficiency of a house is prescribed in South Africa's Building Standards . . it is not optional anymore, and your plans have to show the energy efficiency before the city of Cape Town will allow you to build.
    The simple rules are to keep the fenestration (glazed windows) under 10 or 15% of floor area. Minimal west-facing windows. Bedrooms and living-rooms with north-facing windows. (long rectangular floor-plan on an east-west axis). Roof overhang calculated to shade windows in summer but allow full sun in winter. (600mm wide eave, 400mm above window top works for Cape Town). 130mm "think-pink" on ceiling. Cape Town outer walls have to air-space cavity, which already does insulate somewhat.
    A 40 degree steep roof is great for solar panels. Also allows the tank to be neatly in the roof, without needing pumps for circulation.
    Hope your main sewer line is on the lower side of your sloping plot. Helps to drain sludge of grey water tank.
    Before designing for energy, consider designing for Cape Town's notorious wind from the south-east. A high pitched roof can be part of the anti-wind plan. If anywhere near the sea, consider corrosion-proof materials and avoid wooden window frames. (Quite different here to Windhoek)
    Paarl
    Thanked: 32
    Maybe investigate NewTec (SP) as well with the light steel frame building. The houses I have been in was very insulated and it made a big difference. While building maybe dig a large tank into the foundation in which you can store rainwater - no plastic tanks standing around the house...?!?!
    Enjoy the research and good luck!
    Ford Ranger
    Double cab
    2.2
    Stock standard (for now)
    Dec 2006
    Thanked: 101
    Quote Originally Posted by Christob View Post
    Sitting in a light steel frame building now... it just doesn't have the "safe as houses" feel to it. You knock the wall and if feels prefab. Looks great. I have aircon and a huge window so cannot comment on the insulation but just not sure about whether it will last like brick and mortar.
    Dec 2006
    Thanked: 101
    Quote Originally Posted by Gerald_D View Post
    But the View is to the West!! Plattekloof is the target suburb. I have a house there now but looking at moving (I am in Windhoek temporarily).
    The wind is a large consideration. I am thinking of a large U shaped building with the pool in the U and sheltered. The u will have the southern side longer than the northern side. If you have all the doors opening into the U you should not have a wind tunnel like most CT house seem designed to have.
    Winter sun will be through skylights.
    Apr 2014
    Friedrichshafen / Pretoria
    Thanked: 34
    Biggles, if you want send me a pm with you phone number, then we can chat. Over here in Germany we have unreal rules & regs concerning energy efficiency, insulation etc. I have looked into these as I contemplated building here.
    I currently plan a house to be build near Mosselbay, so there are a few similarities to your building plans, and I am concentrating on security and insulation.
    Suffolk, UK
    Thanked: 17
    There is a whole book to be written on the subject, rather than just a post on a forum, but as I have said many times on here, with your climate, it is child's play to design a building that requires zero space heating, zero cooling, and zero external inputs for hot water, yet remains at a constant comfortable temperature and has hot water whenever you want it.
    None...none......of your houses have enough insulation. No-one seems to be thinking about the huge differences in thermal performance between lightweight (ie framed) construction, and heavyweight construction. Insulation is a very long way from being the whole story with thermal performance: it has to be tied to thermal mass to get its full benefit.
    I would start with an externally insulated masonry wall construction, and control the amount of direct sunlight which reached it. I would have north-facing external sun-spaces for passive solar gain in the winter (you all know how chilly it can get in SA in the winter) which can be folded away in the summer. Of course, it would be double glazed. Those of you following my renovation thread know that I will be installing triple glazing, and a mechanical ventilation system with a heat exchanger to control ventilation heat losses. The latter also handles ventilation "coolth" losses. I doubt such stuff is available in SA.
    Anyway, this subject is my daily bread, so my over-arching advice would be to select your architect very carefully. If they don't aspire to producing a zero-energy building, then don't employ them. If they think that 130mm of mineral wool is adequate......don't employ them.
    "Mike for President" Freeflyd
    Bellville
    Thanked: 1773
    Mike sadly very FEW architects in SA has the first clue of "energy efficiency" ....
    THAT is why we now have "Energy efficiency Regulations" ... which is LIGHT WEIGHT.
    were involved with two homes for a person with homes in various countries and continents .... was almost sad to see the client fighting the architect to implement European energy efficiency principles.
    May 2013
    Fish Hoek
    Quote Originally Posted by Biggles View Post
    West facing windows grab hot sun in the afternoons, unless they are double-glazed and have special heat reflection. Overhanging eaves only work properly for north facing windows.
    May 2013
    Fish Hoek
    Here is a brief overview of Cape Towns energy efficiency requirements:
    https://www.capetown.gov.za/en/Energ..._01Mar2012.pdf
    Hillcrest, Malaysia
    Thanked: 5968
    And my son has a Masters Degree in Architecture and he specializes in energy efficient homes. He designs some of the countries best.
    He designed mine which is in build and broke ground today. see other thread.
    Mike we have spoken one to one on this.
    I really nead to put you two in touch.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Suffolk, UK
    Thanked: 17
    Awesome! That's so slack it looks like it was written in the 1950's.
    Gordon's Bay
    Thanked: 4378
    Quote Originally Posted by MikeAG View Post
    yeah, which is a godsend actually!!!
    don't forget we don't suffer significant interior / exterior temperature differences in most areas (places like sutherland excepted)
    in winter I light fires on the days when I am in danger of having to close the door and possibly put on long trousers.
    on hot days, I stick my feet in the pool and open some windows.
    on very hot days I get in the pool.
    I have normal brick walls and a thatch roof.
    Where Fluffy lives they wear jackets in anything under 30degrees and 80% humidity as they feel a bit chilly.
    On the other hand, my office has zero roof insulation (tin roof, 80 year old building) and there is no breeze it's a sauna in there.
    but, it has doors and windows, I've never had to stop working, and there is a brewery 200m away for the really bad days.
    I suppose that, carbon consumption wise, a load of open fires isn't the best, but I heated my place last year with R3 000 worth (150 quid) of wood, and it was obscenely warm.
    that included braaiing a lot.
    In SA massive insulation is wasted - our issues centre around dependance on municipal services, and , sad to say, that isn't going to improve soon.
    it must also be borne in mind - our power costs are still CHEAP compared to UK - solar systems and so on don't amortise nearly as well here...
    and , despite the doom sayers , it's not going to go up - it will remain cheap to appease the majority (poor) population. the errors will be paid for in tax (wealthier population that vote for the wrong party)
    no matter how much you spend on household alternative energy supply , we'll still pay for electricity - though tax and commodity.
    these are things to consider when looking at energy efficient houses in warmer climates - I am sure the MEd countries look at them the same way!
    Bellville
    Thanked: 1773
    EXACTLY !!!
    it is disgraceful !
    Bellville
    Thanked: 1773
    Fluffy GOOD to hear there are some that starting go this route.
  1. Thermally Activated Building Structures - Yeah!!
    By biltong in forum The 4x4 Pub
    Last Post: 2014/08/30, 05:13 PM
  2. Home Building the D.I.Y. way
    By imgreg in forum Alternative Energy Solutions
    Last Post: 2013/03/31, 03:41 PM
  3. Alternative Power Sources
    By pmdt83 in forum Environmental & Conservation
    Last Post: 2010/02/16, 10:18 AM
  4. We have to start living greener
    By Uys in forum The 4x4 Pub
    Last Post: 2009/06/05, 12:16 PM
