Results 1 to 20 of 36
    Germiston
    Unhappy Prado 120 Rear door sagging-Solution?
    Can somebody give me advice and solution to solve this, apparently common problem?
    Thanked: 568
    This should work :-)
    http://youtu.be/L2QY6bkLatk
    Germiston
    Thanks, good one.
    Still doesn't solve my problem.....
    Louis Trichardt
    Thanked: 82
    On the bottom hinge place two small washers between it and the body .You may need more or less depending on the wear.
    This solved my problem on the Prado 90.
    2003 Jeep KJ 2.5 CRD Manual
    2003 Jeep KJ 2.8 CRD Automatic
    Louis Slater
    Germiston
    Thanks, sounds like it can work, will give it a bash.
    Jul 2010
    Thanked: 111
    http://www.pradopoint.com/showthread...-rear-door-fix
    Here's a nice How-To on Pradopoint.
    Ockert
    Toyota Prado 120 4.0VX
    I did the washers on my 120 and it worked a treat, I put the washers in between the door and the hinge and not between the body and the hinge been fine for about 4 months now.
    Patensie
    Thanked: 28
    I bought two new hinges from Toyota and they install it with a new rear door rubber seal for less than R2000.
    Jun 2013
    Quote Originally Posted by Krummelpap View Post
    Did the same and worked perfect!
    Amarok 4Motion Auto -
    redelik wyd gegaan by Seikel!
    Audi Allroad 2.0TFSI - 'n tipe 4x4...
    Germiston
    Thanks guys, problem solved. This will help many Prado owners.
    joburg
    Thanked: 598
    Seam on the door splits causing door to sag to confirm this, open door and push it further open against hinge and watch the outer vs inner skin by bottom hinge. had same problem and replaced the door. TSA supplied the door free of charge my car was way out of warranty and no full Toyota service history, I just had it painted and spent weekend swapping door.
    Germiston
    How did you mange to do that, did you mail TSA ?
    joburg
    Thanked: 598
    Nope all done at dealer level. It's a well known problem with a Toyota Technical bulletin that was issued to their dealers, and I did suggest I may take it further as it was a design and manifacture fault. My car was 6 years old and had not seen the inside of a dealer for 3 of them at the time.
    Germiston
    Thanks, will phone my Toyota dealer. Only problem my Prado is 10 years old.
    what came of your phone call?
    Germiston
    Did the spacer method (added 2mm spacers to the bottom hinge)the weekend and problem solved, the rear door closes perfectly.
    Eldoraigne
    Thanked: 38
    did mine with spacer as well... Used a plastic vital vitamin bottle and cut two washers as the thinnest metal washers were to thick... Worked a charm. I would recommend the plastic rather than metal as it reduces rust issues down the line...
    JT
    Germiston
    I am glad that the spacer method works. I used galvanised washers, rust should not be a problem.
    Thanked: 119
    Best R2 and 5min mod I've ever done on my Prado.
    Thank you for the info, much appreciated.
    Feb 2017
    JHB
    Default Re: Prado 120 Rear door sagging-Solution?
    Hi All,
    Prado door is sagging now to the point where i have to lift it onto lock and push to get it to close, I.E I cant just slam it shut. It is probably sagging 2cm.
    There is also a 30cm crack in the door running up the weld by the hinges - is this a serious issue? It has been there for a while with no real harm.
    I have tried looking at this: http://www.pradopoint.com/showthread...-rear-door-fix .... But all the photos have been taken down.
    Any affordable suggestions?
    Kind Regards,
    James
  1. Prado 120 (2003-2009) Replacement bumper
    By Riaan Jacobs in forum Toyota
    Last Post: 2019/06/03, 09:48 AM
  2. Replies: 2
    Last Post: 2013/12/03, 12:41 PM
  3. Prado 120 Rear Brake Sticking
    By Heinri in forum Toyota
    Last Post: 2013/02/22, 07:58 AM
  4. An interesting TJ Jeep Article.
    By Big Hilux in forum Jeep
  5. Ode to my High-Lift Jack, it's red...which makes it good
    By Bob in forum 4x4 Recovery & Recovery Gear
    Last Post: 2006/09/13, 11:58 PM
