Results 1 to 20 of 25
    May 2007
    Springs
    Default head shaking ranger
    i developed a head shake @ 75 -80 km/h
    took the ranger in for wheel balance ...still that anoying head shake
    took it in again last week and had the wheels balanced with a highspeed balancer....still headshakes
    i spoke to a colleque of mine and he has the same problem, and that after a ford dealer had serviced his ranger,
    any ideas out there what the problem might be?
    May 2007
    Define the headshaking.
    I am not a complete idiot - there are still some parts missing
    Please don't send me a PM without direct contact details
    97 SVM 3000
    86 HiLux D/C
    Bethlehem
    Thanked: 162
    My previous Ranger had the same thing. Mine was worst in cold weather.
    After endless diagnostics and nothing fixing it, I replaced the tyres and the shake / shudder was gone. I had the new tyres on fot 10000km and the shake never re-appeared
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
    Thanked: 292
    Still got them Firestone's? They are notourious for their morning sickness...
    Nigel
    Thanked: 2511
    That was fairly common on the ATX Firestones I had on the 2700. It was explained to me that the steel belt and the rubber is very stiff after a cold night. So then the tyre has a flat spot. After driving and some flexing, the stiffness is gone and no more head shake. What a pile of crap.
    After fitting the BFG muds, no more problem.
    Uniglide
    +27 zero eight 2 four 95 9252
    Mozambique/Cape Town/Other
    Thanked: 19
    Never heard the term "head shake" before
    Oppierotse
    Thanked: 288
    Quote Originally Posted by Spike View Post
    Spike I think the Americans call it the Death Wobble (DW).
    98 Hilux 2.8D D/C 4x4
  8. The Following User Says Thank You to wiel For This Useful Post:
    Oppierotse
    Thanked: 288
    Do a Google on Death Wobble.
    Jun 2007
    Thanked: 50
    I had a bit of shake and some loose steering that was eventually diagnosed to and corrected by replacing a faulty ball joint.
    Doug Norval
    New & Used Car Sales Exec.
    HAVAL/GWM Fourways
    4ePajero Guest
    I had it on the Isuzu DC, but only on mild long turns to the right.
    Spent big bucks on wheel alignment, shocks, bushes and tests.
    The experience cured me of Coopers, because the moment I dumped them for other tyres, the Death Wobble was gone!
    Apr 2008
    Jhb
    Got the exact same but mine with Continentals 4x4 World Contacts.
    Altho HiQ DID tell me that the tyres were dodgy and NO amount of balancing could sort it out, make it a tad better yes but not for long. Swopped them for Scorpion AT's
    May 2007
    Springs
    i got those stones...firestones, but they are still brand new,with about 20000km on them....
    by buddy's got new michellins on his ranger.....
    eesh.......i tend to think a balljoint might be worn...
    btw...headshake means kopskud...van so aard dat jou tanne uit jou bek skud op 75km/h....
    i'll put new tyres soon, and i like bf's, i have them on the toyota (third set)
    Nov 2006
    Brackenfell
    What's the mileage on your Ford, Hennie 321?
    2010 3l D4D Hilux Raider DC, Burnco front bumper, Cooper STT's, Ironman Shocks and Coils, Stofpad Rocksliders and LCSP's
    <O></O>
    ORRA D04
    ZS1ASH
  15. #14
    May 2007
    Springs
    125000km...(one hundred and twenty five thousand)
    its a 2005 model supercab
  16. #15
    Jul 2007
    Gauteng
    it could even be tie rod ends that have worn ball joints.
  17. #16
    Nov 2006
    Brackenfell
    I am on 84 000 , just wondering about extending the warranty?
    <O></O>
    ORRA D04
    ZS1ASH
  18. #17
    Default Re: head shaking ranger
    Ford Ranger T6 steering wheel shakes badly left to wright from 90km the faster I go the worse it gets, took it to BOSCH they told me the upper and lower control arms are shot so they replaced them (Bushings and Ball joints), still the same so replaced the Shock and tyres still the same they wore due, took it back now 3 time 2 different places for balancing still the same problem any advice This Video is 100% what I am experiencing https://www.youtube.com/watch?v=vuMs...SentidoCritico and https://fordauthority.com/2020/02/fo...-wobble-video/
    Simon Thom
  19. #18
    May 2016
    Thanked: 3865
    I had this on my Isuzu 280 DT DC.
    Most pronounced when turning at 80-90 km/h.
    Only went away after I changed tyres.
    2006 VW Touareg V10 (Sold)
  20. #19
    Jan 2014
    Ezulwini Eswatini
    Thanked: 3198
    Quote Originally Posted by SimonJThom View Post
    Since you have changed tires, balancing, suspension components ( if its all been done correct) the only other item that may cause the steering vibration are perhaps the brake rotors/disks are unbalanced or slightly warped. A skim should fix.
    Is there a shudder when braking ?
    Mr. Karol Joszkowski
    2011 VW Touareg V.8 TDI
    2006 VW Touareg 3.0 TDi air suspension aka Pumba ( sold)
    2003 Pajero IO 2.0 aka Bosvark
  21. #20
    Jan 2016
    Pinetown
    Thanked: 435
    What size tyres are you running?
    Have you changed them recently?
    I experience the same thing and after much frustration discovered that my tyres had a maximum spec for rim width. And I was out of that spec, changing rims seems to have solved that issue.
    Si Vis Pacem Parabellum
    2012 Hilux 2x4 D/L
    A few basic mods.
  1. Ford Ranger 2.5D Head WANTED
    By jp_bez in forum Ford & Mazda
    Last Post: 2011/08/08, 06:16 PM
  2. Defender headACHe (Another Cylinder Head) Issue
    By trilix in forum Land Rover
    Last Post: 2011/07/04, 10:05 PM
  3. 2004 Ranger 2.5TD Head cracked
    By bushcamp in forum Ford & Mazda
    Last Post: 2011/03/24, 10:45 AM
  4. Copper Gasket
    By Acrorellik in forum Vehicle & Technical Chat - General
    Last Post: 2009/10/19, 07:21 PM
  5. Head Gasket Blues
    By benhur in forum Toyota
    Last Post: 2007/05/10, 08:32 AM
