Page 3 of 3 FirstFirst 1 2 3
Results 41 to 50 of 50
  1. #41
    Feb 2017
    Default Re: Freelander 2 Reduced engine performance
    I have also had loads of little niggles, which other older cars do not display. Frustrating, but mostly the extra R10k per year is a real pain in the butt!
    Thinking the same as you now... td4 HSE 2008 with 160000, do I dump it now or hang another 2-3 years and worry about the next fix?
    I was Offered R120k trade, its worth way more than that, but will someone pay it??
  2. #42
    Aug 2015
    Hermanus
    Even my Landrover mechanic says he owns an older vehicle, the wife has the newer small car that's fuel efficient.
    He says these modern vehicles shouldn't be kept past it's warranty or service plan period!
    He's obviously seen how much money goes into replacing these electronic components.
    The previous owner had to replace the gearbox(automatic) at over R20k.
    The price we pay for comfort and luxury...
    So I'll take my time to sell the vehicle and get an older Isuzu our Toyota... You should get a little more for yours I think Moghul
  3. #43
    Aug 2020
    Exclamation Re: Freelander 2 Reduced engine performance
    Good day all,
    I bought a FL2 2009 SE TD4 179000K last month from a friend and it had problems with starting. The "reduced engine performance" and "low engine performance" would appear on the panel sometimes. 3 weeks ago had to change the solenoid kit and plunger by an auto electrician.
    Today the car wouldn't start again! this time the starter is working but the message of low engine performance keeps showing.
    The difference here is my car never showed the "Reduced engine performance" while driving. It only happened when I was about to start the engine.
    Your advices is highly appreciated.
    Thanks,
    Omid
  4. #44
    Mokopane
    Thanked: 375
    Check fuel, can run out of diesel when below half if the fuel transfer fails, fill tank and bleed through.
    Die reën is 'n dag nader as gister.
  5. #45
    Thanked: 625
    FL2's need to be taken care of by someone that knows then inside and out - your run of the mill mechie or autolec might just stuff it up.
    Si vis pacem, para bellum
  6. #46
    Jan 2007
    Thanked: 116
    My son's FL2 also came up with the same engine warning and then went into limp mode. The indy diagnosed it immediately as teh diesel filter. Apparently quite expensive and therefore often not replaced. Replaced it and the problem was gone. If you have replaced it for quite some time, a relative cheap fix to try.
  7. #47
    Thanked: 945
    Quote Originally Posted by Cobus Gouws View Post
    FL 2 diesel filter can be bought from LP4A, not so expensive .
    2006 Disco 3 SE V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2012 Tourer SP
    2013 Freelander SD4 SE
    2013 Freelander SD4 S (SWAMBO)
    ORRA Z07
  8. #48
    Jan 2007
    Thanked: 116
    Yip..intussen geleer. Dit het darem die probleem opgelos.
  9. The Following User Says Thank You to Cobus Gouws For This Useful Post:
  10. #49
    Mar 2013
    Kimberley
    Hi, how safe is this procedure? I’ve used quick start before and it races the engine.
    Wikus
    Quote Originally Posted by Siva Pillay View Post
    Remove the air intake valve , after the air filter, and keep the vehicle idling at a constant 2000 rpm, then spray quick start spray into the air intake pipe at short bursts of about 5 seconds at a time , at 1 minute intervals. you will notice the revs increase each time you do this. use up the whole can of spray. the fuel consumption improved quite considerably as well a 100 to150km more on a full tank.
  11. #50
    Jun 2024
    Default Re: Freelander 2 remap
    [QUOTE=Baben;3031909
    Hi Baben
    Hope you are well
    I would like to get my 2010 FL2 td4 auto remapped, vehicle is doing 113000 Kms
    Do you still do the remapping.
    Thanking you in advance for any advice
    Muhammad
