what have you done with / to your Range Rover (Big Body) today - Page 20
Page 20 of 21 FirstFirst ... 10 11 12 13 14 15 16 17 18 19 20 21 LastLast
Results 381 to 400 of 406
  1. #381
    Here
    Thanked: 651
    Default Re: what have you done with / to your Range Rover (Big Body) today
    Quote Originally Posted by dieterf View Post
    Watched my daughter drive into a pillar
    At least it's not as bad as your daughter watching an old (should be dead) fŕaaaart purposfully driving into your 322 because he hates people in large SUVs.
    Most of that can polish out. After a respray
  2. #382
    cape town
    Thanked: 434
    Quote Originally Posted by 2beFree View Post
    yeah-true!
    when she apologised again the next day via whatsapp, i replied:
    Hi. MorningIt happens, all ok 👍
    One day when I'm a dithering old fool I might crash yours 😉
  3. #383
    Thanked: 880
    yikes...
    this is why I fit VPS to my vehicles - food for thought.
  4. #384
    Cape Town Southern Suburbs
    Thanked: 1135
    Quote Originally Posted by nedge View Post
    Cleaned out the sunroof drain tubes, some really nasty stuff came out. Mine was blocked so badly that I have to remove the drain tube from the sunroof so that I could get in with some compressed air to blow it clean.
    Quite easy to get at, remove grab handle and sun visor. Pull down the headliner just enough to get to the tube. Tube simply pushes onto the sunroof.
    Do yourself a favour and just clean them periodically. If they are not blocked easy way to clean is just a bottle of warm water with some degreaser, pour down each drain and Bob's your uncle.
    Don't use compressed air to clean out the tubes, if you are doing it from the top of the sunroof. This can cause the tubes to be blown off the drain nipples of the sunroof. Rather use some weed eater cord and gently feed it down.
    Will save you a lot of grief, if they are blocked water can run down the back of the dash and cause havoc with the electricals. Attachment 551091
    I learnt this lesson the hard way with another vehicle, compressed air down a blocked rear windscreen washer pipe, the pipe was blown off a connector in the roof lining, what a pita to reconnect that one.
  5. #385
    Here
    Thanked: 651
    yeah-true!
    Hi. MorningIt happens, all ok ��
    One day when I'm a dithering old fool I might crash yours ��
    Well said
  6. #386
    Here
    Thanked: 651
    Replaced all spark plugs but still got OBD2 codes P0316 and P0307. Then replaced piston #7's ignition coil pack. Running smooth again.
  7. #387
    Witbank
    Thanked: 205
    Took her for a drive to work this morning and noticed that she never really got to temp. Thats after about 30km of travelling at about 80-100km/h.
    It was pretty cold between 0 and 2 degrees, but surely the thermostat should allow the engine to get up to temp a bit quicker than that?
    I did ask my indie about it a while ago after a trip to Dullstroom in a very cold storm where she also battled to keep temp even at 120km/h. He recons its normal owing to the size of the radiator, but I am not convinced.
    On the way home with outside temps being about 18-22 degrees, she was up to temp in the first 2km.
    Also noticed that the heater only really works on the drivers side, passenger side stays cold. And the heater doesn't really get that hot unless you start using her a bit harder, holding gears higher revs etc.
    Anyone else have this issue or should I start looking for a new thermostat? Any other ideas.
    She is a 2006 4.4 v8, the Jag v8 not the BMW one.
  8. #388
    Tzaneen
    Thanked: 293
    I would start with the thermostat.
    Our MB200K and the FL2 had the thermostat fail,and was only noticed in winter.Both cars took some time to get some heat into the system....had to drive hard and still took time .Replace the thermostat.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  9. #389
    Witbank
    Thanked: 205
    Quote Originally Posted by DiscoFrans View Post
    Thanks, ordered a thermostat today from Dover, will fit as soon as it arrives.
    Even if it is not the thermostat why risk the whole engine for something that cost a few 100 bucks. Engine has just ticked over 240k km so new thermostat is due anyway.
  10. #390
    Witbank
    Thanked: 205
    Replaced the thermostat, running like a beauty again, with fully functioning heater.
  11. The Following User Says Thank You to nedge For This Useful Post:
  12. #391
    Thanked: 880
    Name:  Tierkloof 4x4 20200616_115349.jpg
    went off-roading at Tierkloof yesterday
  13. The Following User Says Thank You to Orxy For This Useful Post:
  14. #392
    Thanked: 880
    Went off-roading on Tuesday:
  15. The Following 2 Users Say Thank You to Orxy For This Useful Post:
  16. #393
    Thanked: 880
    And because lockdown is so boring...
  17. The Following 2 Users Say Thank You to Orxy For This Useful Post:
  18. #394
    Witbank
    Thanked: 205
    Is that a stock exhaust on her?
    Sounds great.
  19. #395
    Thanked: 880
    Sounds great.
    No, I had the resonator(?) & centre silencer replaced with straight pipes.
    It does tend to cause small children and dogs to run away scared
  20. #396
    Aug 2011
    Dowerglen
    Thanked: 793
    That sound..!!..
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
  21. The Following User Says Thank You to Marcochezzi For This Useful Post:
  22. #397
    Thanked: 880
    Gents, if the engine has been working hard, is it normal for the non-aircon air to be hot?
  23. #398
    Aug 2011
    Dowerglen
    Thanked: 793
    Warm probably, but properly hot hot I imagine no..
  24. #399
    Thanked: 880
    Quote Originally Posted by Marcochezzi View Post
    hmmm, maybe they replaced the filter incorrectly during the service?
    The next day we went off-road and the engine was working hard, but the fan was blowing hot air even though it was freezing cold outside.
  25. #400
    Aug 2011
    Dowerglen
    Thanked: 793
    Honestly cannot remember clearly but if I vaguely recall the L322 pollen filter is in the center rear of the engine bay just below the windscreen, check to see if they 1. closed the cover correctly, 2 - inserted all the rubber seals that run from the left to the right of the panel, let me see if I can find some pics of mine..
  1. Replies: 4
    Last Post: 2015/01/04, 04:27 PM
  2. Reach for a dream 8 March 2014
    By RangeRover in forum Gauteng
    Last Post: 2014/06/02, 01:24 PM
  3. Range Rover classic body pannela
    By RangeRover in forum Land Rover
    Last Post: 2012/11/12, 05:16 PM
  4. Range Rover Classic Body Mounting Rubbers
    By Stubbzie in forum Land Rover
    Last Post: 2011/10/04, 08:08 PM
