what have you done with / to your Range Rover (Big Body) today - Page 8
Page 8 of 21 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 141 to 160 of 405
  1. #141
    Witbank
    Thanked: 204
    Default Re: what have you done with / to your Range Rover (Big Body) today
    Quote Originally Posted by Benson View Post
    Is it possible to fit 18" rims on the big body RR
    As far as I know 18" will fit on the non supercharged models. The big brembo brakes on the SC models only allow for minimum 19".
    Should be able to fit Disco 3 18" rims.
  2. #142
    Thanked: 145
    Great. Anyone Interested in a set of 5 rims with tyres?
    My wife is simple, in a complicated way
  3. #143
    Thanked: 451
    Hi All
    did a trip to PMB last week, where Mike (Mike Mechanics) and myself were modifying a Vespa PX125 cylinder for my Scooter in Switzerland. After a scorching 38.5 Degs in Pretoria on Monday last week, I drove down on Tuesday morning. After some 200km of driving around PMB/Wartburg was on my way back to PT on Wednesday.
    In Harrismith I had to fill up for the first time, as I would not have made it to Villiers.
    Fuel consumption was 9.1lt and the rig was performing faultless. Now sitting at 300'000km.
Name:	2018-01-09 09.52.54.jpg
ID:	473907   Click image for larger version.
Name:	2018-01-10 13.59.04.jpg
    George Bosch
    Distributor for:
  4. The Following User Says Thank You to hgbosch For This Useful Post:
  5. #144
    Thanked: 145
    18" rims fitted. And a set of Johnson rods.Click image for larger version.
ID:	474860Click image for larger version.
  6. #145
    Here
    Thanked: 650
    Very neat Andre...
    Do you have BREMBO brake callipers up front (standard for the 4.2SC) If so what did you do to get the 18's to fit
  7. #146
    Thanked: 145
    Nope. Ended up that I bought a 4.4 on the auction even though it was promoted as a 4.2. So the 18"s just slipped on.....
  8. #147
    Here
    Thanked: 650
    Very lucky boy, you are
  9. #148
    Thanked: 145
    Anyone have a spare suspension pump?
  10. The Following User Says Thank You to Benson For This Useful Post:
  11. #149
    Here
    Thanked: 650
    Tel No:+27 (0)12 800 1255 / 4645
    Fax No:+27 (0)12 800 4498
    Cell No:082 397 7511
    Contact:Antionette
    Address:90 STORMVOEL ROAD, EAST LYNNE, PRETORIA
    Andre contact AutoEzi in PTA. They should have and is currently breaking up a TDV8, so you might be able to get a newer one
  12. #150
    Witbank
    Thanked: 204
    Noticed my sunroof wasn't opening all the way and wasn't closing with the one touch like it should.
    Turn out when it went in to have the hail damage fixed, the panel beaters disconnected the battery and it lost its preset positions.
    Quite a simple fix, hold in the tilt button for about 20sec until motor moves slightly. Then all the way back and one touch forward.
    Also tightened the rear tailgate as it was rattling a lot. Much better now, back to driving in silence.
  13. #151
    Thanked: 451
    Hi Benson
    you have the "BMW" RR with the 4.4 engine. This has the same compressor as the Disco2. I do have repair kits for that unit. If the electric motor runs, all that is needed is the replacement of the piston ring.
    Let me know
    kind regards
    George Bosch
    Distributor for:
  14. #152
    Thanked: 451
    Currently roaming around in the Drakensberg. Left Pretoria last Saturday and drove down to Winterton. Fuel consumption a meagre 8.9lt/100km.
    George Bosch
    Distributor for:
  15. #153
    Thanked: 145
    Hi Benson
    Let me know
    kind regards
    that would be great.v
    Simptoms are as follows.
    Pump seems to be overheating.
    She gets everything up. But 10 minutes later. The nose dives and that's it. She keeps the back up.
  16. #154
    Thanked: 145
    It never ends it seems..
    Parked it at work this morning, and heard a loud hissing sound from the right front wheel. she's as low as she can go, so I can't see anything, but I presume then the shock is leaking air? and as such the pump is overheating to keep it up?
    Could it be something else apart from the shock?
  17. #155
    Witbank
    Thanked: 204
    If you are very lucky could be a damaged pipe or loose fitting. If the sound came from the drivers side wheel. The valve block sits just inside the rear of the wheel well. Could be a leaking valve block.
  18. #156
    Here
    Thanked: 650
    Quite possible the bags had never been replaced. They seem to last about 10 years. Replace both front ones as the second one (if bags) will go soon as well. If the shocks are still good then you can just replace the bags.
    The right front bag is always the first to go.
  19. The Following User Says Thank You to 2beFree For This Useful Post:
  20. #157
    Dowerglen
    Thanked: 732
    This is what I paid for the 2 front airbags (just the bags - no shocks) from LR in October..
    Still have them sitting on my shelf waiting to be changed..
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
  21. #158
    Thanked: 145
    Ooish. Can get two compete shock woth bags for R9000
  22. #159
    Dowerglen
    Thanked: 732
    Get them, my shocks have the electronically controlled damping snake oil inside, I think they want about R23K per complete strut... absurd...
  23. #160
    Thanked: 145
  1. Replies: 4
    Last Post: 2015/01/04, 04:27 PM
  2. Reach for a dream 8 March 2014
    By RangeRover in forum Gauteng
    Last Post: 2014/06/02, 01:24 PM
  3. Range Rover classic body pannela
    By RangeRover in forum Land Rover
    Last Post: 2012/11/12, 05:16 PM
  4. Range Rover Classic Body Mounting Rubbers
    By Stubbzie in forum Land Rover
    Last Post: 2011/10/04, 08:08 PM
