what have you done with / to your Range Rover (Big Body) today - Page 7
Page 7 of 21 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 121 to 140 of 405
  1. #121
    Thanked: 451
    Default Re: what have you done with / to your Range Rover (Big Body) today
    Quote Originally Posted by Benson View Post
    Got a new oil cooler from Grand Mark. Not even BMW could help me.
    Attachment 471776
    Bought 5l of normal atf and just ran it through the system for a semi flush. A lot of water contaminated oil still cane out. So much I was afraid it could be more damage than just the fluid cooler. Then I sat down had a beer and realized that the bloody filter is probably still full of it.
    Do I have to replace the filter? It was done in Dec 2017
    Or will it just work through?
    Hi Benson
    you will need to drop the sump on the gearbox and remove the valve body to have it serviced. Failure to do so will cause problems due to the coolant contamination. The best place to do that would be ZF.
    Next time you are in Pretoria swing past my place and can I can then disable the the seat and steering column comfort settings for you. I have the special diagnostic software (RSW Solutions) for these units.
    Good luck!
    George Bosch
    Distributor for:
  2. #122
    Thanked: 451
    Mine only goed up to 75l even though it takes a 100l when filling up.
    Hi Benson
    that would be the tank level sensor playing up.
    George Bosch
    Distributor for:
  3. #123
    Thanked: 145
    Put everything back together and she gears and runs
    Only see a stream of oil down my driveway.
    The bloody oil cooler is slightly different and the one pipe did not handle the pressure and came off.
    Can I cut it and clamp it?
    It has a slight curve and the existing bit does not fasten properly
    My wife is simple, in a complicated way
  4. #124
    Thanked: 451
    Hi Benson
    take heed of my comments about the valve body. Failure to do so will land you up with a full gearbox rebuild. Budget around R30K for that should the proverbial hit the fan.
    I have earnt my t-shirts on autoboxes
    George Bosch
    Distributor for:
  5. #125
    Thanked: 145
    Hi Benson
    Undoubtedly. But there's no one in Bloem that I would trust with an Auto box.
  6. #126
    Thanked: 145
    Would this oil be sufficient?
  7. #127
    Thanked: 451
    Hi Benson
    Your rig got the ZF 6HP26 6-speed box. You will therefore be looking for at a Dexron 6 ATF. Basically the same ATF as in the D3's. You will have to look at the rear of the bottle where it gives the spcecs to see what ATF it is.
    Good luck!
    George Bosch
    Distributor for:
  8. #128
    Thanked: 145
    Okay cool. These are specs by VW for the same box.
    I have the ZF 5HP24 box in mine.
  9. #129
    Thanked: 451
    Hi Benson
    ok then your unit was built before July 2005.
    Ask Sean from the Gearbox Company on what oil to use. He can assist you there. Top shop and very willing to help. Also found him to be honest and keeping to his word. I.e. he comes highly recommended
    Just for your info, the diesel variant of your model used the BMW M57D30 motor (straight six) and was fitted with a GM 5L40E 5-speed box. That is the one I got.
    George Bosch
    Distributor for:
  10. #130
    Thanked: 145
    Did the whole change and flush again. Took her for a spin. She is smoother than ever. So now holding thumbs for the next few 100km's.
    On Monday she will return to the mechie to do the whole thing again.🤞
  11. #131
    Thanked: 145
    Do you guys perhaps know the capacity of the gearbox?
  12. #132
    Thanked: 145
    Will be taking the old lady out for a leg stretching this weekend.
    Quick question, with these 19" rims, what tyre pressuresnare are safe for and adviced when offloading. I'm thinking around 1.2-1.5 bar.
  13. #133
    Witbank
    Thanked: 204
    Hi benson,
    I haven't had a chance to take her properly off road yet, but I would think, rather have thwm a little harder, 1.5 - 1.8. It's a heavy vehicle.
    Best would be to gauge by side wall deformation. Some tyres have stronger side walls than others and this must be kept in mind.
  14. #134
    Thanked: 145
    True, I have a very soft set on, so 1.8 would be do the trick.
    Now next question. Would the Expedition roofrack in the classifieds fit the L322?
    http://www.4x4community.co.za/classi...o-3-or-4/cat/5
  15. #135
    Witbank
    Thanked: 204
    Two ways to find out is see if you can get dimentions from the seller, not sure if height will be same disco and fattie.
    Alternatively as far as I know that is an OEM roof rack, could cross- reference part numbers with a dealership.
  16. #136
    Krugersdorp
    Thanked: 144
    Quote Originally Posted by 2beFree View Post
    Is that a SC?
    Not sure, too many differences to the Supercharged.
    1. First off, no Supercharged badge at the back.
    2. 19" Wheels on the car, Supercharged came with 20" (255/50R20) wheels.
    3. Does not have the Supercharged's mesh grille or frosted rear lights.
    4. If the oil cooler is BMW sourced, it is definitely not an SC. The SC engine was Jaguar sourced.
    5. SC definitely had the ZF 6 speed box fitted, not the 5 speed.
  17. #137
    Thanked: 139
    Neglected the RRSC since we bought the "toy".
    Will give her (or is it him) a bit of attention by cleaning it over the weekend.
    2007 Disco3 (SWAMBO)
    2004 Merc platkar (SWAMBO) - no more
    gti-eater (opel gte)
  18. #138
    Thanked: 145
    She behaved beautifully
    Never had to Rev her in an obstacle. The power of this motor is incredible.
    https://youtu.be/06dcpbyLKdk
    https://youtu.be/4N4cpBxJ_Ew
  19. The Following User Says Thank You to Benson For This Useful Post:
  20. #139
    Thanked: 145
    But sadly I must say, the tyres perform well apart from the sidewalls. These rubbers are darn soft.Name:  IMG_2832.jpg
  21. #140
    Thanked: 145
    Is it possible to fit 18" rims on the big body RR
  1. Replies: 4
    Last Post: 2015/01/04, 04:27 PM
  2. Reach for a dream 8 March 2014
    By RangeRover in forum Gauteng
    Last Post: 2014/06/02, 01:24 PM
  3. Range Rover classic body pannela
    By RangeRover in forum Land Rover
    Last Post: 2012/11/12, 05:16 PM
  4. Range Rover Classic Body Mounting Rubbers
    By Stubbzie in forum Land Rover
    Last Post: 2011/10/04, 08:08 PM
