what have you done with / to your Range Rover (Big Body) today - Page 6
Page 6 of 21 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... LastLast
Results 101 to 120 of 405
  1. #101
    Thanked: 145
    Default Re: what have you done with / to your Range Rover (Big Body) today
    Found ourselves at an auction looking for a truck for the business. sadly no good ones around, so we stuck around as we saw a RR on the auction list. well the rest is history, she approved of our drooling all over her and subsequently followed us home.
    She's a 2005 Range Rover 4.2 Supercharged. and all she for roadworthy was 2 new tyres. i fitted 255/55R19 General Grabbers and I am actually impressed with.
    I only have one question, the Navigation cd is in the back, but the head unit still asks for one to be fitted.
ID:	469104   Click image for larger version.
ID:	469105   Click image for larger version.
ID:	469106   Click image for larger version.
ID:	469107   Click image for larger version.
ID:	469108   Click image for larger version.
ID:	469109   Click image for larger version.
    My wife is simple, in a complicated way
  2. #102
    Here
    Thanked: 650
    howzit Andre
    Congrats that does look nice?
    Is that a SC?
    Re: the NAV CD
    1: Check for any moisture/dampness in and or around the connections and components in the back
    2: Disconnect (after the car had been asleep fir a good few minutes) the battery and reconnect 5 minutes later and let the units reboot and see if that helps
  3. The Following User Says Thank You to 2beFree For This Useful Post:
    HPM
  4. #103
    Thanked: 145
    Quote Originally Posted by 2beFree View Post
    howzit Andre
    Is that a SC?
    Re: the NAV CD
    Ad for as the paperwork reads, yes the SC.
    Goes really well. Consumption is not that great though.
    I'll give it a go. Have to enable my nanocom as well for the RR then at least I can monitor a few things.
    I have been reading up a bit, seems the oil cooler leaking into the water is an issue. How would I go about sorting that out before I loose an engine?
  5. #104
    Thanked: 145
    I am looking for a roof rack and nudge bar like these in the pics.
  6. #105
    Here
    Thanked: 650
    Quote Originally Posted by Benson View Post
    Consumption: Ya well
    Oil Cooler: I believe the issue you refer to is related to the TDV8. I have not heard of or read about the 4.2SC leaking oil into the water. I would suggest you have the FATTY serviced and inspected, inclusive of the gearbox and related components.
    The only oil leak I have had in 3 years was a few months back when the gasket on the gearbox sump went.
  7. #106
    Thanked: 145
    a nice full system reset was successful :-)
    Satnav and all and all is working perfectly.
  8. #107
    Thanked: 2126
    And they say RR's are complicated to work on.
    Very nice RR, would not mind one myself.
    My name is Rainier and I drive a Frotuna.
    Why are you always in such a bad mood? Experience...
  9. #108
    Jul 2010
    Modders
    Thanked: 251
    Lovely vehicle probably picked it up for a steal as well
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  10. #109
    Thanked: 145
    What does it mean if the battery light is flickering. I fitted a new battery yesterday
  11. #110
    Here
    Thanked: 650
    Could very well be the alternator. Have it checked out asap.
  12. #111
    Thanked: 145
    Full service and a gearbox oil change
    R2680
    Who cares about the extra consumption
  13. #112
    Here
    Thanked: 650
    Lucky #7
    May there plenty more
  14. #113
    Thanked: 145
    Lucky #7
    Mine only goed up to 75l even though it takes a 100l when filling up.
  15. #114
    Here
    Thanked: 650
    Capacity is 104L. You could have a sender unit (in tank) fault or suspect wires leading up to the sender unit if it only registers up to 75L.
  16. The Following User Says Thank You to 2beFree For This Useful Post:
  17. #115
    Witbank
    Thanked: 204
    Trip down to the Robertson's yesterday from Witbank. Average fuel consumption 8km/l actual and according to thw on board pc 8.4km/l.
    Really not bad considering we where 4 adults with luggage and aircon on all the way.
    These things just eat up the km's. Total silence and comfort. Biggest problem was keeping the beast within the speed limit, just don't realise how effortlessly these get get up to speed.
  18. #116
    Thanked: 145
    Did a trip to Balito, and again this Rangie just eats up the kilos.
    But alas it was not uneventful.
    Firstly got a warning to check coolant level. Then opened the bonnet to a steaming burst pipe.
    Easy fix atleast. Cut the pipe and reconnected. But that got me to see oil in the expansion tank.
    So nursed her back home. Uphill she was not happy at low revs so drove her manually.
    Got home took the oil cooler off and was met with not red but sadly water contaminated gearbox oil.
    How do flush this? As I am sure the torque converter did not drain out with the rest of the oil?
  19. #117
    Tzaneen
    Thanked: 275
    Try the fullfatrr UK site,there is a lot of good advice on that site.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  20. #118
    Thanked: 145
    Got a new oil cooler from Grand Mark. Not even BMW could help me.
    Bought 5l of normal atf and just ran it through the system for a semi flush. A lot of water contaminated oil still cane out. So much I was afraid it could be more damage than just the fluid cooler. Then I sat down had a beer and realized that the bloody filter is probably still full of it.
    Do I have to replace the filter? It was done in Dec 2017
    Or will it just work through?
  21. The Following User Says Thank You to Benson For This Useful Post:
  22. #119
    Witbank
    Thanked: 204
    Sorry to hear about your misfortune, with your new baby.
    Benson if I was you I would do another flush of the box and then drop the gearbox sump, which also holds the filter and replace. Much cheaper than overhauling the whole box.
    Or alternatively, might be worth while to give ZF a call and find out if there is someone in Bloem who has the machine to do the propper flush. Should save you a lot of trouble in future.
  23. #120
    Thanked: 451
    Hi Benson
    congrats on your aquisition! They are spectacular vehicles. Ours is the Td6 expertly tweaked by Elton of Eurospeed. Goes nearly as well as a TDV8 but with none of the TDV8 nonsense.
    You will enjoy her and I wish you many happy miles with her.
    The big problem with the "Fattie" is that once you have grown used to it, you will struggle to get comfortable with a lesser vehicle again.
    George Bosch
    Distributor for:
  1. Replies: 4
    Last Post: 2015/01/04, 04:27 PM
  2. Reach for a dream 8 March 2014
    By RangeRover in forum Gauteng
    Last Post: 2014/06/02, 01:24 PM
  3. Range Rover classic body pannela
    By RangeRover in forum Land Rover
    Last Post: 2012/11/12, 05:16 PM
  4. Range Rover Classic Body Mounting Rubbers
    By Stubbzie in forum Land Rover
    Last Post: 2011/10/04, 08:08 PM
