Page 29 of 31 FirstFirst ... 24 25 26 27 28 29 30 31 LastLast
Results 561 to 580 of 611
  1. #561
    Dowerglen
    Thanked: 2410
    Default Re: what have you done with / to your Range Rover (Big Body) today
    Man, sometimes the proper stupid button hits way too close to home....
    The fattie has been parked in the garage for a sizeable amount of time, business is bad, profits are down and the fuel price keeps swinging far north of my affordability scale, so she sits, mostly almost..
    Last of last thursday just before the Easter break I suffer a breakdown in the Mrs Beemer somewhere close to the R21 Nelmapius turnoff, vehicle shaking quite violently with a warning sign on the screen to get to a dealer as urgently as possible, which I duly did, slowly, where 5 days later I was reamed the small sum of R5k for replacing 4 sparkplugs.. Hell at that pricepoint the very least I would expect apart for the R69 I paid for the car to be cleaned expertly was a tub of vaseline so the 'slide' would be a little more bearable, but, alas, BMW like it rough it seems...
    Anyway, that's a story for another day..
    So back to the fattie - SWAMBO, Max Verstaffie and my 19 year old eldest come fetch me at BMW Centurion in the fattie.. SWAMBO there because the victim happens to be her vehicle, which she loves, and the eldest since SWAMBO refuses to drive the fattie, and Max because he is always up for a trip on the backseat, farting quietly to his blissful delight..
    I was done with driving for the day, so hopped into the fatties passenger seat and told threequarterpint to get us home...
    "Dad", he says, "the fattie is driving like sh1t, she has no get up and go.."
    No I tell him, don't push her, you need to go past the first click on the accelerator before she wakes up.. He looks at me as-if I have a 2nd hole in my arse, which I accept given he is a teenager and I know nothing...
    Seems he was right after-all, today I had to go back to Tshwane to deliver an item that could only fit in the fattie, gutless-gertie would have sufficed but it was raining and she has no canopy so the fattie it was..
    She was positively asmatic, her get up and go had gotten up and left sometime back, the ponies had left the paddock and ran astray north of the Limpopo never to be seen again.. She drove like cr@p, her gearbox wasn't gearboxing properly, at one stage on a fairly long uphill I was being pushed out of the fast lane by a Suzuki Swift, so I gave it horns and all that happened was the engine revved to 5K and then stayed there, gearbox would not shift up, could not get her to go past 120, so I flipped the gearbox disting switch on the steering which notched her into another ratio, and slowed her down more, got to the slow lane and ashamedly apologized to the Swift for holding her up...
    Now the brain kicks into total WTF mode, is it gearbox, is it engine, is it the supercharger snout breaking off - man don't be a cock, if that thing broke off you would have a hole in the bonnet... Panic sets in.. Cashflow sets out...
    Stopped at a ultracity, pop the bonnet and the professional mechanic in me confirms that in fact, there is an engine in there, and it seems to be engining rather poorly despite still idling smooth as V8 silk, so closed the bonnet and drove home seriously miffed at the prospect of handing her over to JLR somewhere while buying my own jar or Land Rover approved vaseline...
    Then I remembered that I owned one of those Icarsoft diagnostic things, plugged her in and ran the diagnostics, 1st test is the engine, so ran that test and a Mass airflow sensor fault was diagnosed on bank B, which is the other side of bank A... Cleared the fault successfully with engine off but on running again the fault reappeared, which is a good thing because at least something is really wrong, well of course it is, but you know what I mean, its easier to have something to point to than looking at a block of complex aluminium trying to find where to put the stethoscope..
    Since bank A & bank B MAF's are the same, the simplest thing to do was to swop the left out for the right and vice versa, run the test again and see if the fault jumps banks.. so I did that.. the fault stayed put on bank B..
    Well that's a ball-ache I thought..
    So then back to diagnostics and I run some live data, bank A airflow is measuring properly increasing as you rev the fattie, bank B is sitting fixed at about 1.2 million kg of air despite how hard you do or don't pin her..
    And then I remembered.. Around 3 weeks back I checked the LHS airfilter to see if they both would need changing as it's been a while since last replaced.. I wonder...
    Wonder I did... Removed the LHS airfilter housing only to find that when I had closed her up the three odd weeks back, I had inadvertently got the MAF cable which is clipped on the side of the housing caught between the two housing halves, and promptly severed two of the 3 or 4 wires which are there..
    A bit of a jointing exercise, some new wire, some proper solder, some proper heatshrink insulation, some proper closing of the affair and safe to say the fatties ponies have come back home to rest where they should, thank goodness... I'll be placing my LR approved unused 250ml vaseline tub in the 'what offers' thread shortly...
    Who would have thought that failure pointing to such a small component that looks like one of granny's pins with the plastic blob on the head would cause so much mis-balance from RPM to power to gearbox control to vaseline...
    Thank the good Lord above that I had that Icarsoft thing, otherwise I'd probably be busy removing the gearbox around now..
ID:	719247   Click image for larger version.
ID:	719248   Click image for larger version.
ID:	719249   Click image for larger version.
    Regards - Marco Chezzi
    My wife says I am not qualified enough to express an opinion..
  2. The Following 15 Users Say Thank You to Marcochezzi For This Useful Post:
  3. #562
    Ruimsig
    Thanked: 47344
    Edjit!
    You should know better by now not to crimp the dingus between the magafter and the disting. Laaitjies....... heaven help us
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
  4. The Following User Says Thank You to Estee For This Useful Post:
  5. #563
    Thanked: 3451
    Quote Originally Posted by Marcochezzi View Post
    Last of last thursday just before the Easter break I suffer a breakdown on the Mrs Beemer somewhere close to the R21 Nelmapius turnoff, vehicle shaking quite violently with a warning sign on the screen to get to a dealer as urgently as possible, which I duly did, slowly, where 5 days later I was reamed the small sum of R5k for replacing 4 sparkplugs.. Hell at that pricepoint the very least I would expect apart for the R69 I paid for the car to be cleaned expertly was a tub of vaseline so the 'slide' would be a little more bearable, but, alas, BMW like it rough it seems...
    Then I remembered that I owned one of those Icarsoft diagnostic things, plugged her in and ran the diagnostics, 1st test is the engine, so ran that test and a Mass airflow sensor fault was diagnosed on bank B, which is the other side of bank A... Cleared the fault successfully but on running again the fault reappeared, which is a good thing because at least something is really wrong, well of course it is, but you know what I mean, its easier to have something to point to than looking a a block of complex aluminium trying to find where to put the stethoscope..
    Fantastically writen as always! Glad it is sorted out, these mistakes happen so easily and tends to leave one so upset when they occure...
    '13 Audi Q7 3.0 TDi quattro - stock standard
    '12 Audi Q5 3.0 TDi quattro, 255-65R17 AT tires - Sold
  6. The Following 2 Users Say Thank You to Commander For This Useful Post:
  7. #564
    Dowerglen
    Thanked: 2410
    True this, still getting rid of the frustration of having paid what I did for spark plug replacement… good grief…
  8. #565
    Dowerglen
    Thanked: 2410
    Edjit!
    Sorry uncle, now I know, it was the dingus thing ..
  9. The Following User Says Thank You to Marcochezzi For This Useful Post:
  10. #566
    Thanked: 519
    Our well maintained South African roads took out one of the Hiflys that I bought the Range Rover with. Was hoping to get another couple of months out of them. But such is life.
    4x Apollo Apterra AT2 fitted. 275/55/20.
    Up from the 275/40/20 its a nice increase in sidewall
    Also needed to lift it 50mm and still have some slight rub at the back wheels when cornering and accelarating hard.
    1996 Land Rover Discovery 1 -VW Tdi Swap in Progress
    2000 Land Rover Discovery 2 V8
    2005 Land Rover Discovery 3 V8
    2012 Land Rover Discovery 4 V8
    2010 Range Rover Sport SC 5.0 V8
    1967 Land Rover Series 2A 4.0 V8
    196? Land Rover Series 2 V8 100"
    Ex.
    Discovery 1:TDI and a V8. 2x Discovery 2 V8. 2X Discovery 3 TDV6. Freelander 2 TD4, 2X C350 CDI's, Subaru Forester XT and a Volvo V60 T6
  11. The Following 2 Users Say Thank You to JeandreDiedericks For This Useful Post:
  12. #567
    Jul 2016
    Thanked: 866
    Fitting a new fuel pump to my L322. Should stop it running out of fuel when the range still says 90kms
  13. The Following 3 Users Say Thank You to MikeBob For This Useful Post:
  14. #568
    Feb 2016
    Thanked: 3109
    Please tell me this is not the dreaded timing chain?
    https://youtube.com/shorts/gZzXfGoDTUU
    Defender Puma Workshop Manual:https://bit.ly/2zZ1en9
    Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO
  15. #569
    Jul 2010
    The Vale
    Thanked: 806
    Sounds like it could be, I had the same , sorry
    Ranger Wildtrak
    Ex Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  16. #570
    Dowerglen
    Thanked: 2410
    The timing chain issues were seeming resolved around MY2012, so it 'should' not be that on your 2015..
    What's your mileage, have you checked the supercharger pulley connector thing for rotational play, I am led to believe that excess play from the 'coupler' leads to bad noises..
  17. #571
    Feb 2016
    Thanked: 3109
    Yeah, that seems to be the concensus, it's in for the annual service, so they're checking everything out.
    Just gone over 114,000km.
    I heard it for the first time tomorrow after a somewhat 'spirited' drive on the way to a trail.
    Other owners have also experienced a 'ticking' sound without any issues, seemingly switching to a better oil than Castrol solves this. We're going with Motul, since we can't find Liqui Moly.
  18. #572
    Feb 2016
    Thanked: 3109
    A better clip, with the bonnet open
    https://youtube.com/shorts/7-JDLSxK7bQ?feature=share
  19. #573
    Dowerglen
    Thanked: 2410
    Best of luck Orxy, hopefully its nothing too complex..
    On the assumption that you might not have, if not, get yourself registered with Liqui Moly SA and order the oil online, anything above R600 and delivery is free, just replaced the 10L of 5W20 in my fattie 2 days back after an extended procrastination.. Took them all of 1 day to process the order and get the oil to me, granted, we are not far apart, but still...
  20. #574
    May 2008
    Noordhoek. Cape Town
    Thanked: 27
    I have heard of the hydraulic tensioners failing partially or even totally so dont discount that possibility. If the troubleshooting does point to that, it's not a huge job to remove the lower timing chain cover to assess and replace if need be. No need to disturb the top end of the engine which would be necessary if the chains need replacing.
    I would not be surprised if JLR recommends replacing all timing chain components but that is not normally necessary and is not cheap.
    L322 TDV8 2010
    DISCO 4 V8 HSE 2010
    JAGUAR XJ ULTIMATE 2013
    CAV GT40
  21. The Following User Says Thank You to GT40 For This Useful Post:
  22. #575
    Feb 2016
    Thanked: 3109
    Funny you are mentioning LM, my indie is struggling to find the correct oil from their suppliers
    Btw, you should be using 0w20 conforming to STJLR.03.5006
  23. #576
    Dowerglen
    Thanked: 2410
    Thanks Orxy - Weird - Mine is def specced at 5W20, and if unavailable, then use 0W20..??
ID:	723159   Click image for larger version.
  24. #577
    Feb 2016
    Thanked: 3109
    yep, but the 0w20 superseded the 5w20: the 0 will spread faster on cold startup, therefore mitigating cold startup wear & tear.
    There is a special LM oil for LR that the Yanks use: https://www.liqui-moly.com/en/us/spe...0-p004426.html
    but of course, we don't get that in ZA.
    So will settle for this:
  25. #578
    Dowerglen
    Thanked: 2410
    I think the cold startup thing between 0W and 5W is regarding really cold climates, not so much us, but I did read that the 0W helps with lowering fuel consumption on cold startup, and personally I think that's just not right, I mean, asking a thirsty 5L supercharged V8 to run a little thinner on the Fat is just not British old chap....
    ... but I might just consider my options on the next change
  26. #579
    Thanked: 519
    Sounds like the supercharger coupling, but tough to judge from a video.
    Remove the SC belt and let it idle and see if the noise is still there.
    Ex.
  27. #580
    Feb 2016
    Thanked: 3109
    Went playing in the sand on Sunday
    https://new.reddit.com/r/rangerovers..._the_sand_rsa/
  1. Replies: 4
    Last Post: 2015/01/04, 04:27 PM
  2. Reach for a dream 8 March 2014
    By RangeRover in forum Gauteng
    Last Post: 2014/06/02, 01:24 PM
  3. Range Rover classic body pannela
    By RangeRover in forum Land Rover
    Last Post: 2012/11/12, 05:16 PM
  4. Range Rover Classic Body Mounting Rubbers
    By Stubbzie in forum Land Rover
    Last Post: 2011/10/04, 08:08 PM
