Newbie in need of advice lexus conversion on Disco 1 - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 60 of 60
  1. #41
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Quote Originally Posted by bvandyk View Post
    There are 1000's of Pumas in SA
    Sorry blond moment I was under the impression ford puma lol I think I need a time off after my examns I'm not thinking straight lol.
  2. #42
    Springs
    Thanked: 277
    Quote Originally Posted by Disco beginner View Post
    Any idea where I can find a puma shaft as I believe the puma did not come out in SA?
    the Puma is the Defender with the 2.4 4 cylinder Ford Duratorque engine
    been around since around 2008
    these shafts new from the agents are around R2500 brand new
    the shaft i had custom made for the conversions cost me R6k each
  3. #43
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    I know in Wellington there is a guy that only work with land rovers, don't want to mention the name don't know if it is against the t's&c's. They also have a branch in Brackenfell now maybe they have one lying around.
  4. #44
    Modderfontein, naby Rysmierbult
    Thanked: 572
    Don't know if it has been mentioned, but apart from fitting a new cam belt, also fit a new water pump ... the cam belt drives the water pump .... mine ceased, we ended up just buying another engine; luckily not too expensive and driving again after a week.
    Sterkte with the conversion, once it's done it is only a pleasure
    Johan Mitchell, .... r.i.v. Swambo Marthie
    My beste kennis is diť oor my eie onkunde
    '96 Colt DC V8 ... Safari Camper ... '88 Fleetline L
    '88 Ballade 150 ... sold
    "The rule here is that there is no rule" .. MikeAG
  5. #45
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Quote Originally Posted by Gaitshi Gubib View Post
    Don't know if it has been mentioned, but apart from fitting a new cam belt, also fit a new water pump ... the cam belt drives the water pump .... mine ceased, we ended up just buying another engine; luckily not too inexpensive and driving again after a week.
    Thanks I am quite keen on balancing the motor before installing as it is out and open already then
  6. #46
    Thanked: 413
    Late as usual, but I have 5 cents to add....
    Yes, I have both - the VVT and non VVT monsters
    Haven't gotten down to Krapping with the VVT (5 speed), but have replaced 3 flex plates on my non VVT defender....something went wrong with the TH350 adapter plate hence the eating of flex plates...
    Running a Gotech controller...big mistake, but thats how I got it...(also came with a LH front diff to suit the NP234 TC)
    Where I'm going with this.....I decided to go for the standard Lexus 4 speed auto box to get away from the TH350 and adapter problems, but felt sick about having to buy a gearbox controller (damn GoTech wants to sell me a new ECU as well cos my "old" version wont talk to the gearbox unit)
    I managed to bum a Lexus 4 speed auto box but it came without the bell housing, so I krapped around in my store and found a Mitsi 4 speed auto (AW 3040) that has the same bolt pattern as the Lexus (AW3040 LE).
    The Mitsi transfer case is also LH to the front prop which suits me fine.
    so, maybe the Mitsi box (which is way stronger) can be used instead of bleeding out for a gearbox controller.
    I just need to find a Lexus 4 speed bell housing.........
  7. #47
    Thanked: 413
    Argued my way around not having a handbrake on my auto S2 88....
    Put it in "park" and told them to test my "handbrake".....walked out with my roadworthy cert.
  8. #48
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    This has caught my attention but is the rear output on the TC in the centre?
  9. #49
    Thanked: 11262
    On a Series, a Defender ,the RRC and on a Disco 1 & 2 the offset is to the right.
    On a P38 I think to the center rear.
  10. #50
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Yes I meant on the mistsubishi TC is the output to the rear diff in the centre or also to the right as I do not want to swop out the diff as that requires a lot of extra work
  11. #51
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    I finally found some photos of the Mitsubishi TC case and it isn't going to work for me and some of the guys say that the low range isn't that low as the TC from my disco so I think I will stick with the Disco TC and lexus motor.
  12. #52
    Springs
    Thanked: 277
    many guys screw up getting a transfer case that does not output at the same side as the land rover pumpkins
    LR have both pumpkins offset to RHS
    most Jap TC have rear centre and front left or right
    this will cause major headaches for props
    stick to LR TC
  13. #53
    Thanked: 11262
    Most Jap are center rear.
    The only ones that are/weren't were old SFA Hilux, old FJ60 and earlier LC, and Nissan Safari and Super Safari (160 Mq/MK Patrol).
    Take Landyluvver's advice.
  14. #54
    Thanked: 413
    The Mitsi TC is center rear, left front ( electronic - no nasty sticky things with linkages).........but the box is way stronger than the Lexus and doesnt need a controller
  15. #55
    Jan 2011
    Thanked: 8
    Except it has a horrible 1.9:1 low range..
    Doesn't the NP231 work on the Lexus box as well? Can also be flipped, and has a bunch of options if you're willing to import from the states..
  16. #56
    Thanked: 413
    Don't know about that 1.9:1 low range....the flex plate doesn't make it to the corner, so I have never tried the low range, besides, my Lexus Defender's just for show....If you wanna play in the dune's I'll see you there with my 4x4 tractor
    I've got a left hand front diff so the NP234 works fine for me.....
  17. #57
    Dronk-word-baai
    Thanked: 53
    If the box fits and is to the wrong side you could rotate the diff hosing if you are keen on making lots of work for yourself..
    1990 Toyota Hilux - In process..
    The more people I meet the more I like my dog..
    Real 4x4's have splash guards, not sump guards..
  18. #58
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Hi everyone
    Sorry for not replying I have been busy with examns now I have time on my hands again but I am still trying to find myself a motor the guy I wanted to buy a motor from have already sold his last stock and he cant say when he will be getting new stock.
  19. #59
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Hi everyone
    I have tracked down a motor and gearbox and bought it in the end. All it needs is the ecus and aircon pumps other than that it is complete and in good condition. I will start going through everything tomorrow and clean the engine nice and properly and also refurb the starter while it is all nice and open. Must say I'm very excited as I think this is going to be a very nice project.
  20. #60
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Good Day everyone
    Basicly a year later and what happened...lol nothing I am not doing the conversion but did end up buying another Disco 1 that I am going to change to my liking
  1. Disco 2 td5 19p - Advice
    By moomoo in forum Land Rover
    Last Post: 2014/03/28, 08:58 PM
  2. Did you get what you paid for?
    By CWFourie in forum Mahindra
    Last Post: 2014/01/29, 07:01 PM
  3. About to purchase a Disco 3 need some advice please!
    By Brownpine in forum Land Rover
    Last Post: 2013/07/23, 02:18 PM
  4. Lexus conversion
    By Landyluvver in forum Land Rover
    Last Post: 2011/12/12, 06:00 PM
  5. Lexus V8 Conversion
    By Winston in forum Vehicle & Technical Chat - General
    Last Post: 2011/07/11, 09:16 PM
