Results 21 to 40 of 60
  1. #21
    Thanked: 20097
    Quote Originally Posted by Hagu13 View Post
    Jelo, running well but as with any conversion you never know where the weakest link is. I managed to tear the gearbox mounting so I reengineered it to be really strong. This was good as next time out in the dunes I tore the engine and TC mounts, so my super gearbox mount was all that was holding the drivetrain in. I've now monstered the lot.
    Had a bit of a perfect storm on breakdowns lately- both BMW's have eaten their autoboxes and the MG ate its engine, so no time or money to destruction test the Defender at the moment except for having Chevy Sparks run into it.
    jeez boet it sounds like you need to back off on the loud pedal sometimes
    Jakes Louw
  2. #22
    Melkbosstrand
    Thanked: 488
    You mean it's not just an on/off
    Rob
    Disco 3 SE TDV6
    Disco 2 ES TD5. Custom map, V8 TC
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
  3. #23
    Springs
    Thanked: 287
    it is the nut holding the steering wheel
    I personally would hang onto the LR handbrake with the LR transfer case
    other option is the disc brake conversion which fits onto the rear propshaft
    http://www.terrafirma4x4.com/product...cat=34&grp=135
  4. #24
    Plettenberg
    Thanked: 128
    Quote Originally Posted by Landyluvver View Post
    Bought mine with conversion already done. It is using the LT230 LR TC. Looked at that handbrake conversion, but there is no space in my Defender for that. Need to upgrade the rear drum brakes anyhow so hopefully the jaguar calipers conversion will be OK.
  5. #25
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    I am going to try and keep the TC where it originally sits as then the props stays the same as it is a better way of standing still up a steep hill vs only rear calipers that is locked with the handbrake. I will first test the setup with standard radiator as it has a big radiator(the landie's engine is also 3.9 V8 so will see if this will be sufficient enough and probably 2 electric fans, but heard some of the guys say that the lexus alternator isn't too strong and packs up later on due to heavy load from the two electric fans. Thanks Wilk I am going to source for one that hopefully have the rear mounted sump as that will be easier to modify and make it a bit deeper for offroading purposes. Do I need to make the autobox's sump deeper aswell or is it fine as it is?
  6. #26
    Plettenberg
    Thanked: 128
    Quote Originally Posted by Disco beginner View Post
    Yes. will be better if you can keep the TC in the same location. Better to ask Rob regarding the sump for the autobox as I haven't use mine (Autobox sump- standard) off-road.
  7. #27
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Another thing where will I be able to get an adaptor plate made to mate the autobox with the TC I have seen one on gumtree but it was already sold which had the speedo sensor mounted in the adaptor plate. I assume the easiest way to make the speedo work is to keep the ecu and mount a disco 1 speedo sensor in the adaptor plate?
  8. #28
    Springs
    Thanked: 287
    remember that to fit the LT230 transfer case to the back of the Toyota gearbox, you need an extension tube and shaft and not simply an adaptor plate
  9. #29
    Plettenberg
    Thanked: 128
    Attached picture of tube Landyluvver mentioned. (Don't know who makes them). Would think the speedo pick-up on the Disco 1 is on the TC. The wires on the mounting tube is for Spitronic Computer.
  10. #30
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Yes I am talking about that tube thingie don't know what to call it so therefore just said adaptor plate although it isn't only one piece of plate.
  11. #31
    Springs
    Thanked: 287
    there is a guy in Pretoria called Chris Mod that makes them
    he is well known in the conversion circles
    don't have contact details
    maybe Lextreme can help
  12. #32
    Melkbosstrand
    Thanked: 488
    THat adapter is pricey. besides the 2 plates with a tube between remember you have a piece of shaft, splined at both ends to fit the gearbox output shaft at the front and into the TC at the rear. Very time consuming piece of engineering.
    Gearbox sump is fine, no need to deepen it.
    You run two speed sensors. One on the extension tube to tell the gearbox what its output speed is which helps it calculate shift points, and the one on the back of the TC which is used for your speedometer.
    Rob
    Disco 3 SE TDV6
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
  13. #33
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Yes I might be able to make up the two plates with the tube in the middle but the spline that connects the gbox to the TC is a different ball game but will have to wait till I get the motor before I can start anything. I might have access to some nice CNC lathes and milling machines to make up the adaptor thingie but will probably have the inside shaft made up and I assume I'll have to have it case hardened?
  14. #34
    Springs
    Thanked: 287
    been looking into using the gearbox extension shaft for the Puma
    it makes the conversion a lot quicker
  15. #35
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Does it replace the adaptor thingie that is needed?
  16. #36
    Springs
    Thanked: 287
    you need the extension tube and extension shaft
    the idea is to use the extension shaft from a Puma and modify to fit the back of the Toyota gearbox
    you need to remove the rear portion of the Toyota box to bolt the adaptor on so the extension which is removed has the splined socket attached
    cut this splined section off and graft onto the Puma shaft
    will try to post pics
  17. #37
    Springs
    Thanked: 287
    attached the pics of the puma shaft
ID:	320303   Click image for larger version.
  18. #38
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Ah ok I understand thanks a lot this will speed up the process a lot! And believe it will be softer on my pocket aswell
  19. #39
    Nov 2014
    Langeberg Ridge
    Thanked: 12
    Any idea where I can find a puma shaft as I believe the puma did not come out in SA?
  20. #40
    Jan 2009
    Thanked: 113
    There are 1000's of Pumas in SA
    Range Rover Big Body 5.0 V8 Supercharged
    Land Rover Defender 110 V8 Game viewer
    Land Rover Defender 100 PU V8
    Land Rover Freelander II SD4
    Jaguar XJS V12
  1. Disco 2 td5 19p - Advice
    By moomoo in forum Land Rover
    Last Post: 2014/03/28, 08:58 PM
  2. Did you get what you paid for?
    By CWFourie in forum Mahindra
    Last Post: 2014/01/29, 07:01 PM
  3. About to purchase a Disco 3 need some advice please!
    By Brownpine in forum Land Rover
    Last Post: 2013/07/23, 02:18 PM
  4. Lexus conversion
    By Landyluvver in forum Land Rover
    Last Post: 2011/12/12, 06:00 PM
  5. Lexus V8 Conversion
    By Winston in forum Vehicle & Technical Chat - General
    Last Post: 2011/07/11, 09:16 PM
