DIY Roof Rack
Results 1 to 15 of 15
Thread: DIY Roof Rack
    Oct 2014
    Smile DIY Roof Rack
    Hi Gents
    Plz give ideas/design for a DIY roof rack for Pajero LWB (gen2) i need one for Namibia next year.
    Ruan Seymour
    Pajero 3000 V6 LWB 6g72
    Hope I'm not hijacking this thread, but I am busy designing a roof rack to go on the cab of my bakkie. Dimensions 1.2m x 1.1m. I have calculated the weight to be 20kg using mild steel. Would this be regarded as a practical weight for such a roof rack?
    I would use it for solar panels (13kg), gas bottle (guess 10kg) and a few odds & ends (5kg) so total weight on the roof incl rack would come in at about 50kg. Is this excessive?
    '06 Isuzu Kb 300 TDi LX 4x4 D/C
    May 2012
    Quote Originally Posted by PaulG View Post
    How are you attaching the roof rack onto the roof? with rails like from 4x4 direct / frontrunner or are you using roof racks? factory roof bars?
    the roof will handle that weight if properly installed.
    Currently do not own a 4x4, driving a sedan
    Ex: 2013 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2012 Ford Ranger 3.2 XLT 4x4 auto
    Ex: 2013 Ford Ranger 2.2 XLS 2WD manual
    Ex: 2009 Mazda BT50 3.0 CRDi double cab manual
    Garsfontein, Pretoria
    Thanked: 13
    Do you have roof rails or do you want to bolt the roof rack onto the roof itself? I made one from 25mm aluminium square tubing and connect-it's that clamps onto my roof rails and it is quite strong. Cost about R600 and quick to build.
    '02 Toyota Prado 3.0 td VX, SAC intercooler, Kumho KL78 A/T's. DIY roofrack and rack system.
    "Good judgement come from experience, experience come from bad judgement"
    Quote Originally Posted by Andz View Post
    I have a set of Thule load bars on that has a channel used to mount accessories.
    A far as I can tell the weight limit given by Thule is 75kg.
    Quote Originally Posted by WernerS View Post
    I have considered 25mm aluminium square tubing and connect-it's, however I couldn't settle on a practical design that I liked given the limited choices in configuring the bars. What dimension is your roof rack and what did it weigh in the end?
    May 2012
    Connect its and alu tube is the easiest and lightest.
    you can also consider aluminium rectangle tube for the slats and u channel mild steel for the outer frame.
    the rectangle tube fits tightly in the u channel and you can bolt or pop rivet it together.similar to the front runner assembly. ( the assembly instructions are available online if you go to frontrunner webpage, select any slimlineII rack and then fitting instructions.
    Apr 2011
    Thanked: 11
    Default Re: DIY Roof Rack
    HI. In the process of building a RR... Do you have any photos of yours?
    Mar 2018
    Thanked: 30
    Quote Originally Posted by cruiser View Post
    Hi Cruiser
    Would be keen to see how you progress... I am considering building one as well with 25mm Alu Sq tubing, with support struts and Chequer plate for the base. The issue I have is finding functional load bar and brackets to fit into the Cruiser Bakkie roof channels... Any thoughts?
    Thanked: 66
    See attachment - built year before last.
    Cost for Frontrunner foot rail set was R1 500 and roofrack was not more that R1 400 IIRC.
    New would have been in excess of R 6 500!!
    Carried 18"2nd spare, gazebo, gasbottle, Howling moon 3x3m ripstop tent etc. for more than 6 500 km in Namibia/Botswana!!
    Benefit is that, if I change vehicle, I can use the RR again, just need new footrails for the specific vehicle.
  11. The Following User Says Thank You to ELU For This Useful Post:
    Thanked: 7
    Great do you perhaps have a photo?
    Thanked: 66
    Quote Originally Posted by waynegrey View Post
    I will have to search/scratch. Currently not on vehicle, but suspended by means of Fredlin hoist. Will see what I can do when home.
  14. The Following User Says Thank You to ELU For This Useful Post:
  15. #13
    Jul 2017
    Thanked: 95
    It's not a roof rack but it could be.
    https://www.4x4community.co.za/forum...ack?highlight=
    Weighs 30 odd kg.
  16. The Following User Says Thank You to Walnut For This Useful Post:
  17. #14
    Aug 2018
    Durban North
    Thanked: 11
    Hi
    i built mine last year for my December trip.
    It was easy at cost me just under R800 for all the aluminum
ID:	525614   Click image for larger version.
  18. #15
    Thanked: 66
    Hi Wayne,
    Attached as requested. I had the rails powder coated prior to assembly and then touched up with black paint after assembly (Connect-it connectors, etc).
ID:	525682   Click image for larger version.
Name:	20190414_170057 - Copy.jpg
ID:	525683   Click image for larger version.
ID:	525684   Click image for larger version.
ID:	525685   Click image for larger version.
ID:	525686   Click image for larger version.
ID:	525687   Click image for larger version.
ID:	525688   Click image for larger version.
Name:	TB Roofrack 2.jpg
ID:	525690   Click image for larger version.
Name:	TB Roofrack.jpg
  19. The Following 3 Users Say Thank You to ELU For This Useful Post:
  1. Replies: 30
    Last Post: 2016/05/13, 09:14 AM
  2. Roof rack Ladder
    By Alastair in forum Camping, Fridges, Accessories
    Last Post: 2014/02/04, 07:20 PM
  3. How do you pack your roof rack?
    By Vansubsea in forum Camping, Fridges, Accessories
    Last Post: 2012/10/12, 04:30 AM
  4. Roof Rack supports for Defender
    By FishnChips in forum Land Rover
    Last Post: 2011/05/01, 07:13 AM
  5. Custom built roof rack - engineering advice please
    By LuckyStriker in forum Camping, Fridges, Accessories
    Last Post: 2010/07/26, 03:38 PM
