Imbuya restoration
Results 1 to 4 of 4
    Jan 2007
    Thanked: 9
    Default Imbuya restoration
    We have recently received a beautiful 10-seater ball and claw dining room table from the estate of my mother in law.We have now painstakingly removed all the old water and heat damaged varnish with spirits and fine steel wool. What should we apply to both bring out the natural colour of the wood and at the same time have a low maintenance surface on a table in daily use?
    Aug 2014
    Infinity
    We've used:
    http://www.plascon.co.za/products/pr...0&ProductID=79
    Use the X44 suede clear - preferably not anything 'gloss'.
    or
    http://www.woodoc.com/products/12
    Both are polyurethane.
    Then every 2 months
    http://www.woodoc.com/categories/4/products/10
    Toyotas
    Aug 2014
    Infinity
    Maybe I should add that most of our antique furniture such as dressing tables and cupboards are only treated with the furniture oil/wax after restoration.
    We went the polyurethane route where there was a high possibility of future damage i.e. for tables and chairs.
    Toyotas
    Thanked: 81
    There is a better route. Make a mix as follows:
    1/3 Clear polyurethane
    1/3 White spirits (not vinegar)
    1/3 Furniture oil ( I use Shell Vitrea 22)
    This gives you a product that is as close as I can get to Rubbol matt varnish.
    You cannot keep this mix as it will gel overnight.
  1. Best restoration manual Land Rover series III
    By Wilding in forum Land Rover
    Last Post: 2013/11/04, 09:06 PM
  2. Defender 110 V8 Bodywork Restoration
    By Fontuin in forum Land Rover
    Last Post: 2013/07/18, 03:33 PM
  3. Restoration project plan help needed
    By RangeRover in forum Land Rover
    Last Post: 2013/05/17, 08:05 AM
  4. Help! Auxilary Spot light Restoration
    By Scooter King in forum Vehicle & Technical Chat - General
    Last Post: 2012/07/03, 08:55 PM
  5. Defender Defender Restoration Manual
    By T le Roux in forum Land Rover
    Last Post: 2011/02/02, 11:16 AM
