Deep Cycle Hi-Cycle 450 Amps
Results 1 to 10 of 10
    May 2007
    Welgelegen, Cape Town
    Default Deep Cycle Hi-Cycle 450 Amps
    I might be getting one of these from a friend. Would there be any harm in taking out my 102 Amp battery and putting in the 450 Amp battery as my second battery?
    Klerksdorp
    Stiffen up the vehicle suspension!
    Electrically, there shouldn't be a problem except your alternator will now take much longer to keep the battery charged after a long weekend or similar period of current drain from the battery.
    In my personal opinion, I wouldn't bother, waste of too much space and unnecessary weight unless you're going somewhere really remote and have no other means of charging a battery.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
    what does the IEC rating on a battery mean ...?
    the exide 102Ah has an IEC rating of 450A
    2008 Jimny (ex SJ)
    ...Extended diff & tcase breathers, dual battery, towbar
    2008 Terios Offroad
    ...nudgebar, spots, runners, dvd
    Quote Originally Posted by Soutter View Post
    The IEC stands for International Electrotechnical Commission. The rating you are referring to is the CCA or Cold Cranking Ampere
    The cold cranking ampere (CCA) rating refers to the number of amperes a battery can support for 30
    seconds at a temperature of 0°F until the battery voltage drops to 1.20 volts per cell, or 7.20 volts for a 12V
    battery. Thus, a 12V battery that carries a rating of 600 CCA tells us that the battery will provide 600 amperes
    for 30 seconds at 0°F before the voltage falls to 7.20V.
    Johan's being pulled a fast one methinks - it's not A 450 Ah but probably a standard 102Ah hi-cycle battery if it can supply that CCA
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    woah.... 7.2V ... that is one flat battery
    thanks simonb ... thought it might be something like that ...
    2008 Jimny (ex SJ)
    2008 Terios Offroad
    May 2007
    I doubt it, about being pulled a fast one, this is one seriously big battery. This battery is about length wise the size of almost 3 x 102 Ah batteries in a row if you know what I maen. I'll double check tomorrow.
    Hi,
    Post up the Make/Model of this beast and let's check it out and see if you are being pulled a fast one.
    May 2007
    Ok my mistake, it is a 12 volt 143Ah battery, still a good battery I can get, should give you another 16 hours at 2.5 ah in relation to 41 hours on a 102 Ah battery, I could do with 57 hours, dis nou as my somme reg is.
    is the 143Ah also a deep cycle ... not gonna help much if it isnt ...
    2008 Jimny (ex SJ)
    2008 Terios Offroad
    Given the size and weight of this battery a second 102 would be better surely? Bu then again if it costs you zilch then go for it...
    Carpe Diem Scrotum
  1. High Cycle or Deep Cycle for Aux Battery
    By Gerrit Loubser in forum Vehicle & Technical Chat - General
    Last Post: 2015/10/09, 04:05 PM
  2. Watter battery vir my yskassie?
    By Massy in forum Camping, Fridges, Accessories
    Last Post: 2010/09/20, 04:47 PM
  3. Alternator and a deep cycle battery
    By warrenaken in forum Toyota
    Last Post: 2009/08/17, 10:25 PM
  4. Deep Cycle / High Cycle
    By Tricky Dicky in forum Camping, Fridges, Accessories
    Last Post: 2009/04/17, 08:15 PM
  5. Normal lead-acid vs. deep cycle
    By Gerrie in forum Camping, Fridges, Accessories
    Last Post: 2008/01/25, 07:27 PM
