smoking hardbody
Results 1 to 9 of 9
    Pretoria/Beauvais France
    Default smoking hardbody
    noticed that the hardbody is smoking a bit This stared today after towing about a 750kg load from Germiston to Pta . I filled up with petrol back 20km before it started . The thing only has 11000km so I doubt that is engine wear . Can dirty petrol make a petrol car smoke ?
    De Kelders
    Thanked: 131
    What colour is the smoke, petrol smoke normally is black.
    Its more like a dark grey to black I will say
    Nigel
    Thanked: 2077
    If it is fuel, it will now be very heavy on fuel....
    Uniglide
    +27 zero eight 2 four 95 9252
    I just drained some of the petrol and its black ish with bits floating around in it
    Nigel
    Thanked: 2077
    That is no good.
    You will have to replace your filter as well...
    Uniglide
    De Kelders
    Thanked: 131
    Quote Originally Posted by henris View Post
    That is no good.
    And maybe remove and clean out the fuel tank. Happened to me many years ago when I was doing some work in Ugie. Started up in morning, missing like hell and black smoke. First cleaned out carb and road tested. After a short distance same thing. Had to have tank cleaned out too.
    Apr 2008
    Happened to my Bantam as well. Filter on pickup tube inside the tank blocked eventually. Had to remove and clean petrol tank, remove filter on pickup tube and installed external filter in engine bay.
    Phone the filling station and complain as they sell dirty fuel.........could have been your or my wife's car and she got stuck on the road, she being robbed and raped because of their dirty fuel.
    Demand a new full tank or contact the Supplier.
    Andre ZR6AGA
    2009 VW Tiguan 1.4 TSI Field & Track
    Oct 2006
    CAPE TOWN ,SOUTH AFRICA
    Thanked: 502
    That hardbody has a metal fuel filter underneath almost under drivers seat. Blue smoke is the one to watch out for. Could mean rings and bearings. Also check if oil on spark plugs.
    But as you say towing , well maybe ECU adjusted or compensated for the load and should rectify itself shortly when things get to normal. Those engines , well maintained should get well over 250000 klm
    ORA
    Ian
  1. Navara vs Nissan Hardbody
    By Shelby in forum General 4x4 Discussion
    Last Post: 2011/01/29, 10:32 PM
  2. Pls help Hardbody owners
    By william coetzer in forum Nissan
    Last Post: 2010/11/19, 09:58 AM
  3. Nissan Hardbody smoking
    By newbie123 in forum General 4x4 Discussion
    Last Post: 2010/10/22, 11:30 AM
  4. Ford Ranger 2.5 vs Nissan Hardbody 2.5
    By James130 in forum Ford & Mazda
    Last Post: 2010/05/29, 07:12 AM
  5. Hardbody underbody rattle - found
    By Hard Body in forum Nissan
    Last Post: 2010/03/09, 03:37 PM
