Gearbox problem or clutch?
Results 1 to 13 of 13
    Oct 2014
    Default Gearbox problem or clutch?
    Hi,
    I just bought a '95 V8 Discovery. The engine runs like a clock.
    I can't get the Disco to move. Shifting gears and moving between Lo and Hi feels like positive shifts but no power gets transferred from the engine to the gearbox.
    The the transfer box and the gearbox engage on the driveshaft. I tested this by pushing the disco backwards and forwards and selecting the gears. With the transfer box and the gearbox in neutral the Disco runs free. With just one the transfer box or the gearbox shifted into gear it still runs free. Then I select Hi or Lo and any gear on the gearbox I get the resistance from the gearbox and transfer box on the wheels.
    Any ideas or anyone ever experienced this?
    Springs
    Thanked: 280
    my crystal ball says strip the gearbox out and check
    Oct 2014
    LoL, thanks. Only option left. :-)
    Thanked: 90
    Pit
    To take the box out WILL tell you whats wrong and unless you going to do it yourself will cost about 3K in labour
    I have often wanted to buy one of those things with a light and a camera on the end - like the doc uses when he shoves it down your throat to look at the back of your toe nails
    Cause in this case you could put it up the hole in the bellhousing to see if the clutch is actually moving as it could just be a master and slave cylinder problem
    I think this contraption could also be used to check in many other areas of the landy to help in problem solving
    Owning an older vehicle means doing a lot yourself or paying a lot of money for labour
    Ross
    Mar 2014
    Pit
    Ross
    I've been thinking recently of using ones of those things to check the state of the pistons/cylinder walls......
    Hillcrest
    My money is on the gearbox. The main shaft and lays haft are worn to the point where they have resistance with low torque but slip under high torque. Strip from the props haft end and keep going until you find the problem
    Defender 110 - 300tdi
    If the good lord put me on this earth to accomplish a certain amount of things before I die, I am so far behind I will never die!
    Gaborone
    Thanked: 12
    Take the rear (PTO) cover off the transfer box and look at the state of the gearbox output shaft splines. It sounds like these have worn away, resulting in no power from the gearbox to the transfer box - thus no power to the wheels.
    Talking
    Quote Originally Posted by Pitpaplo View Post
    Hi,
    My Disco 2 V8 engine also runs like a clock, a fast running clock.
    Tick, Tick,Tick Tick, Tick (Worn Lifter)
    Thanked: 448
    R380 box? I've got 2 that have the same problem.....stripped input shafts (toothless), common problem if you run low on oil, or tow the beast with the transfer box engaged.
    Not worth repairing....
    Oct 2014
    Thanks to everyone that commented.
    I found the problem after dropping the gearbox. This was the most uncomfortable vehicle to work on. Hope I'll be able to get my hands back in to tighten the belhousing.
    Here are a picture of problem and why the Disco didn't want to move.
    No, trace of any carbon/ceramic left in the belhousing.
    Thanked: 14206
    AHA
    Wading Plug not installed before going through deep water...........
    I'd now refresh ALL drivetrain lubricants and check diff and gearbox breather pipes.
    Axles and transfer case: Castrol SYNTRAX 75W140
    Gearbox: check with the boffins, could be ATF in the R380, I only ever had an LT95 or LT85. I used Castrol SYNTRANS 75W90 in the 5-speed LT85.
    Gaborone
    Thanked: 12
    Gearbox uses MTF94, if you can source it in SA (no longer available from Castrol AFAIK).
    Did you need to skim the flywheel? And did you replace the clutch fork with a reinforced aftermarket fork? The LR tandard fork is thin where the clutch slave cylinder plunger pushes against it, and a classic cause of "the car won't move" is the clutch failing to respond to pedal pressure because the plunger has gone through the fork.
    Springs
    Thanked: 280
    that is the 2016 racing clutch conversion everyone has been talking about
  1. Replies: 3
    Last Post: 2019/11/06, 08:44 AM
  2. Hyundai IX35 Clutch problem
    By cfraser in forum Hyundai
    Last Post: 2013/06/06, 05:32 PM
  3. Advice needed: 2002 Colt 2.4 ClubCab 4x4 Gearbox problem
    By Theunis Kruger in forum Mitsubishi
    Last Post: 2013/04/09, 08:53 AM
  4. Chev Captiva Clutch Problem 2
    By Cap driver in forum Softroaders
    Last Post: 2010/08/16, 02:10 PM
  5. Replies: 3
    Last Post: 2008/02/04, 07:41 AM
