Results 1 to 3 of 3
    Mar 2012
    Thanked: 51
    Post Comet Spring Siding (C/2013 A1) set for a close shave with Mars
    Anyone else keeping an eye on this?
    Comet is currently about 40' North of the Butterfly Cluster. Pretty dim at a mag. of about 9.8 which makes viewing it from light polluted areas very difficult. Set to pass by Mars on October 19 ( @ 20h30 SAST and North Eastern SA is perfectly positioned for best viewing) - apparently so close that NASA have moved all their satellites to the other side of the planet for fear of damage from all the dust particles in the tail.
    Interest sake:
    - it's shedding approx. 100kg of "dust" per second and each dust particle is moving at about 56 km/sec.
    - It'll be passing about 140 000km from the center point of mars although initial estimates where that there was a very good chance it would actually impact Mars
    - Were it to be passing by earth, it would pass between the moon and the earth at about 1/3rd of the distance to the moon.
    Gary
    Mitsubishi Pajero 3.2 DiDC LWB (Gen 4)
    Metalian Maxi with loads of "making it mine" - SOLD
    Afrispoor Cheetah EZ Camper - 2 sleeper, Inside Shower
    Nov 2012
    Mosselbaai
    Very interesting
    Jan 2009
    Oral
    Thanked: 1537
    Seeing as this is a Mars fred, can I post this here?
    http://www.mweb.co.za/TechnoZone/Vie...from-Mars.aspx
    What I like about this is that some amateur astronomer found this and he has scientists denying its existence because it is so difficult to explain.
    Yet it has been corroborated. There sure are some mysteries still to be solved.
    C
